Home » Modeling » UML2 » How to get the root Model from XMI file exported by Enterprise Architect
How to get the root Model from XMI file exported by Enterprise Architect [message #870956] Thu, 10 May 2012 06:50 Go to next message
jy zhang is currently offline jy zhang
In my standalone programm,
I can use code below to get the root model of .uml(attached) created by UML2Tools.
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(
    UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
URI uri = URI.createURI("33.uml");
Package uml2Model = UML2Util.load(RESOURCE_SET, uri, UMLPackage.Literals.PACKAGE);
But when I use code below to try to get the root model of .xml(attached) exported by Enterprise Architect, i failed.
    "xml", UMLResource.Factory.INSTANCE);
URI uri = URI.createURI("erModel.xml");
RESOURCE_SET.getLoadOptions().put(XMLResource.OPTION_RECORD_UNKNOWN_FEATURE, Boolean.TRUE);
Package uml2Model = UML2Util.load(RESOURCE_SET, uri, UMLPackage.Literals.MODEL);
XMIResourceFactoryImpl xmiResFactory = new XMIResourceFactoryImpl();
Resource res = xmiResFactory.createResource(uri);
res.load(RESOURCE_SET.getLoadOptions());
EList<EObject> contents = res.getContents();
I got uml2Model as null, and contents contains all AnyTypeImpl.
How can I get the root model correctly?
Thanks a lot!
  • Attachment: erModel.xml
    (Size: 8.31KB, Downloaded 41 times)
  • Attachment: 33.uml
    (Size: 1.53KB, Downloaded 40 times)
[Updated on: Thu, 10 May 2012 06:52]
Report message to a moderator
Re: How to get the root Model from XMI file exported by Enterprise Architect [message #870973 is a reply to message #870956] Thu, 10 May 2012 08:07 Go to previous messageGo to next message
The *.uml extension is for Eclipse UML dialects
The *.xmi is for OMG dialects.
Try using *.xmi, since you appear to have a regular OMG file.
Ed Willink
> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put( UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put( "xml", UMLResource.Factory.INSTANCE);
> Thanks a lot!
Re: How to get the root Model from XMI file exported by Enterprise Architect [message #870978 is a reply to message #870973] Thu, 10 May 2012 08:45 Go to previous messageGo to next message
Thanks Edward,
But I'm OK to load *.uml by my code, now my problem is to load *.xml.
I can NOT get the root model of *.xml exported by EA.
Thanks again!
Edward Willink wrote on Thu, 10 May 2012 08:07
Ed Willink
> Thanks a lot!
Re: How to get the root Model from XMI file exported by Enterprise Architect [message #870986 is a reply to message #870978] Thu, 10 May 2012 09:14 Go to previous messageGo to next message
As I wrote before;' try *.xmi
Ed Willink
On 10/05/2012 13:45, jy zhang wrote:
> Thanks Edward,
> Thanks again!
>> Hi
>> Regards
>> Ed Willink
>> Boolean.TRUE);
>> > Thanks a lot!
Re: How to get the root Model from XMI file exported by Enterprise Architect [message #870997 is a reply to message #870986] Thu, 10 May 2012 09:45 Go to previous messageGo to next message
Hi Edward,
But I've tried to load *.xmi exported as XMI2.1 by EA too,
the same problem as *.xml
I got 3 AnyImpl instances in contents.
Thanks a lot!
EDIT: (i'll attach erModel2.xmi and append code, root is always null)
public class Test {
	public static void main(String[] args) throws ClassNotFoundException, IOException {
				"xmi", UMLResource.Factory.INSTANCE);
		ResourceSet resourceSet = new ResourceSetImpl();
		URI uri = URI.createURI("erModel2.xmi");
		resourceSet.getLoadOptions().put(XMLResource.OPTION_RECORD_UNKNOWN_FEATURE, Boolean.TRUE);
		Package root = UML2Util.load(resourceSet, uri, UMLPackage.Literals.PACKAGE);
		System.out.println(root);
Edward Willink wrote on Thu, 10 May 2012 09:14
Ed Willink
> Thanks Edward,
> Thanks again!
  • Attachment: erModel2.xmi
    (Size: 8.31KB, Downloaded 38 times)
[Updated on: Thu, 10 May 2012 10:26]
Re: How to get the root Model from XMI file exported by Enterprise Architect [message #871231 is a reply to message #870997] Fri, 11 May 2012 10:16 Go to previous messageGo to next message
After debug, I think I found the key point:
packageRegistry and regeistry extension for factory.
No matter .uml or .xml or .xmi, it's just postfix,
if the file itself is an XMI file, it can be load by EMF correctly.
We can use code below to get root and root2.
public class Test {
		Registry packageRegistry = resourceSet.getPackageRegistry();
		packageRegistry.put("http:||schema.omg.org/spec/XMI/2.1", UMLPackage.eINSTANCE);
		packageRegistry.put("http:||schema.omg.org/spec/UML/2.1", UMLPackage.eINSTANCE);
		Map<String, Object> extensionToFactoryMap = resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap();
		extensionToFactoryMap.put(XMI2UMLResource.FILE_EXTENSION, new XMIResourceFactoryImpl());
		extensionToFactoryMap.put("xml", new XMIResourceFactoryImpl());
		URI uri2 = URI.createURI("erModel.xmi");
		Package root2 = UML2Util.load(resourceSet, uri2, UMLPackage.Literals.PACKAGE);
		System.out.println(root2);
Anyway, Thanks Edward for your help ^-^
Re: How to get the root Model from XMI file exported by Enterprise Architect [message #871358 is a reply to message #871231] Sat, 12 May 2012 06:34 Go to previous messageGo to next message
The significance of *.xmi, is that there are contentType registrations
so that the XML file is read, the namespace is identified and the
corresponding UML version is exploited. OMG contentTypes are only
available for *.xmi MDT/IML2 dialects for *.uml.
Explicit package registrations as you have are now, as from Juno M6, in
UMLUtil.init, with the content types in UMLResourcesUtil.init().
Finally the difficulties that you and many others experience when taking
responsibility for standalone initialisation will have an easy solution.
Ed Willink
On 11/05/2012 15:16, jy zhang wrote:
> After debug, I think I found the key point: packageRegistry and
> public class Test {
> Boolean.TRUE);
Re: How to get the root Model from XMI file exported by Enterprise Architect [message #871360 is a reply to message #871358] Sat, 12 May 2012 08:30 Go to previous message
Hi Ed,
Great, it's good to put these esstensial initializations in UMLUtil.init().
Now it's a little hard for us emf/uml2 newbie to use it.
Looking forward the coming updatation.
And Thanks again!
Edward Willink wrote on Sat, 12 May 2012 06:34
Ed Willink
Previous Topic:Error to get sendEvent or receiveEvent value from UML sequence
Next Topic:uml2 docs, books
Current Time: Thu May 23 16:43:35 EDT 2013
Powered by FUDForum. Page generated in 0.01736 seconds
