| Re: Scout Client minimized to taskbar disappears when trying to reopen [message #871182 is a reply to message #870981] |
Fri, 11 May 2012 06:09  |
Urs Stöcker Messages: 2 Registered: May 2012 |
Junior Member |
Im currently suffering from the same problem on my windows 7 32-bit machine.
The error is rarely happening if I lock the screen while my scout application is running.
I found a suggestion about the reason and a prevention of the error saved in file awt-html.pdf (could not post link - sorry)
As far as I understand the reason are asynchronous awt threads that interfere.
I tried to reproduce the error while running a awt-robot over night starting and doing those reported tasks (minimizing over task bar, minimizing in the window, invoking a screensaver) about 500 times. However I could not reproduce the error one single time! So it must be really random and depending on other stuff.
Have you any suggestion how to reproduce the error reliably?
However I found some people that have the same problem regularly but did not recognize it as the application closes without any message...
FUDForum. Page generated in 0.09571 seconds
