Home » Eclipse Projects » Eclipse 4 » e4ActivePart and visible when
e4ActivePart and visible when [message #865418] Mon, 30 April 2012 07:45 Go to next message
Phill Perryman is currently offline Phill Perryman
I am trying to make a menu item active when a certain part becomes active. In e3 I used the activeEditorId. I have been trying to use the e4ActivePart variable but from looking at the code using it in an injection it always returns an MPart which in turn contains an object of the type I want.
So a core expression such as with="e4ActivePart" and an instanceOf="MyClass" does not work as the class is always org.eclipse.e4.ui.model.application.ui.basic.MPart.
so
<definition id="activepart">
<with variable="e4ActivePart">
<instanceof value="swb3.quotes.QuoteEditor"></instanceof>
</with>
</definition>
is never true, I tried iterating over the active part in case it contained a collection of user classes.
but
<instanceof value="org.eclipse.e4.ui.model.application.ui.basic.MPart"></instanceof>
</with>
</definition>
is always true.
Is there another way to display a menu item only for certain parts.
Re: e4ActivePart and visible when [message #865709 is a reply to message #865418] Mon, 30 April 2012 10:33 Go to previous messageGo to next message
Christoph Keimel is currently offline Christoph Keimel
have you tried something like this in your handler?
@CanExecute
public boolean canExecute(@Optional @Named(IServiceConstants.ACTIVE_PART) MApplicationElement part) {
	return part != null && part.getElementId().equals(MY_PART_ID);
Re: e4ActivePart and visible when [message #865726 is a reply to message #865709] Mon, 30 April 2012 10:40 Go to previous messageGo to next message
That works fine for disabling but I don't want the handler menu item to be displayed at all so need to hide it with a visible when rather than have it showing but disabled. The can execute won't hide it only disable it. Given the number of different editors and commands I would have something like 25 disabled commands under a menu as opposed to 4-5 visible ones relevant to the editor in question. So I really need a core expression to control the visibility based on the active part.
Re: e4ActivePart and visible when [message #870320 is a reply to message #865418] Mon, 07 May 2012 12:05 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
so far in Eclipse4 we publish the MPart that's active. If you want to check if your editor part is active, for now you could try writing a property tester that could check
"your.part.id".equals(mpart.getElementId())
PW
Re: e4ActivePart and visible when [message #871030 is a reply to message #870320] Thu, 10 May 2012 10:55 Go to previous message
Thanks that put me on the right track. I noticed that the receiver in the test method is the current input part.
For anyone else looking I created a property tester
public PartPropertytester() {}
public boolean test(Object receiver, String property, Object[] args, Object expectedValue) {
if (receiver instanceof InputPartImpl) {
InputPartImpl imp = (InputPartImpl) receiver;
return imp.getObject() instanceof QuoteEditor;
return false;
Where QuoteEditor is the class of my editor part.
I added it as a property tester in the manifest
<extension point="org.eclipse.core.expressions.propertyTesters">
<propertyTester class="swb3.PartPropertytester" id="swb3.PartPropertytester" namespace="swb3" properties="part" type="java.lang.Object">
</propertyTester>
</extension>
I then created a definition for use by the menu
<test forcePluginActivation="true" property="swb3.part">
</test>
</with>
</definition>
I then added the menu in the xmi file
<children xsi:type="menu:HandledMenuItem" xmi:id="_lSY_kH5UEeGwE_NvT3bHXA" elementId="handled.InvoiceAddress" label="Invoice Address" command="_uvx2IH5LEeG8BsWZBE4Y6g">
<visibleWhen xsi:type="ui:CoreExpression" xmi:id="_z8SYEIL9EeGHd819fxj36w" coreExpressionId="activepart"/>
</children>
The menu now appears whenever a QuoteEditor is the active part.
I tried injecting an MPart into the property tester but it was always null. Now to make the tester more generic by passing in a class name rather than using an instanceof test.
Previous Topic:Using Factories in Class URI for Parts
Next Topic:Compatibility Layer
Current Time: Tue May 21 05:18:19 EDT 2013
Powered by FUDForum. Page generated in 0.01820 seconds
