Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » Remote Import of log file
Remote Import of log file [message #87089] Tue, 14 November 2006 06:55 Go to next message
Eclipse User
Originally posted by: cvkmurthy.hotmail.com
I created a log parser plugin using rule based parser. On remote of
log file I get an error "IWAT0061E The remote log parser "ETS
1.0(static)=./ETSParser/AC.adapter" could not be initialized.
Exception=./ETSParser/AC.adapter". I created log parser plugin and
deployed it in the Agent Controller as per the intruction given at
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. tptp.platform.doc.isv/concepts/cintro.html.
What could be the reason?
Krishna
Re: Remote Import of log file [message #87138 is a reply to message #87089] Tue, 14 November 2006 11:17 Go to previous messageGo to next message
Eclipse User
Originally posted by: cindyjin.ca.ibm.com
It seems the your adapter file is not found. Where is your adapter file
located? It should be at <RAServer HOME>/plugins/<Your
plugin>/config/ETSParser/AC.adapter.
If your AC.adapter is at the correct location, could you please attach
your pluginconfig.xml?
Cindy
Krishna wrote:
> Krishna
Re: Remote Import of log file [message #87235 is a reply to message #87138] Wed, 15 November 2006 03:53 Go to previous messageGo to next message
Eclipse User
--------------030003050601070804000608
Hi Cindy,
Even the local import is not working for me. I get a popup which
says "An internal error occurred during "Importing log file..." and on
the parent Eclipse's console I see the following exception.
org.eclipse.tptp.monitoring.logui.internal.wizards.ImportLog Wizard$LocalLogImportJob.parseStatusString(ImportLogWizard.j ava:1240)
org.eclipse.tptp.monitoring.logui.internal.wizards.ImportLog Wizard$LocalLogImportJob.getProgressStatus(ImportLogWizard.j ava:1218)
org.eclipse.tptp.monitoring.logui.internal.wizards.ImportLog Wizard$StatusListener.run(ImportLogWizard.java:2073)
Exception in thread "Thread-1" java.lang.NullPointerException
org.eclipse.tptp.monitoring.logui.internal.wizards.ImportLog Wizard$StatusListener.run(ImportLogWizard.java:2078)
Regarding remote import my adapter file is in
<RAServer HOME>/plugins/<Your plugin>/ETSParser/AC.adapter
I copied ETSParser/AC.adapter to <RAServer HOME>/plugins/<Your
plugin>/config to see if it works. But I get the same error. Attached is
my pluginconfig.xml file.
Krishna
> Thanks
> Cindy
> Krishna wrote:
>> Regards,
>> Krishna
Content-Type: text/xml;
name="pluginconfig.xml"
Content-Disposition: inline;
filename="pluginconfig.xml"
<PluginConfiguration requires="org.eclipse.hyades.logging.parsers">
<Application configuration="default"
executable="RemoteLogParserLoader"
extends="default"
location="%SYS_TEMP_DIR%"
path="%JAVA_PATH%">
<Variable name="CLASSPATH"
position="prepend"
value="%RASERVER_HOME%\plugins\ETSPlugin_1.0.0\ETSLogParser.jar "/>
<Variable name="GLA_CONFIG_PATH" position="prepend" value="%RASERVER_HOME%\plugins\ETSPlugin_1.0.0"/>
<Parameter position="append" value="&quot;config_path=%GLA_CONFIG_PATH%&quot;"/ >
</Application>
<Option name="ETSPlugin" type="version" value="1.0.0"/>
</PluginConfiguration>
--------------030003050601070804000608--
Re: Remote Import of log file [message #87254 is a reply to message #87235] Wed, 15 November 2006 04:00 Go to previous messageGo to next message
Eclipse User
--------------090406060404070608040703
Hi Cindy,
Please find the plugin project attached.
Krishna
Krishna wrote:
> Hi Cindy,
> at
> at
> at
> at
> Krishna
>> file located? It should be at <RAServer HOME>/plugins/<Your
>> Thanks
>> Cindy
>> Krishna wrote:
>>> Hi,
>>> Regards,
>>> Krishna
> extends="default"
> path="%JAVA_PATH%">
> position="prepend"
> </Application>
Content-Type: application/x-zip-compressed;
name="ETSPlugin.zip"
filename="ETSPlugin.zip"
UEsDBBQAAAAIAHalajVx71xnxwAAAIsBAAAUAAAARVRTUGx1Z2luLy5jbGFz c3BhdGidkEFr
AjEUhM8t9D8sufvW3nrYrUixYA8qomeJyesaG1/iy4vov3dVlnqph95mhuEb mGpw3PnigJxc
oFq9Ql8VSCZYR02tlovP3psavL88V8brlKKWTWuefh2S8Kn4cWRrldio4hLe ZPl30wTqmoEb
QONdTAhbK+B1JrNp1+FrPlp9TCeL4Xgymv+DFi2CCYzAuM+O0c58bhylRyjv 1h2qvGdJlAjR
a/kOvAM8osnSHlZe8uvGVvMjbsgSs3TotaNruSrvXz0DUEsDBAoAAAAAAKih aTUAAAAAAAAA
AAAAAAAUAAAARVRTUGx1Z2luLy5tZXRhZGF0YS9QSwMECgAAAAAA9HlpNQAA AAAAAAAAAAAA
ABkAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5sb2NrUEsDBBQAAAAIABZybzVh yrexeD8AAKsu
CgAYAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ubG9n7F1rb9s4s/58AuQ/sIv9 4BeoaUu+G/AH
10m3PidNg7hFcYAAgWIxibayaOiSy/76MxRlWbalWE7ctNnzdC+1LpzhUMPh zDwc6d3keDIZ
fzllZr3erhpGtd5jRqtP/zaa3Kw3WHW3P4cHYuo680Dwq8hx7bE9iLwfnrz3 Dg/+tu4sfif8
wJHewOAtXr+st9PTni39wSTy2Gdn6svgMQjFLGBjb8oPDz5IGZ5IyxY+m0ov CC0vDPrsy2Rw
73gN8z0bno8+DR667ffse3ru9GQgvMtvk8ODj741E/fS/8Es/yaaibgxq859 aUfTkEn/hi/6
HNg/uGMLumgL14q86e3hwUjOZpZnV13HEztQsK3QYkf9i+RCg5u8vji4UL0J 5tZUXBx/nZy5
0Y3jUQtxx64dV/SP+rVsq8VBLW1V4zMRWopDjc/j1kEt2wnqPZ9KX9SIOjuz /ED4NaLOqcNz
4YeOCDISsqoMWDxorHqf/rJ8ukJDenhwePDu+PTr+f+uiBnNibti4l07N5Fv hdLP0aAWb9d7
1P4z6djwr2M2kpFrM0+GzFFP0XXZVeTZrmB5Qtw+0gMPuHgQ0ygkleGW88Dn 8+llUw0Kv1Ps
6m2jYbSMHmPsVLIPMbHqqRU6d2Ik6SnMrFA9wpeJYLb2JsLtPHrgZ8PL8/Fk 9JbloLlAgpB6
vLoQzfrehAika/lOwGlK+XvTqnAezvlMeg5J4Hg33JU3kcOa9M+aOO1+q87b HTMjzvj78Gu9
0e4ds6+3ZGpsax5qi5eMCXU6NhAsNRq14Yin91meGokrwa4ldZkzdvwwFfO4 1WDPtKnTk6/D
0f8weho5Y0xC3yjh57HpCfiJvNFWKO1R/00J+1/WqpEvENPxqLlnudyZzaVP v/lfJ8NPwiWb
y29EONT0z6zwtrK8oJa/vmH2/rPJJleXllxIi10+jlnRAG/wqaxfijm1G7sz unf+sXw7WPL6
Hp9IxPzoy9mJnFruJxmElfV7YqZms2Humy0dFzAzu639MfMjL59No2nkcAnu Qz6NglDO+Ico
eBx7tjNVxowHt/L++y3pXGX1vH4onf11mJ70tfRnHx3PCW4LRqidN0B/X5Nn kZDl+vYjxyKu
/DqmdeaLIBB2ZeWS7n63vhO9qygMpVdMr9Eq7p8d3xdwff+fDWJgk85PhCum IVFb6Vc7r1/q
EelGAf/6OBf2iUO+pkcT5NZSlv6YfNGwsnolJtfbRi1u+dW6cuk0+bOaUOZk 0qktVL7Hf2co
JCd0H8zuluZHTjB3rUeluEfiWvi+0GSCyuKKHuNGszQlYdlDz1aHauFbpWP2 2nl0Fg+fvPp7
kij+i3oU9+REynklORfT6JpP6U+WBLmv3krTTi9vOGmeWFNl5RfT41wEMvKn IhjGpzOzev2K
NsetPHOcofrBCoRWOTpcaMmS9ncnvNXP7qkbNasnhk9z4/r2kfRC37mKXZcx xUaJtn7PqD9d
qRTcHPNqNfLEKsPLmtIIBX+aT5Jvdp8pyp+tlan3JI86JmHpSZhdLr5T7Hgl KNxbm4bpaa2N
PaO5C6Fv4w0K3U75rkxJqlCQWOc0ZxZn1yk2jYLJeOZaoVrqvo0LCGVu0H1r FlBaOm4UOI+P
jofzuavW59RUrJ7SSpC3Rqmge0mNmobOTKQdVYp9p1b9P42Y7Mb5xKblDWBM eUEw5RC7rNTu
WN9FnTyJY3pasujeTJ8rOXckurwPZhR8+WEhj1zlXOGxRnqiyGkZKmunnrAC L6FodBYuWBDR
MxfXyp5yHfN9FuGttIexCZQ+LRukJ96d/CHqFX0D03fsTqBSeF2bh14OySMy 9TfUzLspJvvk
PdpiLLRXHXHXIv9ywUA3WZBKjvT6ketYx8PuLh74Z8vxkrZp3q0Sn0wsXp7l zSFxZQXOlGZz
pq2Z62bmtPVXmvU6ed51TrMZ/S/brqWmxvHsSti2sJlI48tr6bryPuj/JqHv pmz7D09zTTDC
U4SnCE9X6SE83dIc4SnCU4SnmIQBwlOEpwhPS1JEeIrwNDc8zcWgk/gvcpjB 6iVw5+Ugn0au
eybjKZXGq1msd9ud62I8J0R0gkk0jwNU+0sUzskZLwoWjVzv6udHi7l2GtEi okVEi+tUEC0W
k0C0iGgRkxDRIqJFRIt7pYhoEdFibrT4Lr/Yo2X2m23e6NVR7IFij2dtzlca 1OFN9YTfarHH
/kX4NcUe+5fjFxR7JEKY5t6E+CnFHrmVHa1Gv97iZq+T6fs3T8cENhPKW2Uu uavLHSVPUV/P
3+VRXy57r5y/K0jbnFk3Yj2VkXdLvDJ1c/deIK/xCiEV8hrIa5Qmj7zGz5mE yGsgr4G8RimK
yGsgr1EeBS90zjvcbGWryPfrnK9TXz47OOdwzuGcwzmHcw7nHM45nHM453DO l8MO5zx2n7u8
1fx5mfN16stnB+cczjmcczjncM7hnMM5h3MO5xzO+XLY4Zwr99kweLPx05zz DerLZwfnHM45
nHM453DO4ZzDOYdzDucczvly2OGcx+5zkxvNn7atZYP68tn9IuecfO6PjiuO RGg5bkBm1qEW
juU6/4hvY/0ah5tjV6j6ncrGvYke5tmG57LXy4Cu2B/S7wKmRqfY31x9HUBC Ufkiyeq9fBlA
t/6CFxYWdD1llN/xRjdv9uQ5yprciqvcNIsb50q9Iq1hmHmeQTknfY/vz9gp AOz0trlXCAB/
ku+JABABYGnyCAB/ziREAIgAEAFgKYoIABEAlg8Ai74wZ+ZHbStv+jvzJS1D s4DJ6TRSCwO7
vxUei4eMaLGpqni+puApLqquOl6f/bGV9x/8dcI99V4+RUPFegGtp2phHknS KkHxwup1PfNz
H/ezw0vF8qN0beFnmebFlbnPvDxf/Q6HtYi2kr2gJ4T5gnflZ6kl/lVvk0Wz +4I3HWao0ZJj
S09sMjDahbMqpfe3vAr4f8urhQMb/Nngngyd68dK9uya1dqBHvXttIgehZ7P IkjC5hBrlSf2
2fIolPQ5+YB0VMmc0Q+/WXLgxskREdDdyp5IHJNCw7pYzxadSgVLFN3I00DS hbkvb9QLEfm3
Md2cOBzx74RlPY9l1vMk4+spj5nm9I+49coJ/ai30Zg8kn31SU//STySgE58 pm7RMAaVlau6
V7kTqsCzXiW25lib27pW0rHu5L2VE9EtotvS5BHdvngSIrpFdIvoFtEtottf B282+02Tm13j
58CbOdSXzw57DwE9AXqCcw7nHM45nHM453DO4Zwvhx3Oeew+N3mrncWZ9uuc r1NfPjs453DO
4ZzDOYdzDucczjmcczjncM6Xw459YQX+esvgnZWX1I6/D7/WG+3eMft6K1is pvrzO8kHOmiy
xl+rYekXbGrDEU/vszz1WY4rwa5l5NmcsdTFZoM9085691npkw9+kNA3Svh5 vM0oswkp7VH/
TQm7riEFYi7Xith/JOX562SYfCqXVuyhpn9mhbeV5QVtY8xnbPGK8r7bu+ST /7Xe9gu2q61F
U7t8rDc33MLHehcPBR/rxcd6EeRvJ4EgH0E+JiGCfAT5CPL3ShFBPoL83CD/ eHYlbFtBaGl8
eS1dV94H/d8k9N2Ubf/haa4JRniK8BTh6So9hKdbmiM8RXiK8BSTMEB4ivAU 4WlJighPEZ6W
x6CT+C9ymJG3k1Phzu3W77CTMzdEdIJJNI8DVPtLFM7JGS8KFo1c7+rnR4u5 dhrRIqJFRIvr
VBAtFpNAtIhoEZMQ0SKiRUSLe6WIaBHRYm60+G5CEd/4y+lKTNju1+v9epM3 2z1W3e3P4cGi
B1eR49pjexB5Pzx57yWR4p3wA5qvA4O3eP2y3k5Pk8/jDyaRxz47U18Gj+RK zAI29qb88OCD
lGTOKYKNIVGajLTS9NmXyYC8p4b5ng3PR58GD932e/Y9PXd6MhDe5bfJ4UH6 nJjl30TquwPU
mFXnvrSj6drKZP9QNpIu2kIP3uHBSM5mtHpXXccTO1CwrdBiR/2L5EKDm7y+ OLhQvaGFbiou
UjyXWoi7GOPtH/Vr2VaLg1raqsZnIrQUhxqfx62DWrYT1PtYAWpEnWmsuUbU 1ev/KHwKHRFk
JGRVGbB40Fj1Pv1l+XSFhrSoJHRO3BWTBUAt/RwNavH2yltORzJybaagakc9 RddlV5Hyi1ie
EEnKQjyIaewkcct54PP59LKpBoXfKXb1ttEwWkaPMXYq2YeYWFUbnZF6Y+pM +RK/kQi38+iB
nw0vz8eT0VuWg+YCCULq8epCdDt7EyKQruU7Aacp5e9Nq2K7q17LufHi31iE Rpt3elkRhuol
v9oBYeRHk9jpG4DtSOVF+uwPHcnRb0ahf2wiOOcve7lv6f0gcebrRN4sEi3K CFPYEGqrQhdu
hF/JvUkvMvvLi/25ykW9s5QWwi/eltycYb7kXbml+lDIuHA9T/nEL3BVHn3i uyU/E3fkifW5
0W/UudluYX3G+vw8e0oaZCgNesPr895F+EXrs5Zj5T13b2993rsQL12fC0yn YVCkpcosYTph
Op+l6kqDemt+3BsznVqErvHWQ5v9y/ELTOf+hfgpoY0MbjZfBEW9N/umwTuN 5mpUsxbM3Cts
mFlRKImFQ060+8gsnRdWgU0i3NJkVJr/2SgpVx3g1wuTx3XvM5vo463zi1wz E2Ggx4qn+Wd2
Tf9tsHIC9Z0Vy3XsTW99jWXqt8de/PAqCH1iqDtCIYRl658pw8raLUmaPg9Z f5KTbq4gI/EQ
xllOnZHePK+jrlz8pwQHFUZp0joQqWRO6/ymkZds3GWUdMfzxsVsFeZOt+Xq T6x/Hhf57rkv
PjqeHUdqI9cKgkrOTTHD3A9nxrJcWYFYsHB1OBuTmlvh7eJzH9erTDauJ5n8 vOAz5pHKkmV2
JK6tyA1jYkkcvcYn5w6tVbnoZIlnns9m5VqS2i4UpTSDQtq9Z06JMrRzP+6y 0yNQKvD06HcX
RSrLREw+gY2WZutloi9Jb4pudl5iB9YpL62Aab7UCixp51pIs/jTN0v0Udw4 1PRR8z1PjiZE
LBQ3j18mfy1g0+N4WVTg+PFDKDzlo1dyb0+scyGcssk6Jbig9wTLzXtjfp3c vRgF/EbZgrBj
/RHlJ1jm3q6fYDOvqmoHrp/iDQ078k4a6exWntrv+gWreOPEzSIbOY7jp2nm c1bLjRVG7p6G
n74xsNF4gZjYGIiNgSk9bAzc0hwbA7ExEBsDMQkDbAzExkBsDCxJERsDsTEw d2PgyIrISWVX
j/31nMapDD+q14xkMq85udZNzvtJ5zTrO+cekCp666miUmn1RryCc85Z22Az onR4cC5luHxN
Tz+7TwqqDFX+zVV5dwmAEBU5bUCIgBDBVr4xW6lpAyECQpR2AAjRdrZAiIAQ ASHabA6ECAgR
ECJMwgAIERAiIEQlKQIhAkJU/kWDceOC+mdVKWDyVhP1z6h/TvhsrX/eqRKl qV4RUG8Yh6hE
QSUKcAbgDMUMgDMAZwDOAJzhDjgDcIY74AzAGYAzlCIBnAE4AyYhcAbgDLnx P3AG4AzAGfaK
M6ASZYU2UkW/MlVUKq2OShSo8r9KlXeXAAhRkdMGhAgIEWzlG7OVmjYQIiBE aQeAEG1nC4QI
CBEQos3mQIiAEAEhwiQMgBABIQJCVJIiECIgRHuqRNGVAu3sFzdQiYJKFJ1J jiklP5M5VaRk
Kp+TX4nSbPOGsaZfqEQpxBlQiQKcATgDcIZE64EzAGcoyQ84A3CGE+AMwBmA M2w0B84AnAE4
AyZhAJwBOANwhpIUgTMAZ0AlClJFqESBKkOVUYkChAgI0RPmBggRbOXr2UpN GwgREKK0A0CI
trMFQgSECAjRZnMgRECIgBBhEgZAiIAQASEqSREIERCi8pUoKtQuLhJo9VAk gCIBpICRAkYK
GClgpICRAkYKGClgpICRAkYKGClgpICRAkYKGClgpICRAkYK+CkSKBLAzmqk ilAkAFX+f6/K
u0sAhKjIaQNCBIQItvKN2UpNGwgREKK0A0CItrMFQgSECAjRZnMgRECIgBBh EgZAiIAQASEq
SREIERCi8kUCcePiz1WoSoFeHZ+rwOcqNJ/nfa4CSgYl26eSvZuQooy/nK6r Urvf7HCj1WbV
3f4cHiw6chU5rj22B5H3w5P3XqJDd6QGpDEDg7d4/bLeTk9T9OYPJpHHPjtT XwaPFBTNAjb2
pqSHH6RMnjqbyjiPFQZ99mUyoDiwYb5nw/PRp8FDt/2efU/PnZ4MhHf5bXJ4 kK44zPJvIpVq
o8asOvelHU3XfGz7h/L26KIt9DJweDCSsxnFIVXX8cQOFGwrtNhR/yK50OAm ry8OLlRvyGWf
iotlLVbVFnfx5Osf9WvZVouDWtqqxmcitBSHGteIbVDLdoJ6H+tBjagzPZNq RJ1Th+eCZroI
MhKyqgxYPGisep/+sny6QkNaYIaiOXFXTBZ5TDIsmxrU5R0jWxs3kpFrM0+G ZJPoKbruoiIt
T4jEhIg4faocbMt54PP59LKpBoXfKXb1ttEwWkaPMXYqmc6SV7X7NJL0FGYq KvqNRLidRw/8
bHh5Pp6M3rIcNBdIEFKPVxei0dybEIF0Ld8JOE0pf29apfCWvErRTt9o8J6J z0mV3QeASlHs
A8A+AOwDSLQe+wCwD6AkP+wDwD6AE+wDwD4A7APYaI59ANgHgH0AmIQB9gFg HwD2AZSkiH0A
2AeASlGkilApClWGKqNSFAgREKInzA0QItjK17OVmjYQIiBEaQeAEG1nC4QI CBEQos3mQIiA
EAEhwiQMgBABIQJCVJIiECIgRHuqFO2QneGddgtFfCji03yeXcTXVUV8jWYT RXwo4nte0VVX
FV2tfuDurRXx7V2EX1TEp+XotPYmx68o4tu7EK9axNfr1w3execeS0O0KOID RAuIFhBtovWA
aAHRluQHiBYQ7QkgWkC0gGg3mgOiBUQLiBaTMABEC4gWEG1JioBoAdGiiA+p IhTxQZWhyiji
A0IEhOgJcwOECLby9Wylpg2ECAhR2gEgRNvZAiECQgSEaLM5ECIgRECIMAkD IERAiIAQlaQI
hAgI0Z6K+Hr9urn2xSUU8aGIT2eSY0rJz2ROFSmZyufkVKKY7X7L4PVOF5Uo qEQBzgCc4QkG
wBmAMwBnAM5wB5wBOMMdcAbgDMAZSpEAzgCcAZMQOANwhtz4HzgDcAbgDHvF GVCJskIbqaJf
mSoqlVZHJQpU+V+lyrtLAISoyGkDQgSECLbyjdlKTRsIERCitANAiLazBUIE hAgI0WZzIERA
iIAQYRIGQIiAEAEhKkkRCBEQov1UouhKAaOOShRUoiR89luJ0lWfK+t1m6hE QSUKcAbgDE8w
AM4AnAE4A3CGO+AMwBnugDMAZwDOUIoEcAbgDJiEwBmAM+TG/8AZgDMAZ9gr zoBKlBXaSBX9
ylRRqbQ6KlGgyv8qVd5dAiBERU4bECIgRLCVb8xWatpAiIAQpR0AQrSdLRAi IERAiDabAyEC
QgSECJMwAEIEhAgIUUmKQIiAEO2pEqVL7gOvGy1UoqASRfPZWonybkKKMv5y uqZKjXq/2eOd
XodVd/tzeLDoyFXkuPbYHkTeD0/ee4kO3ZEakMYMDE6aellvp6fJsfYHk8hj n52pL4NH8ldn
ARt7U9LDD1ImT51NZZxiCIM++zIZkIveMN+z4fno0+Ch237PvqfnTk8Gwrv8 Njk8SI0Bs/yb
SGVBqDGrzn1pR9M198f+oRZiumgLPUMPD0ZyNiMXseo6ntiBgm2FFjvqXyQX Gtzk9cXBheoN
eVNTcbEsk6na4i6efP2jfi3banFQS1vV+EyEluJQ4xpMC2rZTlDvYz2oEXWm Z1KNqHPqMMXo
oSOCjISsKgMWDxqr3qe/LJ+u0JAWmKFoTtwVk0WKiQzLhga16rxrmBljNJKR azNPhmST6Cm6
7qJYKE+IxISIOLOlfB/LeeDz+fSyqQaF3yl29bbRMFpGjzF2KplOYFb1yjaS 9BRmymH9jUS4
nUcP/Gx4eT6ejN6yHDQXSBBSj1cXwuzuTYhAupbvBJymlL83rVKp8JwivobR N+u81c4+AhTx
oYivYJQA0QKiBUQLiBYQbZKXAkS7c2h5AogWEC0gWkC0gGhXmwKiBUSLSQiI FhAtINpyFAHR
AqJFER9SRSjigypDlVHEB4QICNET5gYIEWzl69lKTRsIERCitANAiLazBUIE hAgI0WZzIERA
iIAQYRIGQIiAEAEhKkkRCBEQov0U8elKgW5z7XM/i1mEIr4nwxd8TiqlofI5 eZUoJvmM3Gj9
X3tn19s2rq3h+wH6H7SLXqRAw+rTX0AuujM9Z7KRfqDp7N4MULiO2nrGiX1M O53uX39IUVJk
S7IYV3bi7mcwwGRsa5GUFpfI9fAlOyhRUKLAGeAMGwqAM8AZ4Axwhhs4A5zh Bs4AZ4AzWJmA
M8AZ6IRwBjhD5fwfzgBngDO0yhlQoqzYJlV0n6kiq7Q6ShRc+ady5bu3AEJU N2iDEEGIiJUH
FiuNbQgRhCivAISouVgIEYQIQlS+HEIEIYIQ0QklhAhCBCGytAghghC1pERJ lAJB30WJghLF
lLP1cVKBevmJXtTnOCmOk9ru+B/lQb7odYtn2x3acVKtN+GejpNqvR33cZyU acTKy+1+j5Oq
C50dFVlF6PuETkLndq6uPKgvon7YmqvvP3S23oR7Cp1JOzpu/6BDZ+uN2FXo 7Kp/9Xm4hE5C
53aurjyoJ9zAO+DQ2XoT7il0tt6O+widphFh98GEzsqG6AUYVVtH9AaeL7rR WkKIrSMWbB3B
wkAWBrIwkIWBLAxkYSALA9sp9pyFgSwMZGFg6XIWBrIwkIWBdELJwkAWBrIw 0NIiCwNZGMjW
EaSK2DoCV8aV2ToCQgQh2hBuIETEyv3FSmMbQgQhyisAIWouFkIEIYIQlS+H EEGIIER0Qgkh
ghBBiCwtQoggRC1tHdEbeMGazoGtI9g6wmSSE0vpn2mfqnMync+pVqIEPeH3 1/wLJUotZ0CJ
AmeAM8AZUq+HM8AZLMuDM8AZzuEMcAY4Q+lyOAOcAc5AJ5RwBjgDnMHSIpwB zoAShVQRShRc
GVdGiQIhghBtCDcQImLl/mKlsQ0hghDlFYAQNRcLIYIQQYjKl0OIIEQQIjqh hBBBiCBElhYh
RBCi1pQoQU8Eno8SBSWKKWe7Q0x7iagpEp3Q4zgpjpPa4vgf40H6QLJOa8f/ 7Pk4qV004T6O
k8rbEfittWPvx0ntohH7O05K1b6vj+frRwEiPkR8IFoQ7YYCQLQg2jxWgmh1 eSDaQgVAtM3F
noNoQbQg2tLlIFoQLYiWTihBtCBaEK2lRRAtiBYRH6kiRHy4Mq6MiA9CBCHa EG4gRMTK/cVK
YxtCBCHKKwAhai4WQgQhghCVL4cQQYggRHRCCSGCEEGILC1CiCBEbYj4jFKg J4K+i4gPEZ8p
5+4iPs91PH8Q+AM3FP1+FxHfD4r4dMEb9Xr5Dx62NO/WL7qi2w8PUZpXbELP c1trwr6leSvt
8KPDlOatNKJ7aNK8vPbqhatMtyzNU8MGxHlrQAT0WjcbAr2CXkGvoFfQK+gV 9NpKYaBX0Cvo
FfS6ahX0Cnp9+J0Q9Ap6Bb1aWQS9gl4R55EqQpyHK+PKiPMgRBCiDeEGQkSs 3F+sNLYhRBCi
vAIQouZiIUQQIghR+XIIEYQIQkQnlBAiCBGEyNIihAhC9KPivFutQF8EHuI8 xHlpOVuJ83x3
EAZqyCa6UfjzivOGt6+o0ktZvYu/Ze9yS6WevbmfULaXekwkukH/QGV7O2nC Pcj2btsRHa5s
byeN2JtsT9c+1CfqBV4X2Z41lEW2B5QFygJlU68HygJlLcsDygJlz4GyQFmg bOlyoCxQFihL
J5RAWaAsUNbSIlAWKItsj1QRsj1cGVdGtgchghBtCDcQImLl/mKlsQ0hghDl FYAQNRcLIYIQ
QYjKl0OIIEQQIjqhhBBBiCBElhYhRBCiFmR7qVagV9YKZL0I2d7G6ct/p2zv TlqUSL1jhdvp
oUWxJg1oUSANkAZIQ+r1kAZIg2V5kAZIwzmkAdIAaShdDmmANEAa6IQS0gBp gDRYWoQ0QBrQ
opAqQouCK+PKaFEgRBCiDeEGQkSs3F+sNLYhRBCivAIQouZiIUQQIghR+XII EYQIQkQnlBAi
CBGEyNIihAhC1JIWxWgF+sUjUNCioEUxmeTEUvpn2qeePqo4QirQp5H5nnal 0PU4QoojpGTD
kT+5x/RFvxO0duTPPo+Q2lET9n6E1I7asd8jpIqN6LZ3ntdOjpCqjPOrOj7T nI4+3tHrF0/E
0no6/cY1L0Pn61A6egB56UyXC9Uv1ehH/Xecv5yH198dHQOEunAsVa2+O59i 9e9IryRxFsrY
iy8qGjnJ9HU6mZhoeZsCTuKK/mihBhpSmctkeas/E87bSTyU6S9HC0dFkcvl SA8FZ7oqouZO
pPdbowQd9dbb3x24fRH5RZ98O5+OkkTcwDn2nE/fF7F8Zv7zXMaqdPW5+8yJ k9mrrkX24/zD
lZ9NhjO9oEbfwYEaGpmvZO0bLuyouavodVzecLzhrCKS8pjAFf3ogN9waRM6 B3xI4o7acQ9v
uLQRvQd+SOLmuB52B2Ff+D1v73H9h17HqtpRKLxecduGsw8v3qsfeebFPI+v pgvzfjazV+ex
jj2ecI/Ug1mMR09PhI5GaTB6cWryPvH8sYrg2UNU7+exqstYvWX/E18Kx8mn zM6JY2duq6cS
Bfpt63f2/7b9oaeiqu2FohP0fsanoh6JNwhdEa4MaR/8UzHVjkS34/6cT8Uz T8XvHdZT8cxT
8aMDeCqVQ/BQTYgGXkf4bpchOENwiyGT8Ziu8FdeEAc1BN9FE+5jCL6Ldux9 CJ43Igof9hBc
r68svQJC9doahL6aQLS8N1TkeuwNtb4e95SV/zUwnpX/rPxn5X+p6az8Z+U/ K/+zlQqtrZBg
5X+5FFb+W9hj5f8mK6z8rzfByn9W/tMJWfnPyv/K+T8r/1n5z8r/Vlf+szfU im1SRfeZKrJK
q7M3FK78U7ny3VsAIaobtEGIIETEygOLlcY2hAhClFcAQtRcLIQIQgQhKl8O IYIQQYjohBJC
BCGCEFlahBBBiOz3htJT7RqZQCD67tq2UMgEkAmQBCYJTBKYJDBJYJLAJIFb K5YkMElgksDl
y0kCkwQmCUwnlCSBSQKTBLa0SBKYJDAyAVJFyARwZVwZmQCECEK0IdxAiIiV +4uVxjaECEKU
VwBC1FwshAhCBCEqXw4hghBBiOiEEkIEIYIQWVqEEEGI2pIJdH1kAtZJYGQC JIFJApMETr2e
JDBJYMvySAKTBCYJTBKYJHD5cpLAJIFJAtMJJUlgksAkgS0tkgQmCYxMgFQR MgFcGVdGJgAh
ghBtCDcQImLl/mKlsQ0hghDlFYAQNRcLIYIQQYjKl0OIIEQQIjqhhBBBiCBE lhYhRBCiVmQC
oXCDEJmAdRIYmQBJYJLAJIFTrycJTBLYsjySwCSBSQKTBCYJXL6cJDBJYJLA dEJJEpgkMElg
S4skgUkCIxMgVYRMAFfGlZEJQIggRBvCDYSIWLm/WGlsQ4ggRHkFIETNxUKI IEQQovLlECII
EYSITighRBAiCJGlRQgRhMheJpBc/Of0k3RCx6/WCvS8Va1A1ovWRQOXSz24 HziPzXBECwXU
+NX5rGYKQojHK/KA22f1ejmZvJ0mNvOsfrmNX78PL2OpJw5f9ARilswFZSHa JUWq5ifTNzVJ
yGYLSepEZvNJ9cWXeH5U+SNzp6rC6nbTlyerpfxr+kk/zTfXDRNMNa3ddR1q C651yrwc7SnC
ZJITS+mfaZ/CyXCyh+xk/S5OhpPhZDjZg3YyjT+qpJuemvaJqNNBujmxBfNI NwHzgPkV24D5
bZu+js9XbAPmAfOA+XRk1NqIDDBfLgUwb2EPML/JCmC+3gRgHjBPJwTMA+Yr 5/+AecA8YL5V
MI90c8U2qaL7TBVZpdWRbuLKP5Ur370FEKK6QRuECEJErDywWGlsQ4ggRHkF IETNxUKIIEQQ
ovLlECIIEYSITighRBAiCJGlRQgRhMheuqmn2jUygY7wowCZgHUSGJkASWCS wCSBU68nCUwS
2LI8ksAkgUkCkwQmCVy+nCQwSWCSwHRCSRKYJDBJYEuLJIFJAiMTIFWETABX xpWRCUCIIEQb
wg2EiFi5v1hpbEOIIER5BSBEzcVCiCBEEKLy5RAiCBGEiE4oIUQQIgiRpUUI EYSoFZlAV4Th
2rk7yASQCZAEJglMEpgkMElgksAkgVsrliQwSWCSwOXLSQKTBCYJTCeUJIFJ ApMEtrRIEpgk
MDIBUkXIBHBlXBmZAIQIQrQh3ECIiJX7i5XGNoQIQpRXAELUXCyECEIEISpf DiGCEEGI6IQS
QgQhghBZWoQQQYjsZQLJxX9OP0kndPxqrUDUWdUKZL1oXTRwudSD+4Hz2AxH tFBAjV+dz2qm
IIR4vCIPuH1Wr5eTydtpYjPP6pfb+PX78DKWeuLwRU8gZslcUBaiXVKkan4y fVOThGy2kKRO
ZDafVF98iedHlT8yd6oqrG43fXmyWsq/pp/003xz3TDBVNPaXdehtuBap8zL 0Z4iTCY5sZT+
mfapH3Cyro+T4WQ4GU72oJ1MZ6arVXVRX/i9EFWdNTNFVQczhZnCTFOvh5nC TC3Lg5kOYaYw
08oKw0wnMFOYKcwUZgozvX1dwExhpjOYKcw0jRgwUztmiqpuxTapovtMFVml 1VHV4co/lSvf
vQUQorpBG4QIQkSsPLBYaWxDiCBEeQUgRM3FQoggRBCi8uUQIggRhIhOKCFE ECIIkaVFCBGE
qDVVXdQXgRehRUGLYspp1KL840I5ytmb1yuuFKn+r12pE7rO8d3+efRLVpFP y/Hk8uzyZHn9
1/X023XqQzfKDZTHnHgiEu5Ht5N/rAbW85OL5bXzajyaT+V3NV69ks7Z9Uj5 4T+n0/SpO6Np
kmJYyIHz5uJEDdED/5nz4t3pbyd/9zrPnA/5Z6/PT+Lrj79fPPolDwbOcP5l qbMg6mLneHj7
iiq9lNW7+Fv2LneOZ5ex6a6PfjmdXl2p8eLxZHwdb2vucrgYOr8O/tAfqSHV KP7jVitzfBnf
JD1w8Ovgef6D5+IqXgz1dc+FgWfyebEMVcHkuT9XhhzTc54rQ2I2V7MW1bNj WWiEczyVTnKT
nONv+V/DufpG3cKasLOcqdJ1IVlKSQWSVY8J3YHriaDvFoLP6XQ5uXSupwsV g9RTm0wycVBV
I9KQESeZLD3WGY7/FrPZ6GMofOGKG12c2/FUePP6juO8njomYXls3mSn08vY udID1AfUhK+z
5d/i7YuP784uTvfdjtCNWmuHcnfVEOUeh9wIOZ0M52MpVJeat+ZVZuSXzeTV SznqdCtaEgo3
KLrVh6xrO+pa1fj48plqixpuTa9Ua+ZTNV1U0S97VSev4t//aUr32ihfS/lU MX+qUZej7tJo
Pk5e5EnocY5E+tXTRNCngsor8yLTUr6rsZT6heYoG+p/kwvUY1yowYt0zGtd hWf1gPT0woTD
4aepatritsjk4tsKfBurJ6mf6mcVn5IrTOCafHf0kHqiLs1KUv/Nbpi4i5Ay uQuB6tzdtS0H
EFIipASTg8nXCgCTg8nzWAkm1+WByQsVAJM3F3sOJgeTg8lLl4PJweRgcjqh BJODycHklhbB
5GByhJSkihBS4sq4MkJKCBGEaEO4gRARK/cXK41tCBGEKK8AhKi5WAgRhAhC VL4cQgQhghDR
CSWECEIEIbK0CCGCELUhpDRaAV/4PQ71QkiZltPioV7Kv/S/wo/cR2hRbEkD WhRIA6QB0pB6
PaQB0mBZHqQB0nAOaYA0QBpKl0MaIA2QBjqhhDRAGiANlhYhDZAGtCikitCi 4Mq4MloUCBGE
aEO4gRARK/cXK41tCBGEKK8AhKi5WAgRhAhCVL4cQgQhghDRCSWECEIEIbK0 CCGCELWkRTFa
gZ6HFgUtiimnXS1KZxB0hBeuaZ3QoqBFgTRAGiANkAZIA6QB0tBaseeQBkgD pKF0OaQB0gBp
oBNKSAOkAdJgaRHSAGlAi0KqCC0Krowro0WBEEGINoQbCBGxcn+x0tiGEEGI 8gpAiJqLhRBB
iCBE5cshRBAiCBGdUEKIIEQQIkuLECIIUUtaFKMV6AZoUdCimHLa1aJ0B74r oiBEi2JNGtCi
QBogDZCG1OshDZAGy/IgDZCGc0gDpAHSULoc0gBpgDTQCSWkAdIAabC0CGmA NKBFIVWEFgVX
xpXRokCIIEQbwg2EiFi5v1hpbEOIIER5BSBEzcVCiCBEEKLy5RAiCBGEiE4o IUQQIgiRpUUI
EYSoJS2K0Qr0O2hR0KKYcrbToqiafsteZbV+1gmDgp+9nU/VEOdKFjUpsfY9 1R21Z42ml7Hz
Wc3XHU1/jsfXyu/qivwx16t+Eb7QQTmeZ6lhNcBJPzla+yaNUVXJmcIovG5g PZpezZaLOB/a
H20egVfmgCyKKUw7LYuqThgW5xXL8eTy1rx6nn8qa/L9NPniqPi1qXtl+qjG 4HJ2qQZJt1OF
kjW/XzN0s5n2yOzzUzWW/6Jm4s1TH79mrFlV+bF8ea3H7xU3wXerxjAFO+9i 9arXzpbVNP3L
5OHmR2vfG6PdGqMrY8XqEvT0L82QNxVW/KkZ2jR4yFpdVUxfpMNHdWuqGuJF TSN6FeUX2fPR
/81Gp2sfp4PTxvHixfBzrF7c12mwK/yvGQHUvo3Xh8srY2Rzca+ur9Y2Rnwe z9N5ZXWDopob
vtni25X7XnOrqt4M65Yv4vnNWE2Qq41m3xp7Nm3Prkj97iYxWrbldWsCx+0s 7cP4uniZiR4F
m+s/2Nyna+2mqQW3xp5XNeTcYE85r+4Tv8bD/EZWGq6ceG967P6TsLJb+FlF a0nCw+wY/oae
kbap7v3bYPPt2v2vvWNNLljVP9YNr3lLTTZwqy5SmSWvTGS8VYOWrJVJTW/t Zm/D6t+a22xT
6eTn5RrfWvH8JjMrVViztfqd8UevMuFdb3Ee/98yllkE0yOMCqt+18pT3w6v qwzmX6UDRJs7
l/y+mF9cM1KZfH5wGcXNl1eyffvLg6pHUrz84ms8mdy6TJKbnU6OzMdp16uc BZaNfHj18dWb
3y9evjh9f/bvF+9frhipTh4WjaRFp1xADZBHR9lHxmv9XlUcXUmpxiqqDs1w qmCm+HE6cqrM
l5ebVDBSbEyncoFTVXK3WItiXjd0/aoYpE0UJrHXgS/eXOgFGx9yOx8qU1N3 NHKkPjBN6XtN
z+VipB7BJOkPeueDgpHCN2YY0/R8Gh9xwI3lxnJjubHcWG4sN5Ybex839nSl Pdve2VUrt7e2
FzaN6N9X3dXChMSPmh5OkwWv1zQtaOGZmPK+VVYgDCvXQ+/skb6N479exVKq yeq2z7NgIn+Y
ftA8JbFc5dE0dWaVB6s8ZqzyqLPIKg9Wediv8kiXT2hZho4fFfw9EEF/jb+P kkXNA8cLvU7o
u86n74tYPjP/eS7j0fRafdl1e77nPnPiZE2gM7u9zA99P/s8/7nne576cDKc abGydnz1Q8d8
K+1WD1TtaBmIjt8r1P7Di3evz17/70A1I6mAKmsej5ZzqZ1/uFjEV7OFs5hm u0/GjgYtVXdM
L8Auxtvr4c34SxL5zqdfXmf/k+6XKRfjycQZXzuLr7FzNb68VJ9NPxc3ziwV kyzrmGX8Q5d2
M46/FRa2mP9Vhf1b/RHPqxcyvDMxpKCK/YlvgNWb2pYLhHfjAtntqjIWVa4Z rrf1aSm/X3yd
ftPtqrLnuW67Bvu9pnUA641NcKYXVBqzX6arL1JW8vVC6w8h7NeNKVuSn2zw kA23S9XLemhp
YawSoW8pjNHagbRHVK/l6nstlpb6Qa+6qF6lV225XC31kmqpj9s4R9cMWs+5 zqejvxJDKx+Y
B1E3h8rn+d/Vg5urmv8nHZNK9UE6D5JHK9+abuo3TS0LK+hXja0toK+d3t1x alW5HuJ+VSyr
gqf0BqT6Jm3ipV5JerT6ubkrfpV3GXNL9bbJVyIkU+0UjWavwaOVL018aByH F9Yy1JmznyY0
rZOoFYquz8RYQMQCIhYQsYCIBUTZz1lANGQBEQuINjILFhCBCrmx3FhuLDeW G8uN5cZyY3dx
Y1lAxAKijSZYQMQComKijgVELCBiAdEBLSDSO7JWrb3pmR1iimtvOE02K5DT ZNkrvK6MvC3s
Fc5e4ds3nb3C2SucvcLZK3zIXuHsFc5e4ewVPjLQ/oy9wtkrnL3CSQLfkASe kQQmCZxGDJLA
dklgTpNdsU2q6D5TRVZpdU6TxZV/Kle+ewsgRHWDNggRhIhYeWCx0tiGEEGI 8gpAiJqLhRBB
iCBE5cshRBAiCBGdUEKIIEQQIkuLECIIkb1MILm47jTZRCvQ8UJOk+U0WVPO dqfJpk9vOXa8
KkFK1BX9qF9wsuK18dVnEZt4mI5vRTbQfXL25sN8OFOzmwIPyr50nr98f/HK 3DAtGbmeqnap
MXdJpbLDgmq8+Gp6GU+k+DqO58P56Ot3sy/eb9n//v7uTI0Yb2LtzzrMPcm/ yd6yWdFvlovZ
cnGxUEOGK/FtPl7E76f6iaiB1Sg/gfao1nAaizpV46SdVvXzZKkm9A318npV WYmd1ms0mcrG
++V1q+5XhfeM9SVZOcn1cngTH618kljsVXa8jS29UJZ+139ok79OR8urZEie f2xqevcna2e3
Ml+0tmO1+C35/+Sq0SQeXi9ntwcVF74z79JNz9pYzEOQHi7/+tYcTvzy79lE 3fO5uFRzCP3s
yt8Y+3fZmFfPpNVER/1PLC6nvxrL6/uMFX+UjgybtmLUm7/WWV79Ln3Zb1nl 9FZsrGylQL/G
+JfcZt1ma15U6RH19mZJla6mN+t7y2X2Kvf0Wr+Z/6Om4tO5nlAq/5Jxsrlu 8fN0eNjU1Ldq
JDHTOYeb25tX/MyYueO+0xVP4bZ19o82TRAlgemFGiglu9Cuf5tY7TbuCbl+ 2Vf16j+drFSy
aNALK2nqJot6P+sNFjuVW8NuMni7vWaVvajuyPA6e0/8fNBSvn+VW2C2mARv fL519bLcHDij
1Kmtlc/MA60k15XVeuKt3amsLjs5gLs6o1LhTGkt7NtxuxP2mo1OZf6w5l6E VfeiV7u93i79
Zd1Tsrr8qIHKB/sjXb0u00VXb6GrpznmZLvG5CFkid2CrcrsRIWtJ4FqYGbn csVGp3Kj+K2h
UzWKeHAJ782X/+hepY176RT28UxcxVxe3t/Tr9z6u87Uh1cfT8/fXLys2Ce0 4zbd0MaNkvzm
3D+7ltoZudP+ZEnD17cmu70bYeWSkDs9WYttyXiyPNmDerIpd/zBvdLWzBSe rv3xIg0g1Hr6
BQjdUDVA6HaFAUIBodc/u1RuQ0fPktV5Cv/H2E+d9TRfLVSdR3+ZhzpWc52j 7PM0ytmsns5M
/s84X8d7lPxtbNQnb+xtdKui7cPEWlHiWVpe1gtTedlWcLInok4POAmcBE5a tvS/CU5OrE5b
zXHQyodpWL4DWAJNrhoHTd6AJq0sgibThoImQZOgSbr6jro6aHKTFdAkaHJD TQBYACyeLGgS
NFltCDS5ags0WVUGaBI0CZoETWobB4Mm/3Hx8uLi7M3rNQAZuQO3L/xe3zm+ 2z+Pfsluwafl
eHJ5dnmyvP7revrtOtXeqjrpTZ1OPBEJ96PbyT9Ww5j5ycXy2nk1Hs2n8rua Jl9J5+x6pBzn
n9NpqpZ1RtNka6aFHDhvLk6Soccz58W7099O/u51njkf8s9en5/E1x9/v3j0 S95BneH8i2E3
A8c5Ht6+NkovSvV+/Ja9X53jmXqISRdS/WR6daWm9MeT8XW8rbnL4WLo/Dr4 41v2/P64PWPs
+DK+SZTLg18Hz/MfPBdX8WKor3suzKaj8nmxDFXBxGt113OM4vi5MiRmc9Xz 5otxLAuNcI6n
0kluknP8Lf9Lu42jbmENrF7OVOm6kGwrLtW5Sx7judpjCsj6dLqcXCYRYKyf 2mSSHapW1Yi0
y8TJDmB6/DEc/y1ms9HHUPjCFTe6OLfjBV7k9R3HeT11zEZvx+btcqq6mnOl B40PqAlfZ8u/
xdsXH9+dXZwecjuUu6uGKPfYdyMCN2qtEXI6Gc7HUqguNW/Nq/SWgRXHHUbe wPVFz+0+4rhD
281sOe6QzWwLk1Q2s2Uz2+2bzma2bGbLZrZsZstmtmxmy2a2bGabbTt7xma2 bGbLZraA0htA
6QxQCihNIwag9M6g9PZWJVN2zogjVbTnVJFVWp3jDnHln8qV794CCFHdoA1C BCEiVh5YrDS2
IUQQorwCEKLmYiFEECIIUflyCBGECEJEJ5QQIggRhMjSIoQIQlRJiCplAsnF Nccdaq1AIMLA
f8Rxhxx3mJSz3XGHOp9TrUUJXOGvH6eJFgUtCqQB0gBpgDRAGiANkIbWij2H NEAaIA2lyyEN
kAZIA51QQhogDZAGS4uQBkgDWhRSRWhRcGVcGS0KhAhCtCHcQIiIlfuLlcY2 hAhClFcAQtRc
LIQIQgQhKl8OIYIQQYjohBJCBCGCEFlahBBBiFrTomitgF88OgQtCloUk0lO LKV/pn3q6aOK
I6RCx+sMor76VwR+lyOkOEJKNhz5ozymO3Bd9a/oREWh0uEcIVVsQtdtrQl7 P0JqR+3Y7xFS
O2rETo6QSkvRCXTd19cbEapZiXB7XqER+rjfJP00cI4959P3RSyfmf88l7G6 Iepz95kTJ3M2
Z3b74/zDlZ9NhjO9jEQPPAdqQGC+kjWVrXwprYoOs2r7gfA7xQOwzj68eK9+ 5L1MZIDz+Gq6
iJPxgnm3O4917PGEe6QezGI8enoidDRKg9GLUzMqjuePVQTPHuKnWD3H8WI8 nIz/E18Kx8kH
FM6JY2eu6gUWOZ6rRplqwCeCsMMLjBdYU8DJPSYUYddrLeDs8wW2oybs/QVW bId+mAf5AttR
I/b7AjON6Ay8vuh7xYMcH/YLLKu2H4nOSrUf6gussqGaqFe1qzdwPeG77AZg v9aL3QBY68Va
L9Z6pV7PWi/WelmWx1ov1nqds9aLtV6s9Spdzlov1nqx1otOKFnrxVov1npZ WmStF2u92A2A
VBG7AeDKuDK7AUCIIEQbwg2EiFi5v1hpbEOIIER5BSBEzcVCiCBEEKLy5RAi CBGEiE4oIUQQ
IgiRpUUIEYToh3cDKGgFIrcoBmI3AHYDMJnkxFL6Z9qnntaLKfsDNxKR30dM iZhSWonflMd0
tMccsJjSNCFsb0ODexJTtt6O+xBTtt6InYgpdeq7SrbXH/ihcKPiXgbI9jZD WWR7QFmgLFA2
9XqgLFDWsjygLFD2HCgLlAXKli4HygJlgbJ0QgmUBcoCZS0tAmWBssj2SBUh 28OVcWVkexAi
CNGGcAMhIlbuL1Ya2xAiCFFeAQhRc7EQIggRhKh8OYQIQgQhohNKCBGECEJk aRFCBCFqSbaX
aAX6Lof4IttLy2mU7d1FixK6Ki4IHy0KWhRIA6ShoQBIA6QB0gBpuIE0QBpu IA2QBkiDlQlI
A6SBTghpgDRUzv8hDZAGSEOrpAEtyoptUkX3mSqySqujRcGVfypXvnsLIER1 gzYIEYSIWHlg
sdLYhhBBiPIKQIiai4UQQYggROXLIUQQIggRnVBCiCBEECJLixAiCFE7WpRU K9DjCCm0KGk5
2x4hFXYGoS/80OcIKY6QkjZH/miPCUQQFYPPgR0h1X4T7ucIqbQdnU5r7biH I6Tab8Q+j5AK
u/oIvsDtIduzhrLI9oCyQFmgbOr1QFmgrGV5QFmg7DlQFigLlC1dDpQFygJl 6YQSKAuUBcpa
WgTKAmWR7ZEqQraHK+PKyPYgRBCiDeEGQkSs3F+sNLYhRBCivAIQouZiIUQQ IghR+XIIEYQI
QkQnlBAiCBGEyNIihAhC1JJsrztwO8Lv+8j2kO2ZcraV7UXhIHBFLwiR7SHb kzYyK+0xnvKY
4HBle+034X5ke2k7wn5r7bgH2V77jdinbC/qqJm8CLprCnpke8j2gLJA2bUC gLJA2TxWAmV1
eUDZQgWAss3FngNlgbJA2dLlQFmgLFCWTiiBskBZoKylRaAsUBbZHqkiZHu4 Mq6MbA9CBCHa
EG4gRMTK/cVKYxtCBCHKKwAhai4WQgQhghCVL4cQQYggRHRCCSGCEEGILC1C iCBE7cj2jFag
3y8eUIRsD9meySQnltI/0z71tF621xmEHeVKEbI9ZHvSSmalPKYnvH73gGV7 rTfhnmR7STt8
Lzho2V7rjdirbK87CDrCC11ke9ZQFtkeUBYoC5RNvR4oC5S1LA8oC5Q9B8oC ZYGypcuBskBZ
oCydUAJlgbJAWUuLQFmgLLI9UkXI9nBlXBnZHoQIQrQh3ECIiJX7i5XGNoQI QpRXAELUXCyE
CEIEISpfDiGCEEGI6IQSQgQhghBZWoQQQYhaku11B0FXqCE2sj1ke6ac7WR7 3sD11JBNhG4P
2R6yPdksszIeE4rIO1jZ3i6acB+yvbwdLZ4auHfZ3i4asT/Znqq9P3D7Qr3/ ke1ZQ1lke0BZ
oCxQNvV6oCxQ1rI8oCxQ9hwoC5QFypYuB8oCZYGydEIJlAXKAmUtLQJlgbLI 9kgVIdvDlXFl
ZHsQIgjRhnADISJW7i9WGtsQIghRXgEIUXOxECIIEYSofDmECEIEIaITSggR hAhCZGkRQgQh
akO2l2gFPFf0fA/ZHrI9U852sr1goLwp9IQbdpHtIduTzTIr4zG+cDvBocr2 dtGE+5Dt7aId
e5ft7aIR+5Ptqdr7g8ATfW/tVYxsD9keUBYou1YAUBYom8dKoKwuDyhbqABQ trnYc6AsUBYo
W7ocKAuUBcrSCSVQFigLlLW0CJQFyiLbI1WEbA9XxpWR7UGIIEQbwg2EiFi5 v1hpbEOIIER5
BSBEzcVCiCBEEKLy5RAiCBGEiE4oIUQQIgiRpUUIEYSoDdme0Qr4ousHyPaQ 7ZlytpbthWqq
JryOj2wP2Z60klkpj+mKIOwfsGyv9Sbck2zPtKMTHrRsr/VG7FW2Fw18V7hu D9meNZRFtgeU
BcoCZVOvB8oCZS3LA8oCZc+BskBZoGzpcqAsUBYoSyeUQFmgLFDW0iJQFiiL bI9UEbI9XBlX
RrYHIYIQbQg3ECJi5f5ipbENIYIQ5RWAEDUXCyGCEEGIypdDiCBEECI6oYQQ QYggRJYWIUQQ
opZke4lWoO8XZSfI9pDtmUxyYin9M+1TT+tle131r/C6fWR7yPaklcxKeUxP e8wBy/ZME/rt
KcXuSbbXejvuQ7bXeiP2KtvrDoJIeFGx9sj2NkNZZHtAWaAsUDb1eqAsUNay PKAsUPYcKAuU
BcqWLgfKAmWBsnRCCZQFygJlLS0CZYGyyPZIFSHbw5VxZWR7ECII0YZwAyEi Vu4vVhrbECII
UV4BCFFzsRAiCBGEqHw5hAhCBCGiE0oIEYQIQmRpEUIEIWpJtpdoBfr9LrI9 ZHumnO1ke6FW
gIaeCKIusj1ke7JZZmU8xhdRdLCyvbwJ3eigZXu7aMfeZXu7aMT+ZHuq9h1d ezXDRrZnDWWR
7QFlgbJA2dTrgbJAWcvygLJA2XOgLFAWKFu6HCgLlAXK0gklUBYoC5S1tAiU Bcoi2yNVhGwP
V8aVke1BiCBEG8INhIhYub9YaWxDiCBEeQUgRM3FQoggRBCi8uUQIggRhIhO KCFEECIIkaVF
CBGEqA3ZntEKBMIPXGR7yPZMOY2yvf8HUEsDBAoAAAAAAKihaTUAAAAAAAAA AAAAAAAdAAAA
RVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9QSwMECgAAAAAAy1VvNQAA AAAAAAAAAAAA
ADgAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNl LmNvcmUucmVz
b3VyY2VzL1BLAwQKAAAAAACooWk1AAAAAAAAAAAAAAAAQQAAAEVUU1BsdWdp bi8ubWV0YWRh
dGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3Rv cnkvUEsDBAoA
AAAAAKihaTUAAAAAAAAAAAAAAABCAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8u cGx1Z2lucy9v
cmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8ucHJvamVjdHMvUEsDBAoAAAAA AFB1bTUAAAAA
AAAAAAAAAABNAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcu ZWNsaXBzZS5j
b3JlLnJlc291cmNlcy8ucHJvamVjdHMvRVRTTW9uaXRvci9QSwMECgAAAAAA PHNvNQAAAAAA
AAAAAAAAAFUAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5l Y2xpcHNlLmNv
cmUucmVzb3VyY2VzLy5wcm9qZWN0cy9Mb2dBbmFseXplclByb2plY3QvUEsD BAoAAAAAADxz
bzUAAAAAAAAAAAAAAAA+AAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lu cy9vcmcuZWNs
aXBzZS5jb3JlLnJlc291cmNlcy8ucm9vdC9QSwMECgAAAAAAqKFpNQAAAAAA AAAAAAAAAEcA
AABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNv cmUucmVzb3Vy
Y2VzLy5yb290Ly5pbmRleGVzL1BLAwQKAAAAAAA9c281oY4MPAEAAAABAAAA VgAAAEVUU1Bs
dWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNv dXJjZXMvLnJv
b3QvLmluZGV4ZXMvaGlzdG9yeS52ZXJzaW9uAlBLAwQKAAAAAAD4eWk18GdD ijkAAAA5AAAA
VwAAAEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2Uu Y29yZS5yZXNv
dXJjZXMvLnJvb3QvLmluZGV4ZXMvcHJvcGVydGllcy5pbmRleAEAAAABAAEv AAECABRvcmcu
ZWNsaXBzZS5qZHQuY29yZQASc3RhdGVWZXJzaW9uTnVtYmVyAAIyMVBLAwQK AAAAAAA9c281
G98FpQEAAAABAAAAWQAAAEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMv b3JnLmVjbGlw
c2UuY29yZS5yZXNvdXJjZXMvLnJvb3QvLmluZGV4ZXMvcHJvcGVydGllcy52 ZXJzaW9uAVBL
AwQUAAAACAA8c281oqgx7DACAADvBgAARQAAAEVUU1BsdWdpbi8ubWV0YWRh dGEvLnBsdWdp
bnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLnJvb3QvMjkudHJlZa2U PW/UMBzGk+sB
hQFQQZ0oDEzoSmQnsXPpdlIRC3cqbRA6IRSFnClpc0nkJC1lZGJluE/ERFUh BiaYWCpxEh8A
IV6cnKHnvKBUwoNj2X4e//R/7LQXWi0pb/xTbrJ0NaTbCnF9L4qJsjNKFDek JF9qyWw5+0oX
7lhb/TDwkpBmU+0lNnvx6L7xk7vcyrpfvEnS0r1wuxc4/sELQjdouEPcJJdd yWXX3n3mMoHq
srSoRCeb2ani5oWc9q9weZ08dVI/4VhKQt3x87E3J115s8W3t0XpDVFqR4Gn 7UMdZx6B4PHl
+/rXmUx2pRNehnKzxsMGNsh8oqLPD+4zEn28eh8rJfHIOVgdhHtk/IRQqK+q AGAEdKht9O/2
rQ5AGrgNIdbYXDYGyGZB0dQnceTQmNA9qOQ0jkBzbF36xmmIWBm/nuYhGQUF HpTzQKBiiHoF
IIyRgXSgNgKaK08qAlVEhfeBCcpRTSdDk+vOSLPI+bgiqtyjOqqjzeAR154V fSqi+uNjPUup
UBszL40GWVqFqFiArGS6ZjSqDLvE7znBOUmozOjUNOyKgDJNl02qCNi92BtH PpnBVIAMDtf4
4ddFkNOXRYeqCssgpg5xt2FZNoNdTtARaXbraepvMFS1Ig8yMEKwa5iNeKav H7+cIchv/wcP
gmaZx4Am7oJmPJPhK87zSeSpfQyw8jEMDjtcu9LQR63ymX4YIs7zgHWL3Of8 P3y0Sp/JMX8O
8kdp/j8qZ91vUEsDBAoAAAAAADxzbzUAAAAAAAAAAAAAAABDAAAARVRTUGx1 Z2luLy5tZXRh
ZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uc2Fm ZXRhYmxlL1BL
AwQUAAAACAA8c281tVOuIqEAAABoAQAAXQAAAEVUU1BsdWdpbi8ubWV0YWRh dGEvLnBsdWdp
bnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLnNhZmV0YWJsZS9vcmcu ZWNsaXBzZS5j
b3JlLnJlc291cmNlc3PY2N2ovIdBREp12vPFk/fJKecmFpekFimUJCblpPJy KYenpij45Zcp
GJoqGJpYGZlamZoqeAaHKBgZGJjxcqWk5pQkulYUZBYllmTm58XnF6XrpSbn ZBYUp+plpZTo
JecXpdoaGpoZm1oYWJqaGhtb8nIl56QmFrmANGJXnpaYUwy0WV+vpCg11dYI qONAxO/PYDcG
fu6p3l1+zGEIuhkAUEsDBAoAAAAAAKihaTUAAAAAAAAAAAAAAAA2AAAARVRT UGx1Z2luLy5t
ZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUvUEsD BAoAAAAAAKih
aTUAAAAAAAAAAAAAAABAAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lu cy9vcmcuZWNs
aXBzZS5jb3JlLnJ1bnRpbWUvLnNldHRpbmdzL1BLAwQUAAAACAAaemk12qVE hkIAAABJAAAA
YAAAAEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2Uu Y29yZS5ydW50
aW1lLy5zZXR0aW5ncy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy5wcmVm c1MOyShV8Msv
UzCwVDA0tTI0szI1UPAMDlEwMjAw4+UqSy0qzszPszXk5UpNzsksKE7VKyhK TUstSs1LTi3W
Q5IGAFBLAwQUAAAACAA8c281KVWEdRMFAACPNAAAYgAAAEVUU1BsdWdpbi8u bWV0YWRhdGEv
LnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5ydW50aW1lLy5zZXR0aW5ncy9v cmcuZWNsaXBz
ZS5oeWFkZXMuZXhlY3V0aW9uLnByZWZz7Vptb6JKFP7epP+hyY0f5YIvbbcb P1BLLS0vLuBt
b0JCKI5Kl7cFtN5/v2eAuuoVUChssiFGA3LmPDPnnJl5zhn+ekbTC8FdXVD9 C6p30+nf9PsX
rKxcdEjy8vxsyNGyPKaVB02URhoz5NixzGiP9/SQGdypN6qKDMv0AtQlOgS5 uVNVz1rOTSdQ
VdefE8m/xNtMN5AWiRIs1g+ffpvqkSTxpvtf09Ae/qXvGFnjxNGIFUbamJZk RpJPh1/8p09R
QFjuHJ7NCU/3A+QHWi/qzyruD/WFpEjQtIieRt2qFCf05pZpe64fVo/1ajo7 Nh6KvMbewnc4
iY357vrfAw98pKqGaxPmK3yN5c4NeK8HH+pXb9MaxWiJDyVRVDIcBr2ayIrI p7l+zEj3vCho
9IgRFHnwtSXRoPMfRtIeRJ5pgZ51iJzAdFPM4yF/ZrsOoc+REwZN86Z507xp 3jRvmv+pzdO4
lDJWxtqYo5V7UeKBAXAcM1RY2FrvJZpnnkXp6XReFXqhR3iWHs5c3yYM17KQ EUI/iZmv2wjz
Aw0zBuAgG0bSpfrUF2BZRiRSjPoUh90nQtsGEuURe7oJ3GBuJsQ2wSKpTE47 FCX8w/O0cFeA
yhquj39sW3emQRajziPT9B09VhipNJnWp7oXIn+PeF5h4rlvgseJwGaRwT3A t6VjhjDEa4JS
1ejmtHDZab9DSsHXg3fT6XbOzx5vRVmOJtrAWVpWvt2w/0obDXtxz2JRhOYk QgojK5oiipxc
rhshCkIidF0rSO0JJCj4eTuKtzIJylFYOKBh/vpLx0F+9XAweZa6VRvcm77S awNbhLA41gq2
QGsfGTWihbDRVY8WK6jNlPEClZoHS+It83TK6rnXB893X9F3WA8PrjqZC075 pabMclcdOgQU
ZlaL8r7NRPicuZGxTsPjT1qmc6OTm8AemGyXRZHQGhlLTNcOI5m60YY5F5o2 6PnFfI8sEVa6
O4M7rdKGPgrkFVEkVTFMWA/MwqJ6lUOATO+terdELCWoGCdlI9jN33jxjuEK pA+7qZPtTpG1
XzM+ZmWuMYkAw88t/VNsnomSlRrKzwU23uA9/EgMu51uxy02BNBCRKlK8ru+ vtzWah/MNekx
PXyIs0xR2Hjr+CHonm4s4jQT4l1L7KdRgNrbipPLPiRWlvn6dyLYTgTbseBJ 4z0F8pCrkiE/
0k+0pNB/+NAfRYHeSVoPhy3D38M1rje88AVKG8iewTXe79a2qXW2J03niiL7 V0nsfch7Ppoh
HzkGTLkV8vG2PaDyE+oaTvXOz3ZKajVQFxh2wti1mDRVRNzTHR/PgP8d7+07 OI66tP9TvX6s
2qxVdROeJUIzIywzym/SRFDYInEQzYbExXtVv24CO+LoOMhaR26erZy9ttLU D1omT0vtsNkQ
WUGQds57yrFwCxeQfBQtyPFlVArHI0qNvW8TVhBfdmbJSQH4Y2k67vpjmhwO hbTeMy/McIJr
79UsRFtjPhCE+ecArd3yfKOiUdGoaFQ0KhoVjYrPUQH8JosNbQhCqxFsBBvB RvB3COYWoX/v
S0Q5p5b1vCZxfsaxt2AzhRFksMOAmOJy3Ed/aGn4MFhfp75NX08+qOJTSKtU fp+vv9wRZ45+
HCJtfRm6to6F2tA4ye/rQgyQvyr5FkC+DUufLW4gtg4LDoIR1UPgok9Fpsqq J9V7TJYESixQ
zHXHQ830IFx7eljwhYUCQO1g6fTJquFid/4EUEsDBBQAAAAIAHt+bTWf8KOd kQAAAKEAAABh
AAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5j b3JlLnJ1bnRp
bWUvLnNldHRpbmdzL29yZy5lY2xpcHNlLmh5YWRlcy50cmFjZS51aS5wcmVm cy2MwQqCQBRF
9wPzDw/aisxouhBcRG0Ci6CWgsjwspHpvWHGjPr6FFod7uFyNicmOPMMOgdd VIWuihyO1xtk
SpVSoHHWR0x9wDsGJIMxnTFEy1RrKZwPY0f9E+u2bXjYUe8+XwyXwCOaSYpX xO7BcaobNr2D
gw2Lhj0TLVwaiVv9+mgrrZTKEk82f+tt+d9S/ABQSwMEFAAAAAgAO3ppNYco sryXAAAAFQEA
AFsAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNl LmNvcmUucnVu
dGltZS8uc2V0dGluZ3Mvb3JnLmVjbGlwc2UuaHlhZGVzLnVpLnByZWZzrY2x CsIwFEX3Qv8h
4P5olSoWugouLu3oEtKXNvBMQvJS8e+NaAfB0enC5Z57NsOcxMUtojqKumnr Q9vsxLkfxLaq
9mXhwgSoyPiIMD/kiBGSAW2IMUQwNoeVBCNqmYhPn/4HxUEqhMXgPXYcEpbF OvABNQa0Kq+W
TBtnu/ofZvbswZNk7cINyE1f+vXpnT0SKn6pr7YsnlBLAwQUAAAACAATgGk1 XtwBGJ4AAADH
AAAAWgAAAEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlw c2UuY29yZS5y
dW50aW1lLy5zZXR0aW5ncy9vcmcuZWNsaXBzZS5qZHQuY29yZS5wcmVmczXL wQrCMBCE4Xuh
7xDwJhJShYKCJ1Hw4sW+QExHjcRu2GxK+/ZG0NvH8M+ie2Z1oVGZrWranTG7 TavO106tjWnr
Ci74mKAj4w7G4JD0CE6ehn1TV8QP/U9evWhHDH3LPvRgzUiU2eFAcT5OLuTv 6+SDgPdLLUiS
sheslrpHDDQXBHJWSlWICS7/3FuxkSgUWhZ/t04Kn/L+Lml81NUHUEsDBBQA AAAIADt6aTWj
f/Sd7wAAAKoBAABYAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9v cmcuZWNsaXBz
ZS5jb3JlLnJ1bnRpbWUvLnNldHRpbmdzL29yZy5lY2xpcHNlLmpkdC51aS5w cmVmc21QPU/D
MBDdI+U/WGK3bFBBFGVAdOlAGtRKmY19Tl3SODqfUwb/eFwBoi3Vbe/j9N67 2Wwjq/3ExCOT
s7l8mM/u2HK9YbdC3JdFDPAWnf5YOGsbBNuoDirCCGVB6r11hrYN+lF1isD8 EGMGfFD9Cg3g
q+vwhPPYcdC9GwPwnSEeHd+pSRmve68VOT8Evj+35AjPw+Dpm70IcfbPKg2c 4JOsH6iS6cVH
dICshkOSIonULuvFql0nmcTF/SEnpqerecE48shzfX449q+uqqzHvSICzGtY 10PgE2DIDSop
yuJXPOY2gDDoU74sjvn/zfoFUEsDBBQAAAAIADxzbzWJ7gtq7gEAAK8DAABn AAAARVRTUGx1
Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJ1bnRp bWUvLnNldHRp
bmdzL29yZy5lY2xpcHNlLnRwdHAubW9uaXRvcmluZy5sb2d1aS5wcmVmc41S wW7iMBC9V+o/
jLyX3UMNoaWqKLSiIUhItEWQsnuwhCwypFk5cWQ7lO7X75gE2krdVW/2zHtv np/n209M4EFv
IehCcNHrdHvdLkwWMXTa7cvTE6XXUj1r6/hQgM3yUqGAUhqLhs/mj6OnMF7N o2k0XESDgAdf
Iyyj+WLy+FATyiI7fwkuLnkULwSYSqE9EARsA97mm0zhqpTueTAWPSHiWTwT Yphi4UJdOKOV
IqggOlc6/b+DN6mRl8K1ykqL57xD5530UCuEfbUkFHC3c9enJw2GlwY3aLBY o+VbNDbTxeDD
e7/gf/TmnybYo+lrr5NadHbQv93lCpoBYsBIgAFN1UlWpHR/isdnV+z2BvoN 4wYORyhkjgRJ
cCMr5Rg0B6/CiDDV6ZisRApzyg7Au6be8QUMSm185SxgkOsic9rQbVSr3NcF Ahn9G9ceJwRJ
DgupXv+gmdVlBpldSpUl1HemQgaVxak0KRJ2UZXNiI1Ulnp1ThMPpigIMdsX aDwSI9l/MvUY
WFQkjkdVes5WqgoB9pOOETOgsjf9j6RZy+f1ntpEfSASDijz7/uP/OHh/dbH 4HylDtxLtQ7f
8H4VQp1TfgLupKXdi7b+FbD0uxAI+HU/FUAsAd61/Xw9dOXKytGah2RoFd5F nNaC1uQvUEsD
BBQAAAAIAHhpbzXjRyMZbAAAAG8AAABYAAAARVRTUGx1Z2luLy5tZXRhZGF0 YS8ucGx1Z2lu
cy9vcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUvLnNldHRpbmdzL29yZy5lY2xp cHNlLnVpLmlk
ZS5wcmVmcw3MsQrDIBQF0F3wHx50D75aLQQcOnbpkkDnYG5Amqo8bb6/mQ+c yxsrvcpB7Ijt
yDze7vScZroa47VC3FNtGKpggyBHtOGAtFRyYK36iY+8zpLip4UuP2hV96Vv Rb5TXzoCs7fG
O2cd2/P7A1BLAwQKAAAAAAD3eWk1ILXyYE8AAABPAAAAVAAAAEVUU1BsdWdp bi8ubWV0YWRh
dGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5ydW50aW1lLy5zZXR0aW5n cy9vcmcuZWNs
aXBzZS51aS5wcmVmcyNUaHUgTm92IDA5IDE1OjE1OjQ1IElTVCAyMDA2DQpl Y2xpcHNlLnBy
ZWZlcmVuY2VzLnZlcnNpb249MQ0Kc2hvd0ludHJvPWZhbHNlDQpQSwMECgAA AAAAqKFpNQAA
AAAAAAAAAAAAADQAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29y Zy5lY2xpcHNl
LmRlYnVnLmNvcmUvUEsDBAoAAAAAAJlTbzUAAAAAAAAAAAAAAAAyAAAARVRT UGx1Z2luLy5t
ZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5kZWJ1Zy51aS9QSwMEFAAA AAgAmVNvNazV
YPUqAQAAjQIAAEUAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29y Zy5lY2xpcHNl
LmRlYnVnLnVpL2RpYWxvZ19zZXR0aW5ncy54bWyNkl1rwjAUhq8d7D+UXM+a OFEv2klo0zbg
kmErdVeh1lCL/Rh+sUF/vFViN1wFyU1OznveJzk5xuQ7z7Sj3O7SsjAB0iHQ ZBGXq7RITDAP
nO4YTN6en4ydjPe1RCuiXJogLLebZa1bgzrXuUmW20SXcZZ+7aS+kstDoh9S fYrnzPKExZlD
3fkMB5QzX9gUT7krfGKd44tZx0j3Mtc28scEKr0QfEZdyoB2jLJDTUCoD3q3 4lbsFYB9T4SE
ul7gC9T49F9H/31UicNZIBh+J7/UKojWZR5V4wpWIWU2D/0KVV2E6vi8BhCq 3fUEqpK7FO9y
pwYxHMAHH0YWH5jZxBaM28RvDF60u6jP2y62oJQ0pHbgNboxfPRSbd3uNz6j ofo1o6cG5jxY
f/YnUEsDBAoAAAAAAKihaTUAAAAAAAAAAAAAAAA6AAAARVRTUGx1Z2luLy5t ZXRhZGF0YS8u
cGx1Z2lucy9vcmcuZWNsaXBzZS5oeWFkZXMuZXhlY3V0aW9uL1BLAwQKAAAA AAA9c281AAAA
AAAAAAAAAAAAQAAAAEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMvb3Jn LmVjbGlwc2Uu
aHlhZGVzLmxvZ2dpbmcucGFyc2Vycy9QSwMEFAAAAAgAM1dvNY4HgTXkBgAA 5CAAAFAAAABF
VFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmh5YWRl cy5sb2dnaW5n
LnBhcnNlcnMvR0xBNTYxMTQuYWRhcHRlctVaW2/bNhR+H7D/QAh96NpFlu04 ToS4hXxrA7hJ
YDntMAQDGIm2iUqiKlKJPfTH70iiZElxbPnSACsQJz7kuX3nwkOilx8XroMe ScAp8zpKXdUU
RDyL2dSbdZS7yfDkXPn44fffLrGNfUEC3Uh+I2DzuC6pHWUuhK/Xak9PTyqx HOpzorJgVpsv
sU14jVtz4uKa5FUX3FakAMuqyNtjrs884oke86Z0FgZYgMV5UWRRUdRgIQJs CVYwZOqKiuxD
FrhYlPyYz3BlRzxBFiLPzPyKvDeh8MOyah8HvHIIbuPNBfawKmvALML5nUcL xnPicVZVvRlv
jtkhqRC6BNx0iQiPKUUaAl4roL6IszMlXnlcYM8iaMoCJOYEWWEQQGogK00S SOIFsUKBHxzS
czDnHQWMyQxLjFIdNptBnqsyi1Xq+o7axZxaUpOCIhJxQWKcbr2AxL/7WJCO 0tC0sxPt/KR+
Nqm39NOGrjXKDF8LhSX1jcgjcTpKEygedkFQrBJl3hUkKChgDuyxUouirxXs iLYVtYce/RGS
q35HuR42m736sK712+f1er97rmnaxUC7aLZajaHWbygyElksJKrFaNz4JCpC b4bMJRfERVPq
EJSkw374J7xcNYHokBtzCAJNKe9VAnFjokgnSpUm0PPct+Mg33wR+Vol6Cdz ygFh2cZQyAlH
AZmFDg6A7AdQprAPIT/uUx5HgiFqgxg6XcJGiwU2CHSoS2GZ7xesTD1Xx4nq QaY567CvFDdp
AFpZgHImJFF0YQHPSIl+nHieHhjP8fPYJV19v9AkvFy9lTJeJQafiEcCaGOp 0gR1P/ftOFi3
DsS61x2g7AjfDd8UV+pFVYWdDPBpKo+rI2ZhZ8Rm0MVZIEBZTterxKHkXxKG aZFwnEicHx6J
qNtmQ81+yc5Sdq6CQEA+J++1AC+5kWDOioTjYG5sxfyylpufkiGr9mzKurQs vTBIl88Xspql
kBN5DN9z27kcveAYiof6qJ0+s1XbNl9IKyKzspHOmkdFJtK7R6QWZoyQhVzO G5F9IgiJsv9s
SDnrsdATwbLHbAjGnRnTRtibhXBEJEQCo5eLF9QN3SvbIRPqJmGDqPgYTtyr qAk8YkiF+r7D
FbifTBpFVwzE4wGoOFDtMEQksYLz3iLdcDolgUn/JZGdjVMlFjpkTKTUCy3z s+sw63t88Wsp
SCx9WE1GsdwgllkP9vuhDpcCCItYIl/+cR3XhE1hyoCsWCrZwlfshLDS1+8n t5Pbe6gmnusT
G6VFJkd/PRO2usmBOLVelJcAp5c9QJltJWNQqmaT3MtaFrQVjSz0jOPXDmo7 TB5x5WDq8RH1
SBeaz3eeFg7x7NtEYUd5A6nvWU5ok0GOmuyTC6bAgSgtOalQc+k+MCgC6F7E d7BF8uqm2OGw
mRcE/JOHE9BMBoZdDvpC1sTc+jh0yCBp3WC2Hb0FSDFnLyNEeW9OHbs3Z9Qi mbWUj8mPEJLE
7i7BNpCYLcmGz1yXeXBpI4PHqJ/kzNlsUKve7F30QHfbWG9QIp+zMLBIdmhe 2UUNRR2GEAF9
CAWBPJni0BGyNKBS7NCKml1eeV97WflWv3MdFBL5NiCPFNryFyysuRk+cEFF GGW9wfuJJSl7
bX/zk6ovulA/hgtX9gT62ys4MiHYtUh0VqCBB/MDgSHZm5V9ahzDp1/mUdHW 5gG2wgEjXzV2
MrNkJdiZ3x4ZC0cYCIHm8lZ99wd0nHQZdMq+hJ6omCMoLSRvgih5TwFDuiF1 YAIZhp6Vmy+e
YVNbB84eAJ4eAcA9Yv1/B7FYV9dGuYZaB8AKrvaO0t0K/sn+X/l8OO0b3fNW G/zobjwfwJSk
ijbgVpbdbg3P2mfGNtljEl1bzZc0VIvN4K/JYHxtjJSS9u7L2rdGCCYKzjxo nabFDm5z1dwY
3Xwqe9A7yIP4RQCuf7N4MD6sUW/Ns10S8XmnSman9qbZaduxJO+70cXpsE61 oU/d2+/vv2Uf
HD50+RNT/rjn6rtiI3tTRydaO7rFCTAseSjpKEv4d/Lly4lto8+fddfVOf/T NE309/rWtrXy
13e2zZB3jWaz394wCcjqh9t4QMWuCVQZ03szAjL6eNsfdO8+/by6Ht78nIyN 3mANnPHdtyJC
FbV+M8bXazQ1j69pMB7fjNeoah1f1dCYGKM1qs52UHVwhjUuzobnjcG2M8Dl s1+fXPFHVKX8
/fNp4039iKhs7ITxff42Xl/Rpq7QsyfUja/H+72JgsrstbAofvVYkXtO3OER UL7ajJKnSmMG
rq4E5TF5+bEFR0zrX1smJpKSUSy6+N7CfH2t3mhURZnUzWLicGSckhwTS++E 8VK6sHqXBPJl
rfRfFT78B1BLAwQKAAAAAACooWk1AAAAAAAAAAAAAAAAOQAAAEVUU1BsdWdp bi8ubWV0YWRh
dGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuaHlhZGVzLnRyYWNlLnVpL1BLAwQU AAAACAA8c281
EF5lwpUAAAAcAQAATAAAAEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMv b3JnLmVjbGlw
c2UuaHlhZGVzLnRyYWNlLnVpL2RpYWxvZ19zZXR0aW5ncy54bWyzsa/IzVEo Sy0qzszPs1Uy
1DNQUkjNS85PycxLt1UKDXHTtVCyt+PlsilOTS4BKlHIS8xNtVUKzy/KTgKq y1ACynGiSfrk
p/sllmWmJ5bkF4HlOW0yS1JzFbJTK4GSnn7e8X6OYZ7ujiH+QfEh/vGuLp5A lpJCWWJOKVB3
WmJOcaqSPthcfajBWCwJKUpMTqW+NchsAFBLAwQKAAAAAACooWk1AAAAAAAA AAAAAAAAMwAA
AEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuaHlh ZGVzLnVpL1BL
AwQKAAAAAACooWk1AAAAAAAAAAAAAAAAQwAAAEVUU1BsdWdpbi8ubWV0YWRh dGEvLnBsdWdp
bnMvb3JnLmVjbGlwc2UuaHlhZGVzLnVpL2ZpbHRlcnJlc291cmNlcy9QSwME FAAAAAgABnJv
Neq4+FgrAwAARCQAAFIAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5z L29yZy5lY2xp
cHNlLmh5YWRlcy51aS9maWx0ZXJyZXNvdXJjZXMvZmlsdGVycy5maWx0eG1p 7Vpdb9owFH2f
tP9gZc+NgW7ahmBVoalWqWu7wj5e3eRCrDl25BgC+/W7DgRCoR8SFFbIEyi+ vj7n3uMTW9A4
GUWCDEEnXMmmU3UrDgHpq4DLftP50T0/+uScfHn7pjGKeP33twtiP2fhNRuO CWRSx+dNJzQm
rlOapqmror6rdJ/inFlIshiSHmcRtUqlimGXHT+EiB1xmRgmfchnfeWgmfbD sTcyIO26yUIW
8AWPE8hShWMWQEIjFYBIaJjPPILZVBdx5pnBVxoezAVRz0KrUc+GOVgDQhor wNQ7PIoFdMA+
/z4APSaSRZgXk8wSToC5RjMf3CGHNHFvtOpxgWU+58KA7o5jQK79EBJDqhVy xxIghkdQ73Qd
ErGRJyACaZB8tTJBg3iUDkC3EE2sIUNDVIwIjdJN58zrtPNAG2oHZECwC3WD izWdh8lcT2Ln
s3F+D5gZaCjMz+pX906N0fxuYLBjoYbeM5szKQV24x2l3dv2DfP/sD5QS7uL rB06R06n0HPS
dIn1pDn0Wd3ZXSNPz6astri6P4gGghk+PEQxzcnvl6TuN3UnwmJCHJiakHGy RyKyDdyFcowy
TJCE/z0wN8p4d5D2/mio0MrdKSk/MCYHKKeLnPu+aWre1PWFZWITuzG+MHtK R65Q/SmQS1WE
0AlVSkBrpQmGEG17FqBKpBhbYeXFTEPQMKmkRfCESHAJjkY7j3cKsju9Oiuo jun+IJPtOimv
bxeU+NycLS6ZHq9O2fK6vzzvqpgXMwvomev19kmWZ8N7xb/Ld0q75bVVFCnZ wvO3N8Qi0ATw
4srNuLBXMgy0QGZxRKMs85GnarjIk2iW/mRigMEfKkush3bEqu5xbotXUCTl oUi1WcK/APMF
GHzcGYMGnUm44G/3nzXovV25PX9b31u26m8p0xKdt3S40uEmIxvxh+NX73Dv P5cO94LuslWP
49LGMGO9q/S50ueykY24xKu3uVppcy9tMDs5ztm9u3S8LL2u9Lry1roLBqvM rtR1eVcp7yr/
311l9avz8be4/TXZCjloK61BZCeBDUDyp9kgWHlv2d6x4jEg08o06PQPQfj9 H1BLAwQKAAAA
AACooWk1AAAAAAAAAAAAAAAAMgAAAEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBs dWdpbnMvb3Jn
LmVjbGlwc2UuamR0LmNvcmUvUEsDBBQAAAAIADxzbzVHC26lTgAAAHMAAABM AAAARVRTUGx1
Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5qZHQuY29yZS92 YXJpYWJsZXNB
bmRDb250YWluZXJzLmRhdGNgYGBigAA2MMnnFernGRIfHOQc7+Hv68oIFGJk 4IIIwgSYGNi9
glzjfTydQDxmBm4QD6gjyN8/BCTCwsDj6uzjGRDsCtfCCtECVMQIAFBLAwQK AAAAAACooWk1
AAAAAAAAAAAAAAAAMAAAAEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMv b3JnLmVjbGlw
c2UuamR0LnVpL1BLAwQUAAAACAA7emk1OksjByoCAABMDAAAQwAAAEVUU1Bs dWdpbi8ubWV0
YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuamR0LnVpL2RpYWxvZ19zZXR0 aW5ncy54bWzN
V1Fv2jAQfu6k/Ycom3hAmtPuaRIw1BWQmNoKiU59rEx8gIvjy+wLJf++TmLa UYWtD0D2EjmX
833f3fnOl25/k6hgDcZK1L3wgp2HAegYhdSLXvjrbvTlW9j//vFD10JMTiXQ PIFeeI9mNXN6
y9B9O3vzEc2CQaxkaoE9CmKZZFITGM0VS3m84gsYblKFBky5/awrCZJgBXkv TCABTRgGa64y
Z6ulqLNDsfU7Q+o4ntXilWz1XjKulv3WgjqtT5vzQfm87BS2PD54/EDae6kF PhUOOStTIG+I
TAYeQvEcs638qxfWOOltW6akXhGCkITGb9vSNYh0gwK2fnjx0wv8bRHCSuqf NV7EmSVMRlK5
qNogs2AGMJcaxIRTEWg71HymQHhDc64s7Lfmwuu3e4u1kEupRDAvFcZbwzVB mOwmmI0kKGEr
w95ZuZ9edEDoh7QKxshvfGDtPQRec31IfHaNMVd3eQr/h/vtz20WK27taaNw i3qSzZSMjx+E
ly5TQ2OYpJR7YRPpYNdyZrjJG8F2OfjJ13xi8NF16kaOI7tCTbxoMk0GYpyk aGjgtLjhxZX1
VxZHqogpOei4mSy4kzBdcuNuipOdhX9W5VhrMO8pzWPlI9e0BJeSG0hm7vpr goOv0KEq559m
ClShPeW5qKOQXWpxVdxRDv7IbToVUFD4IbVrRt7rCvHixF779wN1pehd41y0 M0LWarwZlQud
MCrH/cjP+8V/wR/rZ1BLAwQKAAAAAAA7emk1Db3W/DwAAAA8AAAAQwAAAEVU U1BsdWdpbi8u
bWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuamR0LnVpL09wZW5UeXBl SGlzdG9yeS54
bWw8P3htbCB2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCI/Pg0KPHR5 cGVJbmZvSGlz
dHJveS8+DQpQSwMECgAAAAAAO3ppNefFcb9FAAAARQAAAEwAAABFVFNQbHVn aW4vLm1ldGFk
YXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmpkdC51aS9RdWFsaWZpZWRUeXBl TmFtZUhpc3Rv
cnkueG1sPD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4N CjxxdWFsaWZp
ZWRUeXBlTmFtZUhpc3Ryb3kvPg0KUEsDBAoAAAAAAKihaTUAAAAAAAAAAAAA AAA/AAAARVRT
UGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS50cHRwLm1v bml0b3Jpbmcu
bG9ndWkvUEsDBBQAAAAIADxzbzXuH56OSgEAAF0CAABSAAAARVRTUGx1Z2lu Ly5tZXRhZGF0
YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS50cHRwLm1vbml0b3JpbmcubG9ndWkv ZGlhbG9nX3Nl
dHRpbmdzLnhtbH1RXWvCMBR9drD/EPJu3NzLGO1ks5UJcxat7KVQsnqtF9Ok JKkf+/VLq04F
t4cL93JPzjn3xOttC0HWoA0q6dN7dkcJyEzNUeY+ncWD9iPtPd/eeAYy6yBE 8gJ8+qn06svh
ltTtWp5AY8kKdj4dFqXS9l3lbBqPJ2E6Hc8m/TD9eBmF03QYNPCWhxYKsuai clTBU5KtV0kc
xVEyfB3VlUZaWZVGXNtuUuWmqRh4kYG0oNuhzFECaOeRdq4yQiawNPDAugls eVEKMH8gG12h
8n/3qrJlZfcIr1Nf23SXmSids4Mus6UtWaEkWlW7ZE6gQoa1e8kF2+A313PD ftMaoIB9lJ0D
6RUBRxKA5ShMgNwN52E24Zul2vS5hVzpHT3esODCwPG400ctUDgzb26uwc32 8na7K4GgJJw4
KVJPhuwfHclOQZyZPu9/AFBLAwQKAAAAAACooWk1AAAAAAAAAAAAAAAALAAA AEVUU1BsdWdp
bi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UudWkvUEsDBBQAAAAI ACaEaTVjdNP0
RwAAAFAAAAA/AAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcu ZWNsaXBzZS51
aS9kaWFsb2dfc2V0dGluZ3MueG1ss7GvyM1RKEstKs7Mz7NVMtQzUFJIzUvO T8nMS7dVCg1x
07VQsrfj5bIpTk0uASpRyEvMTbVVCs8vyk4CqstQAsnpQyWBbABQSwMECgAA AAAAqKFpNQAA
AAAAAAAAAAAAADAAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29y Zy5lY2xpcHNl
LnVpLmlkZS9QSwMEFAAAAAgAPXNvNYywglMjBAAAkhsAAEMAAABFVFNQbHVn aW4vLm1ldGFk
YXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLnVpLmlkZS9kaWFsb2dfc2V0dGlu Z3MueG1stZlb
c6JKEMefd6vOd7B8h+UigimzW5wELfVEsmqSdV+sEVqdyE1mvCSf/qBGgwlG hNEnq5z+9YWZ
f7dM9dfKdQoLCAn2veuiyAvFAniWb2NvfF186NU4rfjr5z/fqwQsGi0peMiF 6+KTH06H0bpJ
MfrtW9XBhBam8HJdxB6hyHHArgGi8xDIZsG3KqbgFhbImUfGfjjmUYCsCfBD RPGUD+zRlciX
eYFfSIJQFsqizImSJHCCVpIkTdJkhZNLJan44zQsFwgsBwcEeHBHvO1bVxIv vbMkVRQUNY0p
WH4IPLF9NhDiz0MLcnOyAnK5z2I2hsipPb2SD0zLqcy2sZ5vea7Js00TnQkV l6upxJuJoxVG
3N/Sn/sUqPwMcDclE2McRRYGnRuJ42rGnXavafV0lG1SiaC/iDRfm014TQHK SyA0Iijxokiy
IHDTJ84cvJCbzn9NsmrSU5jAhqOPafMpv/5pRhG9NmcpUPkZDqIjP3SPxqSP TVh55YljPJDF
v2ZaXm5QaAVHY+o+3rbHj2Hbn3B3UK+nQOVmfDr9a0a9PSv7v2ecCoTra+Ip Bg1owLu+h6kf
Rs1sLcU8JourUpwrSuK6J8T6g6zKehb0nEB4CTaskBs4QC4V+45/CXYQ+iPs RI8TwmjC2G2w
Ei/yohBr0aIiVvKhk5l5ww8h8EPKD3FI32OPFylT5DFqEo7jpPtbLdLre72u 3+n9c/HMAk0O
bmC63Z7ZM+0yklEnFXIveshDzgvBhI/GSwhhgWHJP6MFyhvzSQfJqYj1iqLU lbqqq4Z6l9ET
eGPsAfsMttwLBs464uRQ5X5D1/t637gzHozpeeTN3Pqlau8LcaPplWZG+nHh zlPn7dCdVGNF
iITqfFgSheNuZsLQCqwgaLu/vTOpX5ZWNnVVNVWz0ho09DPP+ZdV1XSr1TJw bdToN7Dhn0e+
SDP8RGdPdig7kYtY7GUhaqdDmGLKfpT57IJVIXZA9sqTbm7Rzj/IJ6YWbXuo MwwAew8MZ5Yk
Jvud9wY/UuMMYrkFJpPy1Za8iQ+rupJEuck+Bb6DKaKYUGwhh5/j/HP3EXAy Md92oCGy2I1T
Gxqz+lIglPnfyD2UqepuqAy14COPbU0/HaysGzVOO7Y7s1aTRQWp7zu59eOd xPQpJMNKk/bt
7eR20ug2rMYyHWxzhFluvo9Adnkfqk3mbfcmMwzUcHnkvedDqVeRpJdn84nU W8rJ7FbEznr3
sDbN/so/sj5uVv2xvijafDu8TurA1mMbLfAYUT+M3xpt7pV2K9YXT9gbd4HW sEOj4azbMzvG
4MnstBrt+qBr9Iq7sPTxOISIBoWoFxSW2LP9ZUEUy7JQVpSSrKjaQTIHbh4x LPfwrtnpDXr9
e2OPFnf5vKWRkFK8KFEPXr+LIJuR1QG3+NE4/v1/UEsDBAoAAAAAAKihaTUA AAAAAAAAAAAA
AAA2AAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBz ZS51aS53b3Jr
YmVuY2gvUEsDBBQAAAAIAD1zbzVMIIM7AAEAAJ8BAABJAAAARVRTUGx1Z2lu Ly5tZXRhZGF0
YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS51aS53b3JrYmVuY2gvZGlhbG9nX3Nl dHRpbmdzLnht
bH2QTUvDQBCGzxX8D2HvTvTmIbGEZiuBakISqXgJazquS/cjbLa19de7SSp+ gF6GGd6XmWfe
aH5QMtij7YXRMbmCSxKgbs1GaB6Th3p5cU3mN+dnUY+t85ZAM4UxWRu7ffa+ V+K12S8xU52x
jh6GmozC6JpFwqEKtnj8aSkYR6jqvKRNRVd0UdO0ye6KvKybdfaUlH5KSbBn cud3G8sBWym6
HsF1rgNltHDGelyQhu8ECO3QaibhTbwzu+lhurUyfCkkknBCkaJ3/6LQxyK5 T79QFklNb/My
o9X0zOmbv7A6ydyLsQpa5pAbewRnWYsgxmufFOGAMSYYniIcov7WfwBQSwME FAAAAAgAO3Nv
NUFBJp77DAAAflAAAEMAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5z L29yZy5lY2xp
cHNlLnVpLndvcmtiZW5jaC93b3JrYmVuY2gueG1s7Vxbb9s4Fn4foP9B8C72 YYCRL4kdZ3cy
u27tzKSbpEHjTvdhgICWaFuNLAokFcf99Xt4kUQpki3JSveCYjCNRJHfOTw8 OjdS/vnvzxvf
esKUeSS46PTtXsfCgUNcL1hddD7NL38ad/7+y5sfft4S+riAJ+u08wA6Zx5N 3CePEdqVjV7g
kq21xt5qzS86ZyfjjrX1XL4GIr3Bacd6vugArZ34V/RfIsZ/9/B2ijiy4ptr 4iCuGBNjJHAI
5EPscO8Jv0VUtHgcb+69r1hA9kc91a37sp9DiL9A9BrtSMQtnziP2I3Ji2dX gGN50LSiJArt
pefjjiXA57sQX3Q4/PureHKD6COmikxmHKErGzu+FzJsR56dyKUQag4jgbF3 JODUW0RimlIo
52MplcGggAByXU90ZM35cvEiWgnufBSJJXME3j3mVdkTAi7lzyS03iEXM5tT 5GAbP2NHYohV
rU3z5LwByZASIfZGBMfDBgQpXmIKy92MZNU5fnG5WL336AnNfLzBAX9HsXxJ apPcp2kZkozb
W2Y7oHfRJlTD250Uw4jCa6L+1J7HaFCNCg95aIc+4ktCN7ZPVvYTrBSzvYBj GiBfNL3q2sG6
fQabAKYVwGtTGVac5haWi2EKZloQTCa3xYsFJVt4YqM2J6iMZYCeWrKVgOSt EK9sL/vjk0PM
YbCahNbjT41cYz9saV5FUGVz+qkvpwR/lC/LeC7pBNEKW2i1oliIKlWqK+Bg EjdboOeW9sP9
/uikNxoOT0+GZ/DaL4kTMeCBRiBnHy2wf9ERKCwES2b9ZN1J4wmYFgpc65qs VnAtHaWSJUsv
J2B+LCT9rEBYEPJ40ZniJYp8PpM94mY53guWxAoR5fs6LYnvYmqhMASLgMCk wjJDXPIcAjfC
Zw9kr5BiBvZPGr8i2ZvPmXzz5ErcGc2XwDihOy1mRVZeCjblRTpJ41ZOXxqP +GK/a0heQuDq
bgrC/QKByew59AkFJZLiuEUbmGUq9xsSSKWNCdwDw1ixKW5L6Rr+wSWOMGcm vm5W8y0cD2OF
oSc+tt+pv3kM3VybM0BW9laoOyzAh4jDTLEJHTfVhdbCFibdNHnalBBqgwbf xjcmQWi30gcZ
suKGYR9LWyl5mP3rbnI7fbifT+Yzqf/K/1q3k5uZhIKwbKkU6mpayKDJHDDr OchXOicYFHeX
8i6rlXmy3QyLlbThnkTUebGQU+gFr5e0OuUKoSHukPMIRqdQadUjK3mWkaPl sc/SBqVWKjU8
wp6J19kqoBgqWFhWL3jkRL15MmmghPAb4iqrsE1gFTcqnI8YJ5tLzwdhMysC pwfGBjTLvUNc
yJ/NArTwhSlZIp+Bwv3lT8+9yd9+hmRId9Rj4wfO2vNdaykbrypJyL70sO8y hQOGP09SuY7a
sA+hmsGlHvNg/5gBl5JtiG2LfMsX7un12f7xzz/aoH6Mtcf9LQnuooXvOccx nzHWORIziH93
urFtEdnX3oIiumsdF+Qi7L52O60vrbTnSLwzrzWBq01IKDfMVQGFozRHGCrP aV8yIPn7NaJg
dlqR/UHNvAoCTMvV8zgZ7QK+xiCmG7xZgGVsG19rqU5q21dSn7C21qEIPpoE 7jthzwD6CNMQ
ujJQeusF8CJpbhVav0Vu9X3VN6r70i2K1oyTbRiZCGfzm4epSPx3ZlCRNpaH JgcTenV7rdL6
bNAiIj/RCsnObH4v/hcAQozYmv71j/nd/O4PaGB/6CfNw92PmMnwqzAALQk+ reur238+3E5+
v/p1Mv/w8WH+4WE2vYIrGf8wsIaYiuhHDFrqBdCRirq1dHB60Slys4b25Lvb 72fz2cYTzrrM
NeeHrHBQsWcuVjHY6C5TNYrzvHhGcZwNIcT6otOFBYmTIzk09xgWdgJrv/sK llC9P5pCAvvG
COwP0ujqLFXfPoSBN9r2znsP8B9kd074vPE0gRS05ruQqAowDJLZ5AN13cxy OuIQP9oEn0VR
vQdB9PCkYzb1Lzoi0zdaBqAxuU4nF51RtuVUatiaUO+rcOv+HWGy5CybnzDl Ik0xG6UJkuM/
UJG0G9dXIG5Z5u8e7tSv0mlQpdNJlU56M6FkleSF1EVjF4HpKsedLF4ckX5q mBS5YuVAthjD
OjkGrbRW8bvHPFAZmSAtvWe1z5Hu3PTsXn8khwMlh3ohDLOkmdgfdMgwMiUY 56n7ihAmv3Gl
SbQr+SN/i3bsQ1q7Liw+i2qmj3lGuKqGKYsJQivn5DNeQE4Y+Vi4lLS4WoNM rsZdcSQw5awx
4myNMWdGbbXi+JLad3XqYtVtjp95StsmIQ5mz0pUIiA5Eg4FAVEFM63G9eRT BBm0BeQoBbiG
6GSKfQ9cF2jcnNRB1YLihPjMjsUmarOs3kqkTD3iHYRwYhOV1RhftDlQdXTo ghETIIws+RZy
jk+ypTL5OrsGFSFLtxqrvpOpFTlmbOk2WfWF0Vpf36wkItC7kc0BFsD+Y0hg YRrJIsF5P51P
xXUjlC8RBEH2+0/wb/OZIBGdMY/lENiabB+E331Qila1EFlrcDbdqDXUqKHW GmdW4qsN1B4h
iQrv5X0NgKi4hl95sCKbK9PXHG2GsjWHvkyYagLMEXu89lhVxTJ5XlHMWA2m UcDT8ZOA1xgq
Un0aBdzb4DhFVSMDGLP1viLqHlAt1YnZt3ir34rYyH2WT5rDyUpGW2BXwpks IXZtC3AWRJu2
sCZJaNMWojIUaienNczAC0MsKkENhWjAQWdb7To1HZwElJWG6i3TBOITqDyH /H8OcZeYUH3Z
KDdkiGeOGX+HWKFsjASpDLN6xlUVsSQBqjo88ZXSVR/JwFsRv0FY+QJGGKda XnbfgALPWti9
3EHsQ3/hRPd1znvq/XwUuTm1MRnXhjbIC9QWZtwiDzGodyjey1RHGny85Mlm YnyKwVFVgxXO
7wqXyDpz7mGQO/egseUBEEexXg1U594vNmuVRh2Cy9VpNVhuwctR9vj2GOta /Lkl/JJEgVuF
K2UFADDyldvdh9TeUZF0BagKcnsxs/o+PrRjYsqGguMlpYqU4y8xSmKi9xzW 8B/9k/Nlb7Ho
WLKAL2o6Z6fnw97gfKSbrkEXLzpnw1N9/1GdxB2Ic2QU+2quay+UOqYaRCmq UIWPUUhx8EnM
4Tf4e3Cd9mlQIgS4oOTpGCizYqPNgGi5Fy3fUJe6e/WiUBO0N2XGug/Uup9n 1n0w7GfX/Ww4
PLzu3b1KuSCck42pccMMzWG/l6XZP+vlaZ6aNMvmVtmCFnqT49S1GDK2nnEl vprVzJzCMoqf
yRGsgwjmyR0N8OLYTjnInkyy8ZtTdDisIZZi6i0hjxtEH1uAyiRw/13uILkf fBv3cDZwzhJX
oL3DaDTOGonhaJR7YWWHciPR3gubPwTYzjubR9UqkAnuymEKk/n/rBpVUpOu EaGKWz85J2x+
BSM53r9b1Dtqt2jfkVdzF6h5+mWY4eXL48lSYN93lL7vKB0J9H1HSY7+vqNU TLvpVk6VD+Ka
QJV8d9YEqvCbuYpA9b+uksAHy+Q1PqSoBlgSxFYerKZ19CYFMA/emO9kztlg cM3dlXpnVBos
jWIMuSgE6JSArjfJE7aMezIXqrxUtQ/4SdijquH/E8VdsKxfBhjb7wezWbWy bt23qBDkkPLv
o1xH8cqIl762hQOaKU8aO2eD6tJUjJPwWpbM3vxwOP2pe1JsT1L0Zl8mU+fr sxcxdeZ05VE1
3dy6HuS3qlzilCzz9ZYi0WJK9uaHF+nY62b1wj4+7tTOoUzIWy/uFilrYx37 P6vrHl2HHZ2f
DwcnvZPMEp2e5muiL0ssp0VL1D1kdfIaMhif9U/Gw3G2DDweZ8mf9feXgWuZ s/oH8BtrW4n5
j9dTt1W0MyyORpRRXFEUrpvrXZUw6B2BPKggDno1grM4wchRHLweyRu8Abv5 zWaoP+V8bTL3
4BJ9/I2I3WC+Ju4Uc+T57LWJfYwTx7n4HqMFatHGHzDXIGrPxeX9tLl7qG9h jNhANFX+vqei
5XBFZ0cQlMeaVIT+TTccKoQlx4Uhapsv716yfuVEBhqGX5F+Zq9XU4BtRB5J 5Jkc9Dt62+jF
Tt9xAcIeP8OizQbRnXI3aeyQ3UkdjPMbM8PTavLdHzaopZUO3qCdJT3KxZT9 s1GlgKXVlc1W
R44xSrk1EF0p8dkhd3/cPot5L78jSn+lgEn4tFj9GzAH77VsVQlA8j2SuVtz dSNPsRMjWq6a
4hefYuvmiHlBGPGy368wo/QNcbGfJH3JN0D6y7mOxeXP24xjSwTrEwtA2jQl P/On4pQNfYuo
2cipt0l/70bcyR+aKRZDfzDuxN3kL/EclpY5o89Z3mzQaOBGTyAmXYUN8SN1 NfjIsXGpf/Uu
oV1jOl/E+VpdUJefs0dM7F/coADkXx/OZCvUm+rJ7vpHvPLiTZaMeLrZRetu k1dlQyNhp9WQ
RBV++TdQSwMEFAAAAAgA9nlpNRM7lD2nAAAA7AAAAEUAAABFVFNQbHVnaW4v Lm1ldGFkYXRh
Ly5wbHVnaW5zL29yZy5lY2xpcHNlLnVpLndvcmtiZW5jaC93b3JraW5nc2V0 cy54bWxljk0L
wjAQRO+C/2HZu7GlVj0YiyCCB08qnmO7hmC6kTVa/fdW/ADxOryZeZPiVnu4 kpxdYI2pShCI
y1A5thq3m0VvjMW025k0QY5ttqa4MmwsyW8IxlohayJpjHIhhIMpY5D7cq4x iFVUenc6k7o4
5TiSsPFq960vXjCCN3vyGneOq9DAG4CWQGBTt+Ozzw8cgkDz4tJ0mCXDPB9k +WiM/ada/1/4
AVBLAwQKAAAAAAD8cW81AjBHFBoAAAAaAAAAHwAAAEVUU1BsdWdpbi8ubWV0 YWRhdGEvdmVy
c2lvbi5pbmlvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWU9MVBLAwQUAAAACABG cmk1TTTAYucA
AACeAgAAEgAAAEVUU1BsdWdpbi8ucHJvamVjdL2Sz2oDIRDGzy30HcLeo+mt B7OB5s8tpbDJ
A1idbA3rKOqGPn7UuCnLUuih9DbfN/P5E0e2+tLd7ALOK4PL6pksqhmgMFJh u6yOh938pVrV
T4/MOnMGETbghVM2xOnoPjDkGurtoXnv+lYho1mnhjBaA4aa0aFKbjnFZ0FH 6qNXnWwsiKSK
XMcoR5mdwjKuJSA6ZT2QswxEGBcLfuE5AO77CjHBXdsnti+ajg1GJ5Rfca0E sueoTuDD6/9i
G/EJmv8JtDjDk0de6B2U6ZuY4G9rfsvNRM9DPwVG68FJZqgT8f4Xxv/rClBL AwQKAAAAAADr
em01AAAAAAAAAAAAAAAADgAAAEVUU1BsdWdpbi9iaW4vUEsDBAoAAAAAAOt6 bTUAAAAAAAAA
AAAAAAAYAAAARVRTUGx1Z2luL2Jpbi9ldHNwbHVnaW4vUEsDBBQAAAAIAOt6 bTUZ4TBp4QsA
AOQXAAAqAAAARVRTUGx1Z2luL2Jpbi9ldHNwbHVnaW4vRVRTTG9nUGFyc2Vy LmNsYXNzpVgL
fFPlFf+fNG3S9FLalFexxYKAbUobCihSoFJKkEJasC3FypSmyW0bTHLjvUmh burmfMzn3HCb
sKm4zaHuhQ5SIz7YnG+ne7jhNqfu4Zzu4ZxzLzfdOfembSxVi9Jf+333+845 33n8v/Odw2Nv
3X0fgDo61QEbYZqaMOKRZF845vV1tPu1vk0B3VB1B+yEKk3v86rBSDhuqN7+ wUBINbwRrY9p
+7xxk8zwWuSEwriuhZLBRCcvhrUYwe3fHhgIeCMBJm5P6MyzfJSqTY2oAUMl OA0tqQfV5jWE
KXFdHQhrSaNJVwMJltERjjJFYVQ1jECf2qQlYwk5iZoJJZvaNq7Z3NSxrdPX 1t68sXXbBl8X
YVKTFjMSgViiMxBJqk5MJkweQ5jF2ubz+xrbfcLqhDuLNLNByFsRjoUTDYSc yqpOgr1JC6ku
5GC6ghJMyQehVEEu8mR2nAIH8pwoJygdmzo2+XYGovGIasje8QqcsjebAPk+ QeHB5JqnwIUC
PtsfjqmtyWiPqncEeiKquE8LBiKdAT0s35lFe6I/bBBm+McPGju4yFAT7IXe cF9SN53I1JVW
JJKJcMS7LmD0J0TYcrHI5dsZVONCZjhQSzhpAgEfOW2EV1yyUIEH1S4swhIH FrOXxzlSwUk4
mZ3ZpyYI8yuz8LGxZ7saTCyvOnrJgVPYqLFIcqCeMH3s6upkOBJSdReWYoWC leDAOQYECRt7
3/+8DERdWIZVEt5GwtTKo/erOp1oItgqOoXSp2AtTmOgBOJxNRYi1IzHctRS RtHlTjCUqU0k
bVDgRwvfh4Rm0fB9qBxHP0JuwsLC1HGjSsg3A9Wq7mQn11dWbfW/R0zVATWW MLzBHtXbpEWj
Wmw1X0qfLLLj2wmnfFBuwfZmBZ2CbVdA1wODzbGQulOWz1DQhTwOTTCpC+ol XFsVfESst7OR
UVk4W8E2dLNjI2qsL9Fv3sBm2ehREAQ7Oi/YH9Ab2UR7ZXNVk4vl9irowxS+ SroqtzYciITP
U5tW+4QrrGA7zuEzw6KFwEHYTIFR2eJbklvZnFmJKzgXnGfyjWSPkYnFNNk9 OhpOsAYFzbFe
TY8GrKuwFAMKdmAnq6iemwxEjDE4GobemeKL8xR8VPzszOQ4owDn40IHLnjv q/jujlfwcXyC
VeIs0M5UejgxKLa2C2w/yUb6dF3TnbiEXbEloMdYmLjuMgWfEouLetk/2dlX 1LlCwZVyGyZL
Zhmzd7WCa/BpQrF53rlJNRbMZDE5dX1Vp/jjM+LPz4obxnOhiLlOwefkiDwW 02L0iWe+oOB6
AU9Ri+WZRsFQO0dUNvco+KJsFuhqUNND5ssgdtyg4EaBUT6rGWoUcDmxl1Op aXWF3As+sYK9
WOtCDVY58RWObKtWYYkxKnaoulrRy9JCsx24ZTiJmdp29OvajuEkrEbj/Nhw cjc6+gMxE9ms
aZ84h/P36JLTGImBEnzHo0Zh1jIxKnOqf5yjTN98W8F+gbVdQC3G36ngOzjA Ek0UrA0EE5rO
ByyZ4E31ZXHxASnc5cAQYdGxcytI425CuWkZP8/RuBbj3eYQ/wn3hoOZ56eR 09iEsTyeCL5l
97D969lBBbgPhx24n7DyQ4lU8F3B23TGm2+nGkzKmi82ENa1WJTp5JgHFHxf aBTzQc1IceIh
jmrLoPUACtkjCh4dvh3tyZ4syscZn43xeCRzpBD/QMGTQuzOltkc6hiMM1B/ yBl/nWmI37Kj
3SoghPHHCn4ijEXZjMImgPipgp9JQi2ISMWwTjNYpDA9o+DnwiTJQIoJ0ULo f6ngWaEvzqJf
ayYw4XpOwfPDBg1zyUmCxV8r+A1+y3qKsWbdlmUFYXXlhwx0VacA8kUFv8dL rIEFrPZwIpmB
0uIJQ2mEyYT4ywpewR/5llkS29S4piey5C6bsNwxrAzNPzMgmls7fG2tjf4C vIrXHPjrhLP3
GHEK/iaul2zaxuWxJvm5PagJOv7OT6B/42lywj8U/HOUTAQ0sVF9fCOd+De7 bYzQAryJ/znw
X4L3GH2n4K2RxJ85oTUgif9NvhZEZLMAOUIvMOGaYaIoeAefGfvzya5QLuVZ ty4rQEuOWaZZ
3hYbY0DKXcapHxKjksp7skFZd8yqcQLghaNQuPQDYtBBhYTZQS3qDffwbzDp TXDxx+dJ+ljD
gbMut5OK5DltqQ3VDg7WnnNObTRaaxgumoRVDioZLqdNVjO9bdKMsFnSkJum ckVM06yqqZNZ
aIZCpTSTCwqz2OR0PE7d638XgcMFsVm5in7LnVTGj+0g/6tpaakJhSrWrauP RusNw0Gz+IU+
unzu7eUyn9WoUGg2zeHCwSrACHMrx8oer8ancn78aR4/wx08pxMVqqQqLol0 NR4JBNmcWi73
JlbIiyasfzVz1y40/4nEGu4LiPupBRNsB0wpotYGLpe5g9UTmQoi30ho8czc FRqJJbeQ/vcN
OOPMLiwc9bFOkRbyXbRgQ7g/k3vupGVc5VhSK4bbfBdvZlp8J63gEzrrahfy svUcrA1LMVOc
3ZPWyjmYze9ODsAtsk0aZp7ZpF02R2dmzM+M3BDzOBMKf7MC5lohfxdlfRcz N0kTzn+n8koP
r3FzjQrPEKZ56CBmyJ+ZHnfZQczyuCsOYo4n5yDm3mFyz+e/s1iC/LWzbvmY yydUsrQFfI4X
x/P6ibyrWDJ5p4pHkg6XuRfw3M5fNebJT/HcxuOFnuoheD3V7sIU6g5jqahQ 7S4e/pjpOYAZ
D2ErDzMfwmLPISzr4vmsu7B8CKe6V6ewRih4cK+z5jN5SGE9678Pc9+D3qIZ NWwOOxSoZzev
hBsNbEwjrzexumtwFk7DBVhvGjfNUjtjnMxasZHNImzC6WPNtL1shY0epMNo 84svO/ZRt4d1
2JLCmQexxZqddSNtkFlOCoGiE/ZSg3zYMx91HBxVFopWpNC/0pw1lKUQManK 7N3lKWgsrd5e
ancbKSR3cywPYJB/OxYVudL4mA37UM+bF43dXJTZLOfNi83NktHNWeamdTAf EXnHyWXlQ7i0
PneEujQ3jctN6jmluaak2SN7nq4DmHumvZuBtOuSNK7K4RMLTVx5SnMFYiOE fEC5vTuFa9mc
NHaxPGbtEM4OIeDfz+/FdNONsrNbdnYL+/6sT08KXxLXPvzWHmHawy2POH8f Fsrnyn2YJBxl
1H6xjcpE5M1vvyYrTFHYcgg1Xe6bhnDz/by0ew8mmQtfloXq/XLLaBvtw1ep m/bJmAHP7Yxx
cNueizP4Hp7Nty2AGQhhBffWqxBm6GzHZkShQuOfOC7i1u4q6LgJBm5DgjuC AS6bd/CtOA9H
uLd9ieH2Oi6kYlxE07gDLcNltBSXUyOuJD+uptNxDW3FtdSNXbQdZ9MArqfz sZsuwQ10NW6k
63i8iXs40fRWbsnuxG2Uxu30AL5pgrhNwE4PZkCcy/75GtoZtOupgmNTwFZt pqm4lWc5UCmX
dcxjUB/BLrY0j+mvYHB/XehYugvfYKk2/ukbzitUx192lnzLSGjT+Bb3YLgj jYMEf7X7UBr3
2lDNewyz7/HM/WAaD8v4WBpPyPhUGj+yKJ5O44g1+0UavzJBZgmtTuMFmyX1 d4QWc/IHQmuN
+09p/MWGGvfrabzBd9L9rzT+w2NNGm9n8S9IU44NozlgPd98cJtYyMXvdAxx Dkizg+5GHTiP
4B7OCPdiAxf7m3GYg/sAB/RhDtwjHKxHcSke56b+Ce7In2RYPGW62WM5IePm 6Rw0BznZRVGc
Qvnk4lMH4KUCUtjNNvm/hExafiOT7EXLLcdJGlixF1H5KJOPhr3oPkSTukpo 8hAVt9aYVPZu
3tMOkbsrZ4impGh6vd2iOU5oDlF5V02pPUXHD9EJ9bmluUWuooISmpui+VtK c0vIk6IFPEmR
l2/efto/4pL5nOWBpzm/H8E8PMOJ8Vk04znG+fOM5hcQ49ZmB140zW2wlB5J jYO0kDFC5qzO
RNU8tNEiWszmNmAZLaGT2EFnsJtvp5PZZGKMt2RcUGumVE6lJXTKqDZ55tor Wa+MffiVofrx
eJeP5X11XN6VQkUN/wdQSwMEFAAAAAgA63ptNU8CmggsAQAArwEAADMAAABF VFNQbHVnaW4v
YmluL2V0c3BsdWdpbi9FVFNMb2dQYXJzZXJFeHRlbnNpb24uY2xhc3OFT8tO wzAQHLehjzS0
UN5cUG/QQy2OiMcFwSlClVqVs5taqVESR7aD6GdxQEgc+AA+CrFJOSLhldY7 1sx49uv74xPA
OfabqDGcSGfzpIhVxu+mk1DHY2GsNHcvTmZW6awJj+FCm5jLKFG5lXy5Egtp eaJjEsU8r/iW
qzTXxknD1waPRuS5NAyNK5Upd8NQPz2bMXi3eiF91NEOsIFGCx2GXlRYp9NR ulqbtcGwGaCL
Ht1RYYzM3LjKyNAPn8Sz4ImgryfOUIJLMghVJh+KdC7NVMwTWdJ0JJKZMKrE v4+eWyrLMAj/
2Zkc/YkuTCTvVak7/pM1KoNgQFnrKA+joo2oNwldo0YT0Bm+ozXs+28IXgnW sEW9W0kO4OEQ
Po6wTShY09HHTmW2W7H3fgBQSwMEFAAAAAgAbV1tNTWT812TAAAAOgEAABoA AABFVFNQbHVn
aW4vYnVpbGQucHJvcGVydGllcyvOLy1KTtXTU7BVKC5K1uflyi8tKSgtAQsk ZeYBBYCkXmZe
ck5pSmoxUNDXNcRR19PPTV8nhpdLARXoYREryClNB5pQkZuDRdI1JNgnPz0g sag4tUgvK7EI
t/6CovyC1KKSzNRiLGqS8/PSMtP1IUohHNwWQmzTd3TWS0xJLChJLeLlKoYE Arpr4GECJJGD
ACIIAFBLAwQKAAAAAACUU281AAAAAAAAAAAAAAAAEQAAAEVUU1BsdWdpbi9j b25maWcvUEsD
BAoAAAAAAJRTbzUAAAAAAAAAAAAAAAAbAAAARVRTUGx1Z2luL2NvbmZpZy9F VFNQYXJzZXIv
UEsDBBQAAAAIAJF8bTXXOFJI0AYAAMUgAAAlAAAARVRTUGx1Z2luL2NvbmZp Zy9FVFNQYXJz
ZXIvQUMuYWRhcHRlctVaW2/aSBR+X2n/w8jqQ7fdgIEQEiu0MgbaSDSJMGlX q2glxx7MqLbH
9YwTWPXH77FnMLZDwFwaaSuFhDNzbt+5zJlRLz/OfQ894ogRGnSVRk1VEA5s 6pDA7Sp3k+HJ
ufLxw++/XVqOFXIcabr4jYAtYJqkdpUZ56FWrz89PdWw7ZGQ4RqN3PpsYTmY 1Zk9w75Vl7y1
OXMUKcC2K/Ia1A9pgANu0GBK3DiyOFicF4XnFUUN5jyybE4Lhkx9XpF9SCPf 4iU/Zq5V2ZGA
4znPM9OwIu9NzMO4rDq0IlY5BLfp5gJ7XJU1ojZm7C4gBeMZDhitqt5MN6fs kFQIXQJumkSE
pZQiDQGvHZGQp9m5JF4FjFuBjdGURojPMLLjKILUQPYySSCJ59iOufXgYcOz GOsqYExmmDCq
5lHXhTyvySyuET/0aj2LEVtqUlBCwj5ITNPNiHD6u29x3FWaqnp2op6fNM4m jbZ22tTUZpnh
a6GwpL4RfsReV2kBJbB8EJSqRJl3BQkKiqgHe+ylRcnXCnYk24ra44D8iPFV v6tcD1stozFs
qP3OeaPR752rqnoxUC9a7XZzqPabioxEFguJajEaNyFOijBwkblgHPtoSjyM RDrsh7/gZTUT
iB6+MYcg0JTyXiUQNyZKdKKlUgE9y307DvKtF5GvV4J+MiMMEJZtDMUMMxRh N/asCMhhBGUK
+xAK0z4VMMQpIg6IIdMFbLRp5IBAj/gEltl+wcrUs9pYqB5kmrMO+0pxkwag lQUoZ4KIog8L
lotL9OPE8/TAeI6fx0509f1CI3hZ7VbKeJUYfMIBjqCNLZUK1MPct+Ng3T4Q a6M3QNkRvh++
0yU7q4G0nLBXAbrkgMB5WiQcB+rzw6FO2mk2teyHNl2yp2iPqJuT91qAl9wQ mNMi4TiY61sx
v6znBiQxRdWfjVGXtq0VJuXyAYJXwxLyEo/he247k7MVnDPp1J70y2e2qtsG CGlFYlY2s9mz
pCXw5eUiUQtDRExjJgeKxD4exVjZf/gjjBo0Dni0MKgDwbgzU9rICtwYzgBB xDBb+dac+LF/
5Xh4QnwRNohKaMGRegX6okcLUqGx7/QE7otRouiKjlg64RQnph2mBBErONBt 3IunUxyZ5F+c
2Nk8VVKhQ0r5knqhZn72PGp/T292bQXxRQirYtbKTVqZ9WB/GGsw9UNY+AKF 8o/rtCYcAmME
ZMVCyRa+Wl4MK33tfnI7ub2HamK5PrFRWmJy8tczYaurGoirNYryBHBa2QOU 2VYyBi3VbJJ7
Wc+CtqLhuZZx/NpJbIfRIq0ciwRsRALcg+bznS0LBwfOrVDYVd5A6ge2Fzt4 kKOKfXLB5FbE
S0veUqi58B8oFAF0Lxx6lo3z6qaWx2AzKwj4Jw8noCkmgl1O8kLWpNzaOPbw QLRuMNtJLvtS
zNnLCBFmzIjnGDNKbJxZS9gY/4ghSZzeAmwDidmSbPjU92kAtzI8eEz6Sc6c zQa1Gy3jwgDd
HX29QUI+o3Fk4+zQvHKKGoo6dM4j8hBzDHkytWKPy9KASnFiO2l2eeV99WXl W/3OdVBI5NsI
PxJoy18sbs
Re: Remote Import of log file [message #87272 is a reply to message #87254] Wed, 15 November 2006 04:04 Go to previous messageGo to next message
Eclipse User
The log file I need to parse has lines of below format
2006-03-08 15:35:04,897 INFO - Validating Request
Krishna
Krishna wrote:
> Hi Cindy,
> Krishna
> Krishna wrote:
>> Hi Cindy,
>> on the parent Eclipse's console I see the following exception.
>> at
>> at
>> at
>> at
>> is my pluginconfig.xml file.
>> Regards,
>> Krishna
>>> attach your pluginconfig.xml?
>>> Thanks
>>> Cindy
>>> Krishna wrote:
>>>> Hi,
>>>> of log file I get an error "IWAT0061E The remote log parser "ETS
>>>> Regards,
>>>> Krishna
>> <?xml version="1.0" encoding="UTF-8"?>
>> executable="RemoteLogParserLoader" extends="default"
>> location="%SYS_TEMP_DIR%" path="%JAVA_PATH%">
>> <Variable name="CLASSPATH" position="prepend"
>> </Application>
Re: Remote Import of log file [message #87449 is a reply to message #87272] Wed, 15 November 2006 13:28 Go to previous messageGo to next message
Eclipse User
--------------030708090000040102080506
Hi Krishna:
Please check the attached plugin project. I tested it both locally and
remote. The "An internal error occurred during "Importing log file..."
exception is because it can't find the "etsplugin.Activator". It is
fixed after I added the Activator class. I also correct a few error in
the AC.adapter.
In your AC.adapter, you are using the
org.eclipse.hyades.logging.parsers.adapter.outputters.CBEFil eOutputter,
it should be
org.eclipse.hyades.logging.parsers.adapter.outputters.LogImp ortOutputter
since you want to use log wizard to import log and display the results
in the log view.
Also the type of the outputter configuration should be
"LoggingAgentOutputter" which was "undeclared" in your AC.adapter.
Hope this can help you.
Cindy
> Krishna
> Krishna wrote:
>> Hi Cindy,
>> Regards,
>> Krishna
>> Krishna wrote:
>>> Hi Cindy,
>>> at
>>> at
>>> at
>>> at
>>> Regards,
>>> Krishna
>>>> Thanks
>>>> Cindy
>>>> Krishna wrote:
>>>>> Hi,
>>>>> I created a log parser plugin using rule based parser. On remote
>>>>> 1.0(static)=./ETSParser/AC.adapter" could not be initialized.
>>>>> Exception=./ETSParser/AC.adapter". I created log parser plugin and
>>>>> deployed it in the Agent Controller as per the intruction given at
>>>>> http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. tptp.platform.doc.isv/concepts/cintro.html.
>>>>> What could be the reason?
>>>>> Regards,
>>>>> Krishna
>>> </Application>
UEsDBBQAAAAIAE1WbzXVHJzSpQAAADMBAAAUAAAARVRTUGx1Z2luLy5jbGFz c3BhdGidjz0L
wjAURWcF/0PIbqqbQ2sRqaBDlVJnqcmjjcaXmA/Rf29Vii46uL17OZzLi9Pr SZELWCc1JnTM
RpQAci0k1gndlovhhKbTQT/mqnLOVL5pQ++dAL29kaNEkVBnOSWP8nVG30mu sSO1rRlwJY0D
dhCeqSogb9p1tiqy3Xydl7NlnhV/2IwAxrUFZuEcpAWxUaGW6H6pdPAm+M62 l/iE4+jz+ztQ
SwMECgAAAAAAeE9vNQAAAAAAAAAAAAAAABQAAABFVFNQbHVnaW4vLm1ldGFk YXRhL1BLAwQK
AAAAAAD0eWk1AAAAAAAAAAAAAAAAGQAAAEVUU1BsdWdpbi8ubWV0YWRhdGEv LmxvY2tQSwME
FAAAAAgAFnJvNWHKt7F4PwAAqy4KABgAAABFVFNQbHVnaW4vLm1ldGFkYXRh Ly5sb2fsXWtv
2ziz/nwC5D+wi/3gF6hpS74b8AfXSbc+J02DuEVxgACBYjGJtrJo6JLL/voz FGVZtqVYTty0
2fN0L7UunOFQw+HMPBzp3eR4Mhl/OWVmvd6uGka13mNGq0//NprcrDdYdbc/ hwdi6jrzQPCr
yHHtsT2IvB+evPcOD/627ix+J/zAkd7A4C1ev6y309OeLf3BJPLYZ2fqy+Ax CMUsYGNvyg8P
PkgZnkjLFj6bSi8ILS8M+uzLZHDveA3zPRuejz4NHrrt9+x7eu70ZCC8y2+T w4OPvjUT99L/
wSz/JpqJuDGrzn1pR9OQSf+GL/oc2D+4Ywu6aAvXirzp7eHBSM5mlmdXXccT O1CwrdBiR/2L
5EKDm7y+OLhQvQnm1lRcHH+dnLnRjeNRC3HHrh1X9I/6tWyrxUEtbVXjMxFa ikONz+PWQS3b
Ceo9n0pf1Ig6O7P8QPg1os6pw3Phh44IMhKyqgxYPGisep/+sny6QkN6eHB4 8O749Ov5/66I
Gc2Ju2LiXTs3kW+F0s/RoBZv13vU/jPp2PCvYzaSkWszT4bMUU/RddlV5Nmu YHlC3D7SAw+4
eBDTKCSV4ZbzwOfz6WVTDQq/U+zqbaNhtIweY+xUsg8xseqpFTp3YiTpKcys UD3Cl4lgtvYm
wu08euBnw8vz8WT0luWguUCCkHq8uhDN+t6ECKRr+U7AaUr5e9OqcB7O+Ux6 DkngeDfclTeR
w5r0z5o47X6rztsdMyPO+Pvwa73R7h2zr7dkamxrHmqLl4wJdTo2ECw1GrXh iKf3WZ4aiSvB
riV1mTN2/DAV87jVYM+0qdOTr8PR/zB6GjljTELfKOHnsekJ+Im80VYo7VH/ TQn7X9aqkS8Q
0/GouWe53JnNpU+/+V8nw0/CJZvLb0Q41PTPrPC2sryglr++Yfb+s8kmV5eW XEiLXT6OWdEA
b/CprF+KObUbuzO6d/6xfDtY8voen0jE/OjL2YmcWu4nGYSV9XtipmazYe6b LR0XMDO7rf0x
8yMvn02jaeRwCe5DPo2CUM74hyh4HHu2M1XGjAe38v77LelcZfW8fiid/XWY nvS19GcfHc8J
bgtGqJ03QH9fk2eRkOX69iPHIq78OqZ15osgEHZl5ZLufre+E72rKAylV0yv 0Srunx3fF3B9
/58NYmCTzk+EK6YhUVvpVzuvX+oR6UYB//o4F/aJQ76mRxPk1lKW/ph80bCy eiUm19tGLW75
1bpy6TT5s5pQ5mTSqS1Uvsd/ZygkJ3QfzO6W5kdOMHetR6W4R+Ja+L7QZILK 4ooe40azNCVh
2UPPVodq4VulY/baeXQWD5+8+nuSKP6LehT35ETKeSU5F9Pomk/pT5YEua/e StNOL284aZ5Y
U2XlF9PjXAQy8qciGManM7N6/Yo2x608c5yh+sEKhFY5OlxoyZL2dye81c/u qRs1qyeGT3Pj
+vaR9ELfuYpdlzHFRom2fs+oP12pFNwc82o18sQqw8ua0ggFf5pPkm92nynK n62Vqfckjzom
YelJmF0uvlPseCUo3FubhulprY09o7kLoW/jDQrdTvmuTEmqUJBY5zRnFmfX KTaNgsl45lqh
Wuq+jQsIZW7QfWsWUFo6bhQ4j4+Oh/O5q9bn1FSsntJKkLdGqaB7SY2ahs5M pB1Vin2nVv0/
jZjsxvnEpuUNYEx5QTDlELus1O5Y30WdPIljelqy6N5Mnys5dyS6vA9mFHz5 YSGPXOVc4bFG
eqLIaRkqa6eesAIvoWh0Fi5YENEzF9fKnnId830W4a20h7EJlD4tG6Qn3p38 IeoVfQPTd+xO
oFJ4XZuHXg7JIzL1N9TMuykm++Q92mIstFcdcdci/3LBQDdZkEqO9PqR61jH w+4uHvhny/GS
tmnerRKfTCxenuXNIXFlBc6UZnOmrZnrZua09Vea9Tp53nVOsxn9L9uupabG 8exK2LawmUjj
y2vpuvI+6P8moe+mbPsPT3NNMMJThKcIT1fpITzd0hzhKcJThKeYhAHCU4Sn CE9LUkR4ivA0
NzzNxaCT+C9ymMHqJXDn5SCfRq57JuMplcarWax3253rYjwnRHSCSTSPA1T7 SxTOyRkvChaN
XO/q50eLuXYa0SKiRUSL61QQLRaTQLSIaBGTENEiokVEi3uliGgR0WJutPgu v9ijZfabbd7o
1VHsgWKPZ23OVxrU4U31hN9qscf+Rfg1xR77l+MXFHskQpjm3oT4KcUeuZUd rUa/3uJmr5Pp
+zdPxwQ2E8pbZS65q8sdJU9RX8/f5VFfLnuvnL8rSNucWTdiPZWRd0u8MnVz 914gr/EKIRXy
GshrlCaPvMbPmYTIayCvgbxGKYrIayCvUR4FL3TOO9xsZavI9+ucr1NfPjs4 53DO4ZzDOYdz
DucczjmcczjncM6Xww7nPHafu7zV/HmZ83Xqy2cH5xzOOZxzOOdwzuGcwzmH cw7nHM75ctjh
nCv32TB4s/HTnPMN6stnB+cczjmcczjncM7hnMM5h3MO5xzO+XLY4ZzH7nOT G82ftq1lg/ry
2f0i55x87o+OK45EaDluQGbWoRaO5Tr/iG9j/RqHm2NXqPqdysa9iR7m2Ybn stfLgK7YH9Lv
AqZGp9jfXH0dQEJR+SLJ6r18GUC3/oIXFhZ0PWWU3/FGN2/25DnKmtyKq9w0 ixvnSr0irWGY
eZ5BOSd9j+/P2CkA7PS2uVcIAH+S74kAEAFgafIIAH/OJEQAiAAQAWApiggA EQCWDwCLvjBn
5kdtK2/6O/MlLUOzgMnpNFILA7u/FR6Lh4xosamqeL6m4Ckuqq46Xp/9sZX3 H/x1wj31Xj5F
Q8V6Aa2namEeSdIqQfHC6nU983Mf97PDS8Xyo3Rt4WeZ5sWVuc+8PF/9Doe1 iLaSvaAnhPmC
d+VnqSX+VW+TRbP7gjcdZqjRkmNLT2wyMNqFsyql97e8Cvh/y6uFAxv82eCe DJ3rx0r27JrV
2oEe9e20iB6Fns8iSMLmEGuVJ/bZ8iiU9Dn5gHRUyZzRD79ZcuDGyRER0N3K nkgck0LDuljP
Fp1KBUsU3cjTQNKFuS9v1AsR+bcx3Zw4HPHvhGU9j2XW8yTj6ymPmeb0j7j1 ygn9qLfRmDyS
ffVJT/9JPJKATnymbtEwBpWVq7pXuROqwLNeJbbmWJvbulbSse7kvZUT0S2i 29LkEd2+eBIi
ukV0i+gW0S2i218Hbzb7TZObXePnwJs51JfPDnsPAT0BeoJzDucczjmcczjn cM7hnC+HHc55
7D43eaudxZn265yvU18+OzjncM7hnMM5h3MO5xzOOZxzOOdwzpfDjn1hBf56 y+CdlZfUjr8P
v9Yb7d4x+3orWKym+vM7yQc6aLLGX6th6RdsasMRT++zPPVZjivBrmXk2Zyx 1MVmgz3Tznr3
WemTD36Q0DdK+Hm8zSizCSntUf9NCbuuIQViLteK2H8k5fnrZJh8KpdW7KGm f2aFt5XlBW1j
zGds8Yryvtu75JP/td72C7arrUVTu3ysNzfcwsd6Fw8FH+vFx3oR5G8ngSAf QT4mIYJ8BPkI
8vdKEUE+gvzcIP94diVsW0FoaXx5LV1X3gf93yT03ZRt/+FprglGeIrwFOHp Kj2Ep1uaIzxF
eIrwFJMwQHiK8BThaUmKCE8RnpbHoJP4L3KYkbeTU+HO7dbvsJMzN0R0gkk0 jwNU+0sUzskZ
LwoWjVzv6udHi7l2GtEiokVEi+tUEC0Wk0C0iGgRkxDRIqJFRIt7pYhoEdFi brT4bkIR3/jL
6UpM2O7X6/16kzfbPVbd7c/hwaIHV5Hj2mN7EHk/PHnvJZHinfADmq8Dg7d4 /bLeTk+Tz+MP
JpHHPjtTXwaP5ErMAjb2pvzw4IOUZM4pgo0hUZqMtNL02ZfJgLynhvmeDc9H nwYP3fZ79j09
d3oyEN7lt8nhQfqcmOXfROq7A9SYVee+tKPp2spk/1A2ki7aQg/e4cFIzma0 elddxxM7ULCt
0GJH/YvkQoObvL44uFC9oYVuKi5SPJdaiLsY4+0f9WvZVouDWtqqxmcitBSH Gp/HrYNathPU
+1gBakSdaay5RtTV6/8ofAodEWQkZFUZsHjQWPU+/WX5dIWGtKgkdE7cFZMF QC39HA1q8fbK
W05HMnJtpqBqRz1F12VXkfKLWJ4QScpCPIhp7CRxy3ng8/n0sqkGhd8pdvW2 0TBaRo8xdirZ
h5hYVRudkXpj6kz5Er+RCLfz6IGfDS/Px5PRW5aD5gIJQurx6kJ0O3sTIpCu 5TsBpynl702r
YrurXsu58eLfWIRGm3d6WRGG6iW/2gFh5EeT2OkbgO1I5UX67A8dydFvRqF/ bCI45y97uW/p
/SBx5utE3iwSLcoIU9gQaqtCF26EX8m9SS8y+8uL/bnKRb2zlBbCL96W3Jxh vuRduaX6UMi4
cD1P+cQvcFUefeK7JT8Td+SJ9bnRb9S52W5hfcb6/Dx7ShpkKA16w+vz3kX4 ReuzlmPlPXdv
b33euxAvXZ8LTKdhUKSlyixhOmE6n6XqSoN6a37cGzOdWoSu8dZDm/3L8QtM 5/6F+CmhjQxu
Nl8ERb03+6bBO43malSzFszcK2yYWVEoiYVDTrT7yCydF1aBTSLc0mRUmv/Z KClXHeDXC5PH
de8zm+jjrfOLXDMTYaDHiqf5Z3ZN/22wcgL1nRXLdexNb32NZeq3x1788CoI fWKoO0IhhGXr
nynDytotSZo+D1l/kpNuriAj8RDGWU6dkd48r6OuXPynBAcVRmnSOhCpZE7r /KaRl2zcZZR0
x/PGxWwV5k635epPrH8eF/nuuS8+Op4dR2oj1wqCSs5NMcPcD2fGslxZgViw cHU4G5OaW+Ht
4nMf16tMNq4nmfy84DPmkcqSZXYkrq3IDWNiSRy9xifnDq1VuehkiWeez2bl WpLaLhSlNINC
2r1nTokytHM/7rLTI1Aq8PTodxdFKstETD6BjZZm62WiL0lvim52XmIH1ikv rYBpvtQKLGnn
Wkiz+NM3S/RR3DjU9FHzPU+OJkQsFDePXyZ/LWDT43hZVOD48UMoPOWjV3Jv T6xzIZyyyTol
uKD3BMvNe2N+ndy9GAX8RtmCsGP9EeUnWOberp9gM6+qageun+INDTvyThrp 7Fae2u/6Bat4
48TNIhs5juOnaeZzVsuNFUbunoafvjGw0XiBmNgYiI2BKT1sDNzSHBsDsTEQ GwMxCQNsDMTG
QGwMLEkRGwOxMTB3Y+DIishJZVeP/fWcxqkMP6rXjGQyrzm51k3O+0nnNOs7 5x6QKnrrqaJS
afVGvIJzzlnbYDOidHhwLmW4fE1PP7tPCqoMVf7NVXl3CYAQFTltQIiAEMFW vjFbqWkDIQJC
lHYACNF2tkCIgBABIdpsDoQICBEQIkzCAAgRECIgRCUpAiECQlT+RYNx44L6 Z1UpYPJWE/XP
qH9O+Gytf96pEqWpXhFQbxiHqERBJQpwBuAMxQyAMwBnAM4AnOEOOANwhjvg DMAZgDOUIgGc
ATgDJiFwBuAMufE/cAbgDMAZ9oozoBJlhTZSRb8yVVQqrY5KFKjyv0qVd5cA CFGR0waECAgR
bOUbs5WaNhAiIERpB4AQbWcLhAgIERCizeZAiIAQASHCJAyAEAEhAkJUkiIQ IiBEe6pE0ZUC
7ewXN1CJgkoUnUmOKSU/kzlVpGQqn5NfidJs84axpl+oRCnEGVCJApwBOANw hkTrgTMAZyjJ
DzgDcIYT4AzAGYAzbDQHzgCcATgDJmEAnAE4A3CGkhSBMwBnQCUKUkWoRIEq Q5VRiQKECAjR
E+YGCBFs5evZSk0bCBEQorQDQIi2swVCBIQICNFmcyBEQIiAEGESBkCIgBAB ISpJEQgREKLy
lSgq1C4uEmj1UCSAIgGkgJECRgoYKWCkgJECRgoYKWCkgJECRgoYKWCkgJEC RgoYKWCkgJEC
Rgr4KRIoEsDOaqSKUCQAVf5/r8q7SwCEqMhpA0IEhAi28o3ZSk0bCBEQorQD QIi2swVCBIQI
CNFmcyBEQIiAEGESBkCIgBABISpJEQgREKLyRQJx4+LPVahKgV4dn6vA5yo0 n+d9rgJKBiXb
p5K9m5CijL+crqtSu9/scKPVZtXd/hweLDpyFTmuPbYHkffDk/deokN3pAak MQODt3j9st5O
T1P05g8mkcc+O1NfBo8UFM0CNvampIcfpEyeOpvKOI8VBn32ZTKgOLBhvmfD 89GnwUO3/Z59
T8+dngyEd/ltcniQrjjM8m8ilWqjxqw696UdTdd8bPuH8vbooi30MnB4MJKz GcUhVdfxxA4U
bCu02FH/IrnQ4CavLw4uVG/IZZ+Ki2UtVtUWd/Hk6x/1a9lWi4Na2qrGZyK0 FIca14htUMt2
gnof60GNqDM9k2pEnVOH54JmuggyErKqDFg8aKx6n/6yfLpCQ1pghqI5cVdM FnlMMiybGtTl
HSNbGzeSkWszT4Zkk+gpuu6iIi1PiMSEiDh9qhxsy3ng8/n0sqkGhd8pdvW2 0TBaRo8xdiqZ
zpJXtfs0kvQUZioq+o1EuJ1HD/xseHk+nozeshw0F0gQUo9XF6LR3JsQgXQt 3wk4TSl/b1ql
8Ja8StFO32jwnonPSZXdB4BKUewDwD4A7ANItB77ALAPoCQ/7APAPoAT7APA PgDsA9hojn0A
2AeAfQCYhAH2AWAfAPYBlKSIfQDYB4BKUaSKUCkKVYYqo1IUCBEQoifMDRAi 2MrXs5WaNhAi
IERpB4AQbWcLhAgIERCizeZAiIAQASHCJAyAEAEhAkJUkiIQIiBEe6oU7ZCd 4Z12C0V8KOLT
fJ5dxNdVRXyNZhNFfCjie17RVVcVXa1+4O6tFfHtXYRfVMSn5ei09ibHryji 27sQr1rE1+vX
Dd7F5x5LQ7Qo4gNEC4gWEG2i9YBoAdGW5AeIFhDtCSBaQLSAaDeaA6IFRAuI FpMwAEQLiBYQ
bUmKgGgB0aKID6kiFPFBlaHKKOIDQgSE6AlzA4QItvL1bKWmDYQICFHaASBE 29kCIQJCBIRo
szkQIiBEQIgwCQMgRECIgBCVpAiECAjRnor4ev26ufbFJRTxoYhPZ5JjSsnP ZE4VKZnK5+RU
opjtfsvg9U4XlSioRAHOAJzhCQbAGYAzAGcAznAHnAE4wx1wBuAMwBlKkQDO AJwBkxA4A3CG
3PgfOANwBuAMe8UZUImyQhupol+ZKiqVVkclClT5X6XKu0sAhKjIaQNCBIQI tvKN2UpNGwgR
EKK0A0CItrMFQgSECAjRZnMgRECIgBBhEgZAiIAQASEqSREIERCi/VSi6EoB o45KFFSiJHz2
W4nSVZ8r63WbqERBJQpwBuAMTzAAzgCcATgDcIY74AzAGe6AMwBnAM5QigRw BuAMmITAGYAz
5Mb/wBmAMwBn2CvOgEqUFdpIFf3KVFGptDoqUaDK/ypV3l0CIERFThsQIiBE sJVvzFZq2kCI
gBClHQBCtJ0tECIgRECINpsDIQJCBIQIkzAAQgSECAhRSYpAiIAQ7akSpUvu A68bLVSioBJF
89laifJuQooy/nK6pkqNer/Z451eh1V3+3N4sOjIVeS49tgeRN4PT957iQ7d kRqQxgwMTpp6
WW+np8mx9geTyGOfnakvg0fyV2cBG3tT0sMPUiZPnU1lnGIIgz77MhmQi94w 37Ph+ejT4KHb
fs++p+dOTwbCu/w2OTxIjQGz/JtIZUGoMavOfWlH0zX3x/6hFmK6aAs9Qw8P RnI2Ixex6jqe
2IGCbYUWO+pfJBca3OT1xcGF6g15U1NxsSyTqdriLp58/aN+LdtqcVBLW9X4 TISW4lDjGkwL
atlOUO9jPagRdaZnUo2oc+owxeihI4KMhKwqAxYPGqvep78sn67QkBaYoWhO 3BWTRYqJDMuG
BrXqvGuYGWM0kpFrM0+GZJPoKbruolgoT4jEhIg4s6V8H8t54PP59LKpBoXf KXb1ttEwWkaP
MXYqmU5gVvXKNpL0FGbKYf2NRLidRw/8bHh5Pp6M3rIcNBdIEFKPVxfC7O5N iEC6lu8EnKaU
vzetUqnwnCK+htE367zVzj4CFPGhiK9glADRAqIFRAuIFhBtkpcCRLtzaHkC iBYQLSBaQLSA
aFebAqIFRItJCIgWEC0g2nIUAdECokURH1JFKOKDKkOVUcQHhAgI0RPmBggR bOXr2UpNGwgR
EKK0A0CItrMFQgSECAjRZnMgRECIgBBhEgZAiIAQASEqSREIERCi/RTx6UqB bnPtcz+LWYQi
vifDF3xOKqWh8jl5lSgm+YzcaP1fe2fX2zaureH7AfoftItepEDD6tNfQC66 Mz1nspF+oOns
3gxQuI7aesaJfUw7ne5ff0hRUmRLshhXduLuZzDAZGxrkZQWl8j18CU7KFFQ osAZ4AwbCoAz
wBngDHCGGzgDnOEGzgBngDNYmYAzwBnohHAGOEPl/B/OAGeAM7TKGVCirNgm VXSfqSKrtDpK
FFz5p3Llu7cAQlQ3aIMQQYiIlQcWK41tCBGEKK8AhKi5WAgRhAhCVL4cQgQh ghDRCSWECEIE
IbK0CCGCELWkREmUAkHfRYmCEsWUs/VxUoF6+Yle1Oc4KY6T2u74H+VBvuh1 i2fbHdpxUq03
4Z6Ok2q9HfdxnJRpxMrL7X6Pk6oLnR0VWUXo+4ROQud2rq48qC+iftiaq+8/ dLbehHsKnUk7
Om7/oENn643YVejsqn/1ebiETkLndq6uPKgn3MA74NDZehPuKXS23o77CJ2m EWH3wYTOyobo
BRhVW0f0Bp4vutFaQoitIxZsHcHCQBYGsjCQhYEsDGRhIAsD2yn2nIWBLAxk YWDpchYGsjCQ
hYF0QsnCQBYGsjDQ0iILA1kYyNYRpIrYOgJXxpXZOgJCBCHaEG4gRMTK/cVK YxtCBCHKKwAh
ai4WQgQhghCVL4cQQYggRHRCCSGCEEGILC1CiCBELW0d0Rt4wZrOga0j2DrC ZJITS+mfaZ+q
czKdz6lWogQ94ffX/AslSi1nQIkCZ4AzwBlSr4czwBksy4MzwBnO4QxwBjhD 6XI4A5wBzkAn
lHAGOAOcwdIinAHOgBKFVBFKFFwZV0aJAiGCEG0INxAiYuX+YqWxDSGCEOUV gBA1FwshghBB
iMqXQ4ggRBAiOqGEEEGIIESWFiFEEKLWlChBTwSejxIFJYopZ7tDTHuJqCkS ndDjOCmOk9ri
+B/jQfpAsk5rx//s+TipXTThPo6TytsR+K21Y+/HSe2iEfs7TkrVvq+P5+tH ASI+RHwgWhDt
hgJAtCDaPFaCaHV5INpCBUC0zcWeg2hBtCDa0uUgWhAtiJZOKEG0IFoQraVF EC2IFhEfqSJE
fLgyroyID0IEIdoQbiBExMr9xUpjG0IEIcorACFqLhZCBCGCEJUvhxBBiCBE dEIJIYIQQYgs
LUKIIERtiPiMUqAngr6LiA8Rnynn7iI+z3U8fxD4AzcU/X4XEd8Pivh0wRv1 evkPHrY079Yv
uqLbDw9RmldsQs9zW2vCvqV5K+3wo8OU5q00onto0ry89uqFq0y3LM1TwwbE eWtABPRaNxsC
vYJeQa+gV9Ar6BX02kphoFfQK+gV9LpqFfQKen34nRD0CnoFvVpZBL2CXhHn kSpCnIcr48qI
8yBEEKIN4QZCRKzcX6w0tiFEEKK8AhCi5mIhRBAiCFH5cggRhAhCRCeUECII EYTI0iKECEL0
o+K8W61AXwQe4jzEeWk5W4nzfHcQBmrIJrpR+POK84a3r6jSS1m9i79l73JL pZ69uZ9Qtpd6
TCS6Qf9AZXs7acI9yPZu2xEdrmxvJ43Ym2xP1z7UJ+oFXhfZnjWURbYHlAXK AmVTrwfKAmUt
ywPKAmXPgbJAWaBs6XKgLFAWKEsnlEBZoCxQ1tIiUBYoi2yPVBGyPVwZV0a2 ByGCEG0INxAi
YuX+YqWxDSGCEOUVgBA1FwshghBBiMqXQ4ggRBAiOqGEEEGIIESWFiFEEKIW ZHupVqBX1gpk
vQjZ3sbpy3+nbO9OWpRIvWOF2+mhRbEmDWhRIA2QBkhD6vWQBkiDZXmQBkjD OaQB0gBpKF0O
aYA0QBrohBLSAGmANFhahDRAGtCikCpCi4Ir48poUSBEEKIN4QZCRKzcX6w0 tiFEEKK8AhCi
5mIhRBAiCFH5cggRhAhCRCeUECIIEYTI0iKECELUkhbFaAX6xSNQ0KKgRTGZ 5MRS+mfap54+
qjhCKtCnkfmedqXQ9ThCiiOkZMORP7nH9EW/E7R25M8+j5DaURP2foTUjtqx 3yOkio3otnee
106OkKqM86s6PtOcjj7e0esXT8TSejr9xjUvQ+frUDp6AHnpTJcL1S/V6Ef9 d5y/nIfX3x0d
A4S6cCxVrb47n2L170ivJHEWytiLLyoaOcn0dTqZmGh5mwJO4or+aKEGGlKZ y2R5qz8TzttJ
PJTpL0cLR0WRy+VIDwVnuiqi5k6k91ujBB311tvfHbh9EflFn3w7n46SRNzA OfacT98XsXxm
/vNcxqp09bn7zImT2auuRfbj/MOVn02GM72gRt/BgRoama9k7Rsu7Ki5q+h1 XN5wvOGsIpLy
mMAV/eiA33BpEzoHfEjijtpxD2+4tBG9B35I4ua4HnYHYV/4PW/vcf2HXseq 2lEovF5x24az
Dy/eqx955sU8j6+mC/N+NrNX57GOPZ5wj9SDWYxHT0+EjkZpMHpxavI+8fyx iuDZQ1Tv57Gq
y1i9Zf8TXwrHyafMzoljZ26rpxIF+m3rd/b/tv2hp6Kq7YWiE/R+xqeiHok3 CF0RrgxpH/xT
MdWORLfj/pxPxTNPxe8d1lPxzFPxowN4KpVD8FBNiAZeR/hulyE4Q3CLIZPx mK7wV14QBzUE
30UT7mMIvot27H0InjciCh/2EFyvryy9AkL12hqEvppAtLw3VOR67A21vh73 lJX/NTCelf+s
/Gflf6nprPxn5T8r/7OVCq2tkGDlf7kUVv5b2GPl/yYrrPyvN8HKf1b+0wlZ +c/K/8r5Pyv/
WfnPyv9WV/6zN9SKbVJF95kqskqrszcUrvxTufLdWwAhqhu0QYggRMTKA4uV xjaECEKUVwBC
1FwshAhCBCEqXw4hghBBiOiEEkIEIYIQWVqEEEGI7PeG0lPtGplAIPru2rZQ yASQCZAEJglM
EpgkMElgksAkgVsrliQwSWCSwOXLSQKTBCYJTCeUJIFJApMEtrRIEpgkMDIB UkXIBHBlXBmZ
AIQIQrQh3ECIiJX7i5XGNoQIQpRXAELUXCyECEIEISpfDiGCEEGI6IQSQgQh ghBZWoQQQYja
kgl0fWQC1klgZAIkgUkCkwROvZ4kMElgy/JIApMEJglMEpgkcPlyksAkgUkC 0wklSWCSwCSB
LS2SBCYJjEyAVBEyAVwZV0YmACGCEG0INxAiYuX+YqWxDSGCEOUVgBA1Fwsh ghBBiMqXQ4gg
RBAiOqGEEEGIIESWFiFEEKJWZAKhcIMQmYB1EhiZAElgksAkgVOvJwlMEtiy PJLAJIFJApME
JglcvpwkMElgksB0QkkSmCQwSWBLiySBSQIjEyBVhEwAV8aVkQlAiCBEG8IN hIhYub9YaWxD
iCBEeQUgRM3FQoggRBCi8uUQIggRhIhOKCFEECIIkaVFCBGEyF4mkFz85/ST dELHr9YK9LxV
rUDWi9ZFA5dLPbgfOI/NcEQLBdT41fmsZgpCiMcr8oDbZ/V6OZm8nSY286x+ uY1fvw8vY6kn
Dl/0BGKWzAVlIdolRarmJ9M3NUnIZgtJ6kRm80n1xZd4flT5I3OnqsLqdtOX J6ul/Gv6ST/N
N9cNE0w1rd11HWoLrnXKvBztKcJkkhNL6Z9pn8LJcLKH7GT9Lk6Gk+FkONmD djKNP6qkm56a
9omo00G6ObEF80g3AfOA+RXbgPltm76Oz1dsA+YB84D5dGTU2ogMMF8uBTBv YQ8wv8kKYL7e
BGAeME8nBMwD5ivn/4B5wDxgvlUwj3RzxTapovtMFVml1ZFu4so/lSvfvQUQ orpBG4QIQkSs
PLBYaWxDiCBEeQUgRM3FQoggRBCi8uUQIggRhIhOKCFEECIIkaVFCBGEyF66 qafaNTKBjvCj
AJmAdRIYmQBJYJLAJIFTrycJTBLYsjySwCSBSQKTBCYJXL6cJDBJYJLAdEJJ EpgkMElgS4sk
gUkCIxMgVYRMAFfGlZEJQIggRBvCDYSIWLm/WGlsQ4ggRHkFIETNxUKIIEQQ ovLlECIIEYSI
TighRBAiCJGlRQgRhKgVmUBXhOHauTvIBJAJkAQmCUwSmCQwSWCSwCSBWyuW JDBJYJLA5ctJ
ApMEJglMJ5QkgUkCkwS2tEgSmCQwMgFSRcgEcGVcGZkAhAhCtCHcQIiIlfuL lcY2hAhClFcA
QtRcLIQIQgQhKl8OIYIQQYjohBJCBCGCEFlahBBBiOxlAsnFf04/SSd0/Gqt QNRZ1QpkvWhd
NHC51IP7gfPYDEe0UECNX53PaqYghHi8Ig+4fVavl5PJ22liM8/ql9v49fvw MpZ64vBFTyBm
yVxQFqJdUqRqfjJ9U5OEbLaQpE5kNp9UX3yJ50eVPzJ3qiqsbjd9ebJayr+m n/TTfHPdMMFU
09pd16G24FqnzMvRniJMJjmxlP6Z9qkfcLKuj5PhZDgZTvagnUxnpqtVdVFf +L0QVZ01M0VV
BzOFmcJMU6+HmcJMLcuDmQ5hpjDTygrDTCcwU5gpzBRmCjO9fV3ATGGmM5gp zDSNGDBTO2aK
qm7FNqmi+0wVWaXVUdXhyj+VK9+9BRCiukEbhAhCRKw8sFhpbEOIIER5BSBE zcVCiCBEEKLy
5RAiCBGEiE4oIUQQIgiRpUUIEYSoNVVd1BeBF6FFQYtiymnUovzjQjnK2ZvX K64Uqf6vXakT
us7x3f559EtWkU/L8eTy7PJkef3X9fTbdepDN8oNlMeceCIS7ke3k3+sBtbz k4vltfNqPJpP
5Xc1Xr2Sztn1SPnhP6fT9Kk7o2mSYljIgfPm4kQN0QP/mfPi3elvJ3/3Os+c D/lnr89P4uuP
v188+iUPBs5w/mWpsyDqYud4ePuKKr2U1bv4W/Yud45nl7Hpro9+OZ1eXanx 4vFkfB1va+5y
uBg6vw7+0B+pIdUo/uNWK3N8Gd8kPXDw6+B5/oPn4ipeDPV1z4WBZ/J5sQxV weS5P1eGHNNz
nitDYjZXsxbVs2NZaIRzPJVOcpOc42/5X8O5+kbdwpqws5yp0nUhWUpJBZJV jwndgeuJoO8W
gs/pdDm5dK6nCxWD1FObTDJxUFUj0pARJ5ksPdYZjv8Ws9noYyh84YobXZzb 8VR48/qO47ye
OiZheWzeZKfTy9i50gPUB9SEr7Pl3+Lti4/vzi5O992O0I1aa4dyd9UQ5R6H 3Ag5nQznYylU
l5q35lVm5JfN5NVLOep0K1oSCjcoutWHrGs76lrV+PjymWqLGm5Nr1Rr5lM1 XVTRL3tVJ6/i
3/9pSvfaKF9L+VQxf6pRl6Pu0mg+Tl7kSehxjkT61dNE0KeCyivzItNSvqux lPqF5igb6n+T
C9RjXKjBi3TMa12FZ/WA9PTChMPhp6lq2uK2yOTi2wp8G6snqZ/qZxWfkitM 4Jp8d/SQeqIu
zUpS/81umLiLkDK5C4Hq3N21LQcQUiKkBJODydcKAJODyfNYCSbX5YHJCxUA kzcXew4mB5OD
yUuXg8nB5GByOqEEk4PJweSWFsHkYHKElKSKEFLiyrgyQkoIEYRoQ7iBEBEr 9xcrjW0IEYQo
rwCEqLlYCBGECEJUvhxCBCGCENEJJYQIQgQhsrQIIYIQtSGkNFoBX/g9DvVC SJmW0+KhXsq/
9L/Cj9xHaFFsSQNaFEgDpAHSkHo9pAHSYFkepAHScA5pgDRAGkqXQxogDZAG OqGENEAaIA2W
FiENkAa0KKSK0KLgyrgyWhQIEYRoQ7iBEBEr9xcrjW0IEYQorwCEqLlYCBGE CEJUvhxCBCGC
ENEJJYQIQgQhsrQIIYIQtaRFMVqBnocWBS2KKaddLUpnEHSEF65pndCioEWB NEAaIA2QBkgD
pAHS0Fqx55AGSAOkoXQ5pAHSAGmgE0pIA6QB0mBpEdIAaUCLQqoILQqujCuj RYEQQYg2hBsI
EbFyf7HS2IYQQYjyCkCImouFEEGIIETlyyFEECIIEZ1QQoggRBAiS4sQIghR S1oUoxXoBmhR
0KKYctrVonQHviuiIESLYk0a0KJAGiANkIbU6yENkAbL8iANkIZzSAOkAdJQ uhzSAGmANNAJ
JaQB0gBpsLQIaYA0oEUhVYQWBVfGldGiQIggRBvCDYSIWLm/WGlsQ4ggRHkF IETNxUKIIEQQ
ovLlECIIEYSITighRBAiCJGlRQgRhKglLYrRCvQ7aFHQophyttOiqJp+y15l tX7WCYOCn72d
T9UQ50oWNSmx9j3VHbVnjaaXsfNZzdcdTX+Ox9fK7+qK/DHXq34RvtBBOZ5n qWE1wEk/OVr7
Jo1RVcmZwii8bmA9ml7Nlos4H9ofbR6BV+aALIopTDsti6pOGBbnFcvx5PLW vHqefypr8v00
+eKo+LWpe2X6qMbgcnapBkm3U4WSNb9fM3SzmfbI7PNTNZb/ombizVMfv2as WVX5sXx5rcfv
FTfBd6vGMAU772L1qtfOltU0/cvk4eZHa98bo90aoytjxeoS9PQvzZA3FVb8 qRnaNHjIWl1V
TF+kw0d1a6oa4kVNI3oV5RfZ89H/zUanax+ng9PG8eLF8HOsXtzXabAr/K8Z AdS+jdeHyytj
ZHNxr66v1jZGfB7P03lldYOimhu+2eLblftec6uq3gzrli/i+c1YTZCrjWbf Gns2bc+uSP3u
JjFatuV1awLH7Sztw/i6eJmJHgWb6z/Y3Kdr7aapBbfGnlc15NxgTzmv7hO/ xsP8RlYarpx4
b3rs/pOwslv4WUVrScLD7Bj+hp6Rtqnu/dtg8+3a/a+9Y00uWNU/1g2veUtN NnCrLlKZJa9M
ZLxVg5aslUlNb+1mb8Pq35rbbFPp5OflGt9a8fwmMytVWLO1+p3xR68y4V1v cR7/3zKWWQTT
I4wKq37XylPfDq+rDOZfpQNEmzuX/L6YX1wzUpl8fnAZxc2XV7J9+8uDqkdS vPziazyZ3LpM
kpudTo7Mx2nXq5wFlo18ePXx1ZvfL16+OH1/9u8X71+uGKlOHhaNpEWnXEAN kEdH2UfGa/1e
VRxdSanGKqoOzXCqYKb4cTpyqsyXl5tUMFJsTKdygVNVcrdYi2JeN3T9qhik TRQmsdeBL95c
6AUbH3I7HypTU3c0cqQ+ME3pe03P5WKkHsEk6Q9654OCkcI3ZhjT9HwaH3HA jeXGcmO5sdxY
biw3lht7Hzf2dKU9297ZVSu3t7YXNo3o31fd1cKExI+aHk6TBa/XNC1o4ZmY 8r5VViAMK9dD
7+yRvo3jv17FUqrJ6rbPs2Aif5h+0DwlsVzl0TR1ZpUHqzxmrPKos8gqD1Z5 2K/ySJdPaFmG
jh8V/D0QQX+Nv4+SRc0Dxwu9Tui7zqfvi1g+M/95LuPR9Fp92XV7vuc+c+Jk TaAzu73MD30/
+zz/ued7nvpwMpxpsbJ2fPVDx3wr7VYPVO1oGYiO3yvU/sOLd6/PXv/vQDUj qYAqax6PlnOp
nX+4WMRXs4WzmGa7T8aOBi1Vd0wvwC7G2+vhzfhLEvnOp19eZ/+T7pcpF+PJ xBlfO4uvsXM1
vrxUn00/FzfOLBWTLOuYZfxDl3Yzjr8VFraY/1WF/Vv9Ec+rFzK8MzGkoIr9 iW+A1ZvalguE
d+MC2e2qMhZVrhmut/VpKb9ffJ1+0+2qsue5brsG+72mdQDrjU1wphdUGrNf pqsvUlby9ULr
DyHs140pW5KfbPCQDbdL1ct6aGlhrBKhbymM0dqBtEdUr+Xqey2WlvpBr7qo XqVXbblcLfWS
aqmP2zhH1wxaz7nOp6O/EkMrH5gHUTeHyuf539WDm6ua/ycdk0r1QToPkkcr 35pu6jdNLQsr
6FeNrS2gr53e3XFqVbke4n5VLKuCp/QGpPombeKlXkl6tPq5uSt+lXcZc0v1 tslXIiRT7RSN
Zq/Bo5UvTXxoHIcX1jLUmbOfJjStk6gViq7PxFhAxAIiFhCxgIgFRNnPWUA0 ZAERC4g2MgsW
EIEKubHcWG4sN5Yby43lxnJjd3FjWUDEAqKNJlhAxAKiYqKOBUQsIGIB0QEt INI7slatvemZ
HWKKa284TTYrkNNk2Su8roy8LewVzl7h2zedvcLZK5y9wtkrfMhe4ewVzl7h 7BU+MtD+jL3C
2SucvcJJAt+QBJ6RBCYJnEYMksB2SWBOk12xTaroPlNFVml1TpPFlX8qV757 CyBEdYM2CBGE
iFh5YLHS2IYQQYjyCkCImouFEEGIIETlyyFEECIIEZ1QQoggRBAiS4sQIgiR vUwgubjuNNlE
K9DxQk6T5TRZU852p8mmT285drwqQUrUFf2oX3Cy4rXx1WcRm3iYjm9FNtB9 cvbmw3w4U7Ob
Ag/KvnSev3x/8crcMC0ZuZ6qdqkxd0mlssOCarz4anoZT6T4Oo7nw/no63ez L95v2f/+/u5M
jRhvYu3POsw9yb/J3rJZ0W+Wi9lycbFQQ4Yr8W0+XsTvp/qJqIHVKD+B9qjW cBqLOlXjpJ1W
9fNkqSb0DfXyelVZiZ3WazSZysb75XWr7leF94z1JVk5yfVyeBMfrXySWOxV dryNLb1Qln7X
f2iTv05Hy6tkSJ5/bGp69ydrZ7cyX7S2Y7X4Lfn/5KrRJB5eL2e3BxUXvjPv 0k3P2ljMQ5Ae
Lv/61hxO/PLv2UTd87m4VHMI/ezK3xj7d9mYV8+k1URH/U8sLqe/Gsvr+4wV f5SODJu2YtSb
v9ZZXv0ufdlvWeX0VmysbKVAv8b4l9xm3WZrXlTpEfX2ZkmVrqY363vLZfYq 9/Rav5n/o6bi
07meUCr/knGyuW7x83R42NTUt2okMdM5h5vbm1f8zJi5477TFU/htnX2jzZN ECWB6YUaKCW7
0K5/m1jtNu4JuX7ZV/XqP52sVLJo0Asraeomi3o/6w0WO5Vbw24yeLu9ZpW9 qO7I8Dp7T/x8
0FK+f5VbYLaYBG98vnX1stwcOKPUqa2Vz8wDrSTXldV64q3dqawuOzmAuzqj UuFMaS3s23G7
E/aajU5l/rDmXoRV96JXu73eLv1l3VOyuvyogcoH+yNdvS7TRVdvoaunOeZk u8bkIWSJ3YKt
yuxEha0ngWpgZudyxUancqP4raFTNYp4cAnvzZf/6F6ljXvpFPbxTFzFXF7e 39Ov3Pq7ztSH
Vx9Pz99cvKzYJ7TjNt3Qxo2S/ObcP7uW2hm50/5kScPXtya7vRth5ZKQOz1Z i23JeLI82YN6
sil3/MG90tbMFJ6u/fEiDSDUevoFCN1QNUDodoUBQgGh1z+7VG5DR8+S1XkK /8fYT531NF8t
VJ1Hf5mHOlZznaPs8zTK2ayezkz+zzhfx3uU/G1s1Cdv7G10q6Ltw8RaUeJZ Wl7WC1N52VZw
sieiTg84CZwETlq29L8JTk6sTlvNcdDKh2lYvgNYAk2uGgdN3oAmrSyCJtOG giZBk6BJuvqO
ujpocpMV0CRockNNAFgALJ4saBI0WW0INLlqCzRZVQZoEjQJmgRNahsHgyb/ cfHy4uLszes1
ABm5A7cv/F7fOb7bP49+yW7Bp+V4cnl2ebK8/ut6+u061d6qOulNnU48EQn3 o9vJP1bDmPnJ
xfLaeTUezafyu5omX0nn7HqkHOef02mqlnVG02RrpoUcOG8uTpKhxzPnxbvT 307+7nWeOR/y
z16fn8TXH3+/ePRL3kGd4fyLYTcDxzke3r42Si9K9X78lr1fneOZeohJF1L9 ZHp1pab0x5Px
dbytucvhYuj8OvjjW/b8/rg9Y+z4Mr5JlMuDXwfP8x88F1fxYqivey7MpqPy ebEMVcHEa3XX
c4zi+LkyJGZz1fPmi3EsC41wjqfSSW6Sc/wt/0u7jaNuYQ2sXs5U6bqQbCsu 1blLHuO52mMK
yPp0upxcJhFgrJ/aZJIdqlbViLTLxMkOYHr8MRz/LWaz0cdQ+MIVN7o4t+MF XuT1Hcd5PXXM
Rm/H5u1yqrqac6UHjQ+oCV9ny7/F2xcf351dnB5yO5S7q4Yo99h3IwI3aq0R cjoZzsdSqC41
b82r9JaBFccdRt7A9UXP7T7iuEPbzWw57pDNbAuTVDazZTPb7ZvOZrZsZstm tmxmy2a2bGbL
ZrZsZpttO3vGZrZsZstmtoDSG0DpDFAKKE0jBqD0zqD09lYlU3bOiCNVtOdU kVVaneMOceWf
ypXv3gIIUd2gDUIEISJWHlisNLYhRBCivAIQouZiIUQQIghR+XIIEYQIQkQn lBAiCBGEyNIi
hAhCVEmIKmUCycU1xx1qrUAgwsB/xHGHHHeYlLPdcYc6n1OtRQlc4a8fp4kW BS0KpAHSAGmA
NEAaIA2QhtaKPYc0QBogDaXLIQ2QBkgDnVBCGiANkAZLi5AGSANaFFJFaFFw ZVwZLQqECEK0
IdxAiIiV+4uVxjaECEKUVwBC1FwshAhCBCEqXw4hghBBiOiEEkIEIYIQWVqE EEGIWtOiaK2A
Xzw6BC0KWhSTSU4spX+mferpo4ojpELH6wyivvpXBH6XI6Q4Qko2HPmjPKY7 cF31r+hERaHS
4RwhVWxC122tCXs/QmpH7djvEVI7asROjpBKS9EJdN3X1xsRqlmJcHteoRH6 uN8k/TRwjj3n
0/dFLJ+Z/zyXsboh6nP3mRMnczZndvvj/MOVn02GM72MRA88B2pAYL6SNZWt fCmtig6zavuB
8DvFA7DOPrx4r37kvUxkgPP4arqIk/GCebc7j3Xs8YR7pB7MYjx6eiJ0NEqD 0YtTMyqO549V
BM8e4qdYPcfxYjycjP8TXwrHyQcUzoljZ67qBRY5nqtGmWrAJ4KwwwuMF1hT wMk9JhRh12st
4OzzBbajJuz9BVZsh36YB/kC21Ej9vsCM43oDLy+6HvFgxwf9gssq7Yfic5K tR/qC6yyoZqo
V7WrN3A94bvsBmC/1ovdAFjrxVov1nqlXs9aL9Z6WZbHWi/Wep2z1ou1Xqz1 Kl3OWi/WerHW
i04oWevFWi/WellaZK0Xa73YDYBUEbsB4Mq4MrsBQIggRBvCDYSIWLm/WGls Q4ggRHkFIETN
xUKIIEQQovLlECIIEYSITighRBAiCJGlRQgRhOiHdwMoaAUitygGYjcAdgMw meTEUvpn2qee
1osp+wM3EpHfR0yJmFJaid+Ux3S0xxywmNI0IWxvQ4N7ElO23o77EFO23oid iCl16rtKttcf
+KFwo+JeBsj2NkNZZHtAWaAsUDb1eqAsUNayPKAsUPYcKAuUBcqWLgfKAmWB snRCCZQFygJl
LS0CZYGyyPZIFSHbw5VxZWR7ECII0YZwAyEiVu4vVhrbECIIUV4BCFFzsRAi CBGEqHw5hAhC
BCGiE0oIEYQIQmRpEUIEIWpJtpdoBfouh/gi20vLaZTt3UWLEroqLggfLQpa FEgDpKGhAEgD
pAHSAGm4gTRAGm4gDZAGSIOVCUgDpIFOCGmANFTO/yENkAZIQ6ukAS3Kim1S RfeZKrJKq6NF
wZV/Kle+ewsgRHWDNggRhIhYeWCx0tiGEEGI8gpAiJqLhRBBiCBE5cshRBAi CBGdUEKIIEQQ
IkuLECIIUTtalFQr0OMIKbQoaTnbHiEVdgahL/zQ5wgpjpCSNkf+aI8JRBAV g8+BHSHVfhPu
5wiptB2dTmvtuIcjpNpvxD6PkAq7+gi+wO0h27OGssj2gLJAWaBs6vVAWaCs ZXlAWaDsOVAW
KAuULV0OlAXKAmXphBIoC5QFylpaBMoCZZHtkSpCtocr48rI9iBEEKIN4QZC RKzcX6w0tiFE
EKK8AhCi5mIhRBAiCFH5cggRhAhCRCeUECIIEYTI0iKECELUkmyvO3A7wu/7 yPaQ7ZlytpXt
ReEgcEUvCJHtIduTNjIr7TGe8pjgcGV77TfhfmR7aTvCfmvtuAfZXvuN2Kds L+qombwIumsK
emR7yPaAskDZtQKAskDZPFYCZXV5QNlCBYCyzcWeA2WBskDZ0uVAWaAsUJZO KIGyQFmgrKVF
oCxQFtkeqSJke7gyroxsD0IEIdoQbiBExMr9xUpjG0IEIcorACFqLhZCBCGC EJUvhxBBiCBE
dEIJIYIQQYgsLUKIIETtyPaMVqDfLx5QhGwP2Z7JJCeW0j/TPvW0XrbXGYQd 5UoRsj1ke9JK
ZqU8pie8fveAZXutN+GeZHtJO3wvOGjZXuuN2KtsrzsIOsILXWR71lAW2R5Q FigLlE29HigL
lLUsDygLlD0HygJlgbKly4GyQFmgLJ1QAmWBskBZS4tAWaAssj1SRcj2cGVc GdkehAhCtCHc
QIiIlfuLlcY2hAhClFcAQtRcLIQIQgQhKl8OIYIQQYjohBJCBCGCEFlahBBB iFqS7XUHQVeo
ITayPWR7ppztZHvewPXUkE2Ebg/ZHrI92SyzMh4Tisg7WNneLppwH7K9vB0t nhq4d9neLhqx
P9meqr0/cPtCvf+R7VlDWWR7QFmgLFA29XqgLFDWsjygLFD2HCgLlAXKli4H ygJlgbJ0QgmU
BcoCZS0tAmWBssj2SBUh28OVcWVkexAiCNGGcAMhIlbuL1Ya2xAiCFFeAQhR c7EQIggRhKh8
OYQIQgQhohNKCBGECEJkaRFCBCFqQ7aXaAU8V/R8D9kesj1TznayvWCgvCn0 hBt2ke0h25PN
MivjMb5wO8GhyvZ20YT7kO3toh17l+3tohH7k+2p2vuDwBN9b+1VjGwP2R5Q Fii7VgBQFiib
x0qgrC4PKFuoAFC2udhzoCxQFihbuhwoC5QFytIJJVAWKAuUtbQIlAXKItsj VYRsD1fGlZHt
QYggRBvCDYSIWLm/WGlsQ4ggRHkFIETNxUKIIEQQovLlECIIEYSITighRBAi CJGlRQgRhKgN
2Z7RCvii6wfI9pDtmXK2lu2FaqomvI6PbA/ZnrSSWSmP6Yog7B+wbK/1JtyT bM+0oxMetGyv
9UbsVbYXDXxXuG4P2Z41lEW2B5QFygJlU68HygJlLcsDygJlz4GyQFmgbOly oCxQFihLJ5RA
WaAsUNbSIlAWKItsj1QRsj1cGVdGtgchghBtCDcQImLl/mKlsQ0hghDlFYAQ NRcLIYIQQYjK
l0OIIEQQIjqhhBBBiCBElhYhRBCilmR7iVag7xdlJ8j2kO2ZTHJiKf0z7VNP 62V7XfWv8Lp9
ZHvI9qSVzEp5TE97zAHL9kwT+u0pxe5Jttd6O+5Dttd6I/Yq2+sOgkh4UbH2 yPY2Q1lke0BZ
akm2l2gF+v0usj1ke6ac7WR7oVaAhp4Ioi6yPWR7sllmZTzGF1F0sLK9vAnd 6KBle7tox95l
e7toxP5ke6r2HV17NcNGtmcNZZHtAWWBskDZ1OuBskBZy/KAskDZc6AsUBYo W7ocKAuUBcrS
CSVQFigLlLW0CJQFyiLbI1WEbA9XxpWR7UGIIEQbwg2EiFi5v1hpbEOIIER5 BSBEzcVCiCBE
EKLy5RAiCBGEiE4oIUQQIgiRpUUIEYSoDdme0QoEwg9cZHvI9kw5jbK9/wdQ SwMECgAAAAAA
HFBvNQAAAAAAAAAAAAAAAB0AAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVn aW5zL1BLAwQK
AAAAAAB4T281AAAAAAAAAAAAAAAAOAAAAEVUU1BsdWdpbi8ubWV0YWRhdGEv LnBsdWdpbnMv
b3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvUEsDBAoAAAAAAKihaTUAAAAA AAAAAAAAAABB
AAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5j b3JlLnJlc291
cmNlcy8uaGlzdG9yeS9QSwMECgAAAAAAeE9vNQAAAAAAAAAAAAAAAEIAAABF VFNQbHVnaW4v
Lm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2Vz Ly5wcm9qZWN0
cy9QSwMECgAAAAAAUHVtNQAAAAAAAAAAAAAAAE0AAABFVFNQbHVnaW4vLm1l dGFkYXRhLy5w
bHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5wcm9qZWN0cy9F VFNNb25pdG9y
L1BLAwQKAAAAAABKUG81AAAAAAAAAAAAAAAAVQAAAEVUU1BsdWdpbi8ubWV0 YWRhdGEvLnBs
dWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLnByb2plY3RzL0xv Z0FuYWx5emVy
UHJvamVjdC9QSwMECgAAAAAASlBvNQAAAAAAAAAAAAAAAD4AAABFVFNQbHVn aW4vLm1ldGFk
YXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5yb290 L1BLAwQKAAAA
AAB4T281AAAAAAAAAAAAAAAARwAAAEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBs dWdpbnMvb3Jn
LmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLnJvb3QvLmluZGV4ZXMvUEsDBAoA AAAAAEtQbzWh
jgw8AQAAAAEAAABWAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9v cmcuZWNsaXBz
ZS5jb3JlLnJlc291cmNlcy8ucm9vdC8uaW5kZXhlcy9oaXN0b3J5LnZlcnNp b24CUEsDBAoA
AAAAAPh5aTXwZ0OKOQAAADkAAABXAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8u cGx1Z2lucy9v
cmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8ucm9vdC8uaW5kZXhlcy9wcm9w ZXJ0aWVzLmlu
ZGV4AQAAAAEAAS8AAQIAFG9yZy5lY2xpcHNlLmpkdC5jb3JlABJzdGF0ZVZl cnNpb25OdW1i
ZXIAAjIxUEsDBAoAAAAAAEtQbzUb3wWlAQAAAAEAAABZAAAARVRTUGx1Z2lu Ly5tZXRhZGF0
YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8ucm9vdC8u aW5kZXhlcy9w
cm9wZXJ0aWVzLnZlcnNpb24BUEsDBBQAAAAIAEpQbzXq0GC5SwIAAO8GAABF AAAARVRTUGx1
Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291 cmNlcy8ucm9v
dC8zMC50cmVlrZQ9b9NAGMcvTnjrAKi8TBQGhARqse5snx0jIRGpiIVUAYwQ Q4lS+yhuHdu6
JC1lZGJDFSDWfgQWPgETqIqYOsDEggRqPwBCvNzZV+JLbEglHilOdOfndz89 fzuVsqKApJRJ
kF8lcDyiiypxAz/uEHXJ66puREmypZTYNv8GE1edW/Uo9LsR5UsVRisd3rxh /RSUC/zySxQA
k9ejxVrYCtYeEdqg0RJxu0nbMd7Wn3/ZEG1K1uQoOKjGg5vZqfyMU/1PYr+c 2P5pPDlL7rd6
QVdoqV3qth+2/UFr/9767jmVzFkMc0Zubcahr68iw+SMUGJ8+T67k7aVXJlx toDRhE3IOfEw
54fgeDLHL+Y4PdLxWmszc9EKaS8QiowZDUITQwPpjfq1ujMNsQ4vImTqbI3/ hrjJgqK9gHTi
Fu0QuoLUxKYl2Xx2jnwTNjzozFCDYps7xAuHfHDig6BmIlwbEjJNbGEDamMJ ZcbTk4VyojJX
oQ1Ho9reOr8h+vaJD6/9uVEljPyo+s8uvxr0Zjk5Ue1ynAc9Ks3GTkajI5bW UFQsQDYyQ7fG
mszm1Jv3wuAAkCbj7dmGPSJw1KbKFjUMm7WO344DksrkiMy9uyQOPy2L7H0s BtI0NCpiG8is
jjmWm+GyMJiWbZaLbYqfYKTpwz7YMjFGVcsey+fr+vzjVKH09n/4YGSP+ljI NqtwPJ8Xd58I
n4+yT+HLgHJfhqfPoeidAv/6/0s5Wh5n58S5DeFzm10OCc7EXzh6Hmd76/UV wfmQeiRV4XeU
wW9QSwMECgAAAAAASlBvNQAAAAAAAAAAAAAAAEMAAABFVFNQbHVnaW4vLm1l dGFkYXRhLy5w
bHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5zYWZldGFibGUv UEsDBBQAAAAI
AEpQbzXpiIP6ogAAAGgBAABdAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1 Z2lucy9vcmcu
ZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uc2FmZXRhYmxlL29yZy5lY2xpcHNl LmNvcmUucmVz
b3VyY2Vzc9jY3ai8h0FESnXa88WT98kp5yYWl6QWKZQkJuWk8nIph6emKPjl lykYmioYGlgZ
GFkZWiq4BocoGBkYmPFypaTmlCS6VhRkFiWWZObnxecXpeulJudkFhSn6mWl lOgl5xel2hoa
mhmbGRhZGluaGZnyciXnpCYWuYA0YleelphTDLRZX6+kKDXV1tiAl+tAxO/P YDcGfu6p3l1+
zGEIuhkAUEsDBAoAAAAAAHhPbzUAAAAAAAAAAAAAAAA2AAAARVRTUGx1Z2lu Ly5tZXRhZGF0
YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUvUEsDBAoAAAAA AHhPbzUAAAAA
AAAAAAAAAABAAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcu ZWNsaXBzZS5j
b3JlLnJ1bnRpbWUvLnNldHRpbmdzL1BLAwQUAAAACAAaemk12qVEhkIAAABJ AAAAYAAAAEVU
U1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5y dW50aW1lLy5z
ZXR0aW5ncy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy5wcmVmc1MOyShV 8MsvUzCwVDA0
tTI0szI1UPAMDlEwMjAw4+UqSy0qzszPszXk5UpNzsksKE7VKyhKTUstSs1L Ti3WQ5IGAFBL
AwQUAAAACABLUG81kJjjwuEEAADsLQAAYgAAAEVUU1BsdWdpbi8ubWV0YWRh dGEvLnBsdWdp
bnMvb3JnLmVjbGlwc2UuY29yZS5ydW50aW1lLy5zZXR0aW5ncy9vcmcuZWNs aXBzZS5oeWFk
ZXMuZXhlY3V0aW9uLnByZWZz7Vpdb6JKGL5v0v/QZOOlE0Dtabvxgiq1tny4 gNuehIRQHJUu
XwtoPf/+vAPYo658GdmzF1xobJl53nm/n5nhywueXYne+oruXdHUHcXcMdQV p6hXDEVdX14M
eFZRJqz6qEvySOcG/HiicPrTAzvg+kPtTtOwaVt+iDXNt1cLyw01zQsWKP0v ep8bJtY7iEE0
EggidUvdtGmKotC7EXzNwn/8mx1yis5Lo9FYHOkTVlY4WSkjcPmPMcMhsr0F PFsg3whCHIR6
F3UQhdZkBTRNMRSsQNOW8dN4IWdGjvyFbTm+F0S/qDmQBH18D5/BNEsf03OQ 9QYfcwWm66Je
CpJaR5YkdW8qwE8VVRKyzDjh5AdBEnV2xImq0v/akllA+c7J+qMkcC3A2UTY DS0vQ2UfB3PH
c5GxwG4UNtOb6c30ZnozvZneTD86PYvWqBN1ok94Vn2QZAGYAM9zA3UMnflB ZgXuRZKfy1Cc
yI985NtGNPcCB5mebWMzgpWheWA4+MMLfgApYY7QHTMekEu8BpJMvgSBFYel +JbpBeTLcQx3
FsZEj0LjmOhdU7023f0kekUcjx2yE5WTT+B4xszwIxwcMLEuUfpQzaepOFbz RLyvXCsCNW4Q
rWnxH/vcS5eU/ofldpjLi6d7SVHi8Oi7K9su1pDY9gT1iIV3daNu6dtjuh1I VYHD66ok8UpV
wREOIxR5nh3+IntrV2C45Hk79n41/lwKnQQUBHSwcl0c1CEAwnVl2DUKeDfW Ro3wywhqQM3w
S7wJsFkrfgTlsg78BGDXQNnpOZGle+45vywcVvvAe8M/oFCQOgsCDxMzNydP ycZU0x1hoGsn
Q9h+l9lWH+57vPmr3F+2ZQivSWfbMzfFHC2y9SsNAUT68fKU0ClAPTXi82DJ gP9KJXiMn4JL
0t5RXg7eYHNFGv1BzP+VSLEMsw0BH1kO3qUrJY9YztycwJb2Cc2hDCzdrQEU xnTfa8BNGlmY
VYL2U1WQhhx/Qoo63gzbYVZ9KOX+WtgXGGBhG7l883fXKkjGSnFZHR98/oZp iq5PQrQrIcuw
ykuphhZ+ROnp7LrDdHql7QLzUMyD0+/NzfUuztGlsRN28JjsLiTxM/TyVmn4 hrlMtheQRHpq
HJ0Gm3TTXLumO/R1D8i6bb1teWPYTke2k5E5i3lin1lZZf+3RT1JIru3iTju TU54gN9kb/Yq
jMv4FTtz+E0CfeNYOpN4JilODAQRtfXQdrwf4DkOsGtCZq9xQDpHny7e0tRy MH95sbf5rqVD
gmop7dOTbnxG9pftwiTKyvoviZsc5xXESqU4qSwmjkZ5Kqrjci6KgzG1fnpO kCYL1UkFjXg2
8XirZLtqFXS3s1N7mJs+z7VN1r1LlWuaFikcAf6sIQGOz5ZiuecCygyhb9Ox KL1WidefK8v1
NtuYPe7frPVyr9xgSs7BzpXqO3odiaXiU7jW/mFZA9FANBANRAPRQDQQfwwE 0KA89vXJKlrN
wGZgM7AZ+EcPLDwd/r2vCxRcYtV1sXx5wY/vwSoqJyqgaR/NyKHYdgWsPHjs b24yX0utaz+p
kZshO24650SsetFUgEgc3TZWkecYZFAbJm8PDGqTEeJgXfkKutgyO5dlxz29 nxp1XJykuiZD
yipYBX5uhNHGN6LSt5gngbfDldvbvoPzL1BLAwQUAAAACAB7fm01n/CjnZEA AAChAAAAYQAA
AEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29y ZS5ydW50aW1l
Ly5zZXR0aW5ncy9vcmcuZWNsaXBzZS5oeWFkZXMudHJhY2UudWkucHJlZnMt jMEKgkAURfcD
8w8P2orMaLoQXERtAougloLI8LKR6b1hxoz6+hRaHe7hcjYnJjjzDDoHXVSF roocjtcbZEqV
UqBx1kdMfcA7BiSDMZ0xRMtUaymcD2NH/RPrtm142FHvPl8Ml8AjmkmKV8Tu wXGqGza9g4MN
i4Y9Ey1cGolb/fpoK62UyhJPNn/rbfnfUvwAUEsDBBQAAAAIADt6aTWHKLK8 lwAAABUBAABb
bWUvLnNldHRpbmdzL29yZy5lY2xpcHNlLmh5YWRlcy51aS5wcmVmc62NsQrC MBRF90L/IeD+
aJUqFroKLi7t6BLSlzbwTELyUvHvjWgHwdHpwuWeezbDnMTFLaI6irpp60Pb 7MS5H8S2qvZl
4cIEqMj4iDA/5IgRkgFtiDFEMDaHlQQjapmIT5/+B8VBKoTF4D12HBKWxTrw ATUGtCqvlkwb
Z7v6H2b27MGTZO3CDchNX/r16Z09Eip+qa+2LJ5QSwMEFAAAAAgAE4BpNV7c ARieAAAAxwAA
AFoAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNl LmNvcmUucnVu
dGltZS8uc2V0dGluZ3Mvb3JnLmVjbGlwc2UuamR0LmNvcmUucHJlZnM1y8EK wjAQhOF7oe8Q
8CYSUoWCgidR8OLFvkBMR43EbthsSvv2RtDbx/DPontmdaFRma1q2p0xu02r ztdOrY1p6wou
+JigI+MOxuCQ9AhOnoZ9U1fED/1PXr1oRwx9yz70YM1IlNnhQHE+Ti7k7+vk g4D3Sy1IkrIX
rJa6Rww0FwRyVkpViAku/9xbsZEoFFoWf7dOCp/y/i5pfNTVB1BLAwQUAAAA CAA7emk1o3/0
ne8AAACqAQAAWAAAAEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMvb3Jn LmVjbGlwc2Uu
Y29yZS5ydW50aW1lLy5zZXR0aW5ncy9vcmcuZWNsaXBzZS5qZHQudWkucHJl ZnNtUD1PwzAQ
3SPlP1hit2xQQRRlQHTpQBrUSpmNfU5d0jg6n1MG/3hcAaIt1W3v4/Teu9ls I6v9xMQjk7O5
fJjP7thyvWG3QtyXRQzwFp3+WDhrGwTbqA4qwghlQeq9dYa2DfpRdYrA/BBj BnxQ/QoN4Kvr
8ITz2HHQvRsD8J0hHh3fqUkZr3uvFTk/BL4/t+QIz8Pg6Zu9CHH2zyoNnOCT rB+okunFR3SA
rIZDkiKJ1C7rxapdJ5nExf0hJ6anq3nBOPLIc31+OPavrqqsx70iAsxrWNdD 4BNgyA0qKcri
VzzmNoAw6FO+LI75/836BVBLAwQUAAAACAA8c281ie4Lau4BAACvAwAAZwAA AEVUU1BsdWdp
bi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5ydW50aW1l Ly5zZXR0aW5n
cy9vcmcuZWNsaXBzZS50cHRwLm1vbml0b3JpbmcubG9ndWkucHJlZnONUsFu 4jAQvVfqP4y8
l91DDaGlqii0oiFISLRFkLJ7sIQsMqRZOXFkO5Tu1++YBNpK3VVv9sx7b56f 59tPTOBBbyHo
QnDR63R73S5MFjF02u3L0xOl11I9a+v4UIDN8lKhgFIai4bP5o+jpzBezaNp NFxEg4AHXyMs
o/li8vhQE8oiO38JLi55FC8EmEqhPRAEbAPe5ptM4aqU7nkwFj0h4lk8E2KY YuFCXTijlSKo
IDpXOv2/gzepkZfCtcpKi+e8Q+ed9FArhH21JBRwt3PXpycNhpcGN2iwWKPl WzQ208Xgw3u/
4H/05p8m2KPpa6+TWnR20L/d5QqaAWLASIABTdVJVqR0f4rHZ1fs9gb6DeMG DkcoZI4ESXAj
K+UYNAevwogw1emYrEQKc8oOwLum3vEFDEptfOUsYJDrInPa0G1Uq9zXBQIZ /RvXHicESQ4L
qV7/oJnVZQaZXUqVJdR3pkIGlcWpNCkSdlGVzYiNVJZ6dU4TD6YoCDHbF2g8 EiPZfzL1GFhU
JI5HVXrOVqoKAfaTjhEzoLI3/Y+kWcvn9Z7aRH0gEg4o8+/7j/zh4f3Wx+B8 pQ7cS7UO3/B+
FUKdU34C7qSl3Yu2/hWw9LsQCPh1PxVALAHetf18PXTlysrRmodkaBXeRZzW gtbkL1BLAwQU
AAAACABLUG813niZcGwAAABvAAAAWAAAAEVUU1BsdWdpbi8ubWV0YWRhdGEv LnBsdWdpbnMv
b3JnLmVjbGlwc2UuY29yZS5ydW50aW1lLy5zZXR0aW5ncy9vcmcuZWNsaXBz ZS51aS5pZGUu
cHJlZnMNybEKgzAQANA9kH846C53sRERMnTo2kWhs8QTQm0SLle/37713d68 waucQB4IJ3ST
Q3jOCzjEwRqOR6qNuyq8s3CO3LqTpaWSA1mj/3zkbZEUPy2o/Niaeqy6F/nO uioHoqGn0XmP
o79bcwFQSwMECgAAAAAA93lpNSC18mBPAAAATwAAAFQAAABFVFNQbHVnaW4v Lm1ldGFkYXRh
Ly5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucnVudGltZS8uc2V0dGluZ3Mv b3JnLmVjbGlw
c2UudWkucHJlZnMjVGh1IE5vdiAwOSAxNToxNTo0NSBJU1QgMjAwNg0KZWNs aXBzZS5wcmVm
ZXJlbmNlcy52ZXJzaW9uPTENCnNob3dJbnRybz1mYWxzZQ0KUEsDBAoAAAAA AKihaTUAAAAA
AAAAAAAAAAA0AAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcu ZWNsaXBzZS5k
ZWJ1Zy5jb3JlL1BLAwQKAAAAAAB4T281AAAAAAAAAAAAAAAAMgAAAEVUU1Bs dWdpbi8ubWV0
YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuZGVidWcudWkvUEsDBBQAAAAI AJlTbzWs1WD1
KgEAAI0CAABFAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcu ZWNsaXBzZS5k
ZWJ1Zy51aS9kaWFsb2dfc2V0dGluZ3MueG1sjZJda8IwFIavHew/lFzPmjhR L9pJaNM24JJh
K3VXodZQi/0YfrFBf7xVYjdcBclNTs573ic5OcbkO8+0o9zu0rIwAdIh0GQR l6u0SEwwD5zu
GEzenp+MnYz3tUQrolyaICy3m2WtW4M617lJlttEl3GWfu2kvpLLQ6IfUn2K 58zyhMWZQ935
DAeUM1/YFE+5K3xineOLWcdI9zLXNvLHBCq9EHxGXcqAdoyyQ01AqA96t+JW 7BWAfU+EhLpe
4AvU+PRfR/99VInDWSAYfie/1CqI1mUeVeMKViFlNg/9ClVdhOr4vAYQqt31 BKqSuxTvcqcG
MRzABx9GFh+Y2cQWjNvEbwxetLuoz9sutqCUNKR24DW6MXz0Um3d7jc+o6H6 NaOnBuY8WH/2
J1BLAwQKAAAAAACooWk1AAAAAAAAAAAAAAAAOgAAAEVUU1BsdWdpbi8ubWV0 YWRhdGEvLnBs
dWdpbnMvb3JnLmVjbGlwc2UuaHlhZGVzLmV4ZWN1dGlvbi9QSwMECgAAAAAA eE9vNQAAAAAA
AAAAAAAAAEAAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5l Y2xpcHNlLmh5
YWRlcy5sb2dnaW5nLnBhcnNlcnMvUEsDBBQAAAAIADNXbzWOB4E15AYAAOQg AABQAAAARVRT
UGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5oeWFkZXMu bG9nZ2luZy5w
YXJzZXJzL0dMQTU2MTE0LmFkYXB0ZXLVWltv2zYUfh+w/0AIfejaRZbtOE6E uIV8awO4SWA5
7TAEAxiJtolKoipSiT30x+9IomRJcWz50gArECc+5Ll958JDopcfF66DHknA KfM6Sl3VFEQ8
i9nUm3WUu8nw5Fz5+OH33y6xjX1BAt1IfiNg87guqR1lLoSv12pPT08qsRzq c6KyYFabL7FN
eI1bc+LimuRVF9xWpADLqsjbY67PPOKJHvOmdBYGWIDFeVFkUVHUYCECbAlW MGTqiorsQxa4
WJT8mM9wZUc8QRYiz8z8irw3ofDDsmofB7xyCG7jzQX2sCprwCzC+Z1HC8Zz 4nFWVb0Zb47Z
IakQugTcdIkIjylFGgJeK6C+iLMzJV55XGDPImjKAiTmBFlhEEBqICtNEkji BbFCgR8c0nMw
5x0FjMkMS4xSHTabQZ6rMotV6vqO2sWcWlKTgiIScUFinG69gMS/+1iQjtLQ tLMT7fykfjap
t/TThq41ygxfC4Ul9Y3II3E6ShMoHnZBUKwSZd4VJCgoYA7ssVKLoq8V7Ii2 FbWHHv0Rkqt+
R7keNpu9+rCu9dvn9Xq/e65p2sVAu2i2Wo2h1m8oMhJZLCSqxWjc+CQqQm+G zCUXxEVT6hCU
pMN++Ce8XDWB6JAbcwgCTSnvVQJxY6JIJ0qVJtDz3LfjIN98EflaJegnc8oB YdnGUMgJRwGZ
hQ4OgOwHUKawDyE/7lMeR4IhaoMYOl3CRosFNgh0qEthme8XrEw9V8eJ6kGm OeuwrxQ3aQBa
WYByJiRRdGEBz0iJfpx4nh4Yz/Hz2CVdfb/QJLxcvZUyXiUGn4hHAmhjqdIE dT/37ThYtw7E
utcdoOwI3w3fFFfqRVWFnQzwaSqPqyNmYWfEZtDFWSBAWU7Xq8Sh5F8ShmmR cJxInB8eiajb
ZkPNfsnOUnaugkBAPifvtQAvuZFgzoqE42BubMX8spabn5Ihq/Zsyrq0LL0w SJfPF7KapZAT
eQzfc9u5HL3gGIqH+qidPrNV2zZfSCsis7KRzppHRSbSu0ekFmaMkIVczhuR fSIIibL/bEg5
67HQE8Gyx2wIxp0Z00bYm4VwRCREAqOXixfUDd0r2yET6iZhg6j4GE7cq6gJ PGJIhfq+wxW4
n0waRVcMxOMBqDhQ7TBEJLGC894i3XA6JYFJ/yWRnY1TJRY6ZEyk1Ast87Pr MOt7fPFrKUgs
fVhNRrHcIJZZD/b7oQ6XAgiLWCJf/nEd14RNYcqArFgq2cJX7ISw0tfvJ7eT 23uoJp7rExul
RSZHfz0TtrrJgTi1XpSXAKeXPUCZbSVjUKpmk9zLWha0FY0s9Izj1w5qO0we ceVg6vER9UgX
ms93nhYO8ezbRGFHeQOp71lOaJNBjprskwumwIEoLTmpUHPpPjAoAuhexHew RfLqptjhsJkX
BPyThxPQTAaGXQ76QtbE3Po4dMggad1gth29BUgxZy8jRHlvTh27N2fUIpm1 lI/JjxCSxO4u
wTaQmC3Jhs9cl3lwaSODx6if5MzZbFCr3uxd9EB321hvUCKfszCwSHZoXtlF DUUdhhABfQgF
gTyZ4tARsjSgUuzQippdXnlfe1n5Vr9zHRQS+TYgjxTa8hcsrLkZPnBBRRhl vcH7iSUpe21/
85OqL7pQP4YLV/YE+tsrODIh2LVIdFaggQfzA4Eh2ZuVfWocw6df5lHR1uYB tsIBI181djKz
ZCXYmd8eGQtHGAiB5vJWffcHdJx0GXTKvoSeqJgjKC0kb4IoeU8BQ7ohdWAC GYaelZsvnmFT
WwfOHgCeHgHAPWL9fwexWFfXRrmGWgfACq72jtLdCv7J/l/5fDjtG93zVhv8 6G48H8CUpIo2
4FaW3W4Nz9pnxjbZYxJdW82XNFSLzeCvyWB8bYyUkvbuy9q3RggmCs48aJ2m xQ5uc9XcGN18
KnvQO8iD+EUArn+zeDA+rFFvzbNdEvF5p0pmp/am2WnbsSTvu9HF6bBOtaFP 3dvv779lHxw+
dPkTU/645+q7YiN7U0cnWju6xQkwLHko6ShL+Hfy5cuJbaPPn3XX1Tn/0zRN 9Pf61ra18td3
ts2Qd41ms9/eMAnI6ofbeEDFrglUGdN7MwIy+njbH3TvPv28uh7e/JyMjd5g DZzx3bciQhW1
fjPG12s0NY+vaTAe34zXqGodX9XQmBijNarOdlB1cIY1Ls6G543BtjPA5bNf n1zxR1Sl/P3z
aeNN/YiobOyE8X3+Nl5f0aau0LMn1I2vx/u9iYLK7LWwKH71WJF7TtzhEVC+ 2oySp0pjBq6u
BOUxefmxBUdM619bJiaSklEsuvjewnx9rd5oVEWZ1M1i4nBknJIcE0vvhPFS urB6lwTyZa30
XxU+/AdQSwMECgAAAAAAeE9vNQAAAAAAAAAAAAAAADkAAABFVFNQbHVnaW4v Lm1ldGFkYXRh
Ly5wbHVnaW5zL29yZy5lY2xpcHNlLmh5YWRlcy50cmFjZS51aS9QSwMEFAAA AAgASlBvNRBe
ZcKVAAAAHAEAAEwAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29y Zy5lY2xpcHNl
Lmh5YWRlcy50cmFjZS51aS9kaWFsb2dfc2V0dGluZ3MueG1ss7GvyM1RKEst Ks7Mz7NVMtQz
UFJIzUvOT8nMS7dVCg1x07VQsrfj5bIpTk0uASpRyEvMTbVVCs8vyk4CqstQ Aspxokn65Kf7
JZZlpieW5BeB5TltMktScxWyUyuBkp5+3vF+jmGe7o4h/kHxIf7xri6eQJaS QlliTilQd1pi
TnGqkj7YXH2owVgsCSlKTE6lvjXIbABQSwMECgAAAAAAeE9vNQAAAAAAAAAA AAAAADMAAABF
VFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmh5YWRl cy51aS9QSwME
CgAAAAAAeE9vNQAAAAAAAAAAAAAAAEMAAABFVFNQbHVnaW4vLm1ldGFkYXRh Ly5wbHVnaW5z
L29yZy5lY2xpcHNlLmh5YWRlcy51aS9maWx0ZXJyZXNvdXJjZXMvUEsDBBQA AAAIAAZybzXq
uPhYKwMAAEQkAABSAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9v cmcuZWNsaXBz
ZS5oeWFkZXMudWkvZmlsdGVycmVzb3VyY2VzL2ZpbHRlcnMuZmlsdHhtae1a XW/aMBR9n7T/
YGXPjYFu2oZgVaGpVqlru8I+Xt3kQqw5duQYAvv1uw4EQqEfEhRWyBMovr4+ 597jE1vQOBlF
ggxBJ1zJplN1Kw4B6auAy37T+dE9P/rknHx5+6Yxinj997cLYj9n4TUbjglk UsfnTSc0Jq5T
mqapq6K+q3Sf4pxZSLIYkh5nEbVKpYphlx0/hIgdcZkYJn3IZ33loJn2w7E3 MiDtuslCFvAF
jxPIUoVjFkBCIxWASGiYzzyC2VQXceaZwVcaHswFUc9Cq1HPhjlYA0IaK8DU OzyKBXTAPv8+
AD0mkkWYF5PMEk6AuUYzH9whhzRxb7TqcYFlPufCgO6OY0Cu/RASQ6oVcscS IIZHUO90HRKx
kScgAmmQfLUyQYN4lA5AtxBNrCFDQ1SMCI3STefM67TzQBtqB2RAsAt1g4s1 nYfJXE9i57Nx
fg+YGWgozM/qV/dOjdH8bmCwY6GG3jObMykFduMdpd3b9g3z/7A+UEu7i6wd OkdOp9Bz0nSJ
9aQ59Fnd2V0jT8+mrLa4uj+IBoIZPjxEMc3J75ek7jd1J8JiQhyYmpBxskci sg3chXKMMkyQ
hP89MDfKeHeQ9v5oqNDK3SkpPzAmByini5z7vmlq3tT1hWViE7sxvjB7Skeu UP0pkEtVhNAJ
VUpAa6UJhhBtexagSqQYW2HlxUxD0DCppEXwhEhwCY5GO493CrI7vTorqI7p /iCT7Topr28X
lPjcnC0umR6vTtnyur8876qYFzML6Jnr9fZJlmfDe8W/y3dKu+W1VRQp2cLz tzfEItAE8OLK
zbiwVzIMtEBmcUSjLPORp2q4yJNolv5kYoDBHypLrId2xKrucW6LV1Ak5aFI tVnCvwDzBRh8
3BmDBp1JuOBv95816L1duT1/W99btupvKdMSnbd0uNLhJiMb8YfjV+9w7z+X DveC7rJVj+PS
xjBjvav0udLnspGNuMSrt7laaXMvbTA7Oc7Zvbt0vCy9rvS68ta6CwarzK7U dXlXKe8q/99d
ZfWr8/G3uP012Qo5aCutQWQngQ1A8qfZIFh5b9neseIxINPKNOj0D0H4/R9Q SwMECgAAAAAA
eE9vNQAAAAAAAAAAAAAAADIAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVn aW5zL29yZy5l
Y2xpcHNlLmpkdC5jb3JlL1BLAwQUAAAACABKUG81SX1iFU4AAABzAAAATAAA AEVUU1BsdWdp
bi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuamR0LmNvcmUvdmFy aWFibGVzQW5k
Q29udGFpbmVycy5kYXRjYGBgYoAANjDJ4+rs4xkQ7Brv4e/ryggUYGTg9gpy jQ8Ocg7y9w8B
iTAxsINEfDydQDxmBj6vUD/PEJAKuCYWiBKgEIjHysAFUQKWBgBQSwMECgAA AAAAeE9vNQAA
LmpkdC51aS9QSwMEFAAAAAgASlBvNeb4joxeAgAA/wwAAEMAAABFVFNQbHVn aW4vLm1ldGFk
YXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmpkdC51aS9kaWFsb2dfc2V0dGlu Z3MueG1sxVff
b9owEH7epP0PUTbxgDRD+zQJGGL80JjaComufaxMchAXx85sB8h/Pzs5KKxh Q1ohL5Hj3N33
+bvz6dLubmLurUBpJkXHvyJN3wMRyJCJRcf/eT/6/MXvfv3wvq0hMNbEEzSG jv8o1XJm7SLf
fnvXZgZibwlZx7/PEvjOQFEVRNkDg/WEKkOi7c7K7vjeivLUBrn2Gyd5S8VA GOrgd75N9D2k
9YOu6JBDbM2n4IL08q+6YNlA4xJHqRYEAs4SDeQ5NCRlhAkDSlBOEhos6QKG m4RLBSqPtU86
zvHkjlqNm9aBqrVfqTQtK22xeNG3eM9FLpbd2sK0ah83zUH+7LVcLMQHxPeY fmQilGuXAxtl
CgYDGZUCQnCayXS7f42bJYfE2JpwJpZGQsiMVOi2paukNLcyhO05cHu9g79z Eha7+Cw5RZBq
I+MR41ZV7aUa1ADmTEA4ocYJrYeCzjiEGGhOuYbj0ay86I4RSyEjxkNvnhuM t4FLRJgcJphM
Xa0FuoiMp2XH+TXeErsvbaW7c92wmb0G2flJ7Oq8hM0wTkw2FgIUfvkrnZf6 e1tJuNS2TJR8
tle2mqxcLBkl2HdSTNIZZ0El6CMGPKxG9HGcSGUG1oqqvPlXUHxPSdGdRuj4 VP9UJ5aQ1mei
kYTgaHxjwtYb1nwBfnUE8VzyTzNhIrCN8Bbime2wVVx9fL9kDfyzHZ7SCc+U k1fVSOqXzYft
RdOIqoq7cT/tibDvLqGFryQR5EYGlLtptRoFbB7cqFtpFpADjtv/RaFx0jjX OBghSy3+GJWd
Df4n7M3+++vfUEsDBAoAAAAAAEpQbzUNvdb8PAAAADwAAABDAAAARVRTUGx1 Z2luLy5tZXRh
ZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5qZHQudWkvT3BlblR5cGVIaXN0 b3J5LnhtbDw/
eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04Ij8+DQo8dHlwZUlu Zm9IaXN0cm95
Lz4NClBLAwQKAAAAAABKUG8158Vxv0UAAABFAAAATAAAAEVUU1BsdWdpbi8u bWV0YWRhdGEv
LnBsdWdpbnMvb3JnLmVjbGlwc2UuamR0LnVpL1F1YWxpZmllZFR5cGVOYW1l SGlzdG9yeS54
bWw8P3htbCB2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCI/Pg0KPHF1 YWxpZmllZFR5
cGVOYW1lSGlzdHJveS8+DQpQSwMECgAAAAAAeE9vNQAAAAAAAAAAAAAAAD8A AABFVFNQbHVn
aW4vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLnRwdHAubW9uaXRv cmluZy5sb2d1
aS9QSwMEFAAAAAgAPHNvNe4fno5KAQAAXQIAAFIAAABFVFNQbHVnaW4vLm1l dGFkYXRhLy5w
bHVnaW5zL29yZy5lY2xpcHNlLnRwdHAubW9uaXRvcmluZy5sb2d1aS9kaWFs b2dfc2V0dGlu
Z3MueG1sfVFda8IwFH12sP8Q8m7c3MsY7WSzlQlzFq3spVCyeq0X06QkqR/7 9UurTgW3hwv3
ck/OOffE620LQdagDSrp03t2RwnITM1R5j6dxYP2I+093954BjLrIETyAnz6 qfTqy+GW1O1a
nkBjyQp2Ph0WpdL2XeVsGo8nYTodzyb9MP14GYXTdBg08JaHFgqy5qJyVMFT kq1XSRzFUTJ8
HdWVRlpZlUZc225S5aapGHiRgbSg26HMUQJo55F2rjJCJrA08MC6CWx5UQow fyAbXaHyf/eq
smVl9wivU1/bdJeZKJ2zgy6zpS1ZoSRaVbtkTqBChrV7yQXb4DfXc8N+0xqg gH2UnQPpFQFH
EoDlKEyA3A3nYTbhm6Xa9LmFXOkdPd6w4MLA8bjTRy1QODNvbq7Bzfbydrsr gaAknDgpUk+G
7B8dyU5BnJk+738AUEsDBAoAAAAAAEpQbzUAAAAAAAAAAAAAAABBAAAARVRT UGx1Z2luLy5t
ZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS50cHRwLnBsYXRmb3JtLmxv Zy52aWV3cy9Q
SwMEFAAAAAgASlBvNTpJR21aAAAAfQAAAFQAAABFVFNQbHVnaW4vLm1ldGFk YXRhLy5wbHVn
aW5zL29yZy5lY2xpcHNlLnRwdHAucGxhdGZvcm0ubG9nLnZpZXdzL2RpYWxv Z19zZXR0aW5n
cy54bWyzsa/IzVEoSy0qzszPs1Uy1DNQUkjNS85PycxLt1UKDXHTtVCyt+Pl silOTS4BKlHI
S8xNtVUKzy/KTgKqy1ACynGiSfrkp/sllmWmJ5bkF0Hk9aEKQAYhsQFQSwME CgAAAAAAeE9v
NQAAAAAAAAAAAAAAACwAAABFVFNQbHVnaW4vLm1ldGFkYXRhLy5wbHVnaW5z L29yZy5lY2xp
cHNlLnVpL1BLAwQUAAAACAAmhGk1Y3TT9EcAAABQAAAAPwAAAEVUU1BsdWdp bi8ubWV0YWRh
dGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UudWkvZGlhbG9nX3NldHRpbmdzLnht bLOxr8jNUShL
LSrOzM+zVTLUM1BSSM1Lzk/JzEu3VQoNcdO1ULK34+WyKU5NLgEqUchLzE21 VQrPL8pOAqrL
UALJ6UMlgWwAUEsDBAoAAAAAAHhPbzUAAAAAAAAAAAAAAAAwAAAARVRTUGx1 Z2luLy5tZXRh
ZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS51aS5pZGUvUEsDBBQAAAAIAEtQ bzUop/w85gQA
AL4dAABDAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNs aXBzZS51aS5p
ZGUvZGlhbG9nX3NldHRpbmdzLnhtbLWZ3XOqOhDAn8+duf+D4zuUT8FOe89w FSm2ikdtPZ4X
J8WoqUAoSdV2/ONP/KytWBWoviDu/rK72WwWcvVz5nu5CYwIwsF1XuSFfA4G Lu6jYHidv29X
OD3/879//7ki0KVMJBcAH17nOzgaPzK5UZ799+PKQ4TmxvD1Oo8CQoHnwX4F AvoSQbIU+HGF
KPRzE+C9MGUcDXkQAncE+UdA0ZgP+4NLkS/wAj+RBKEgFESZEyVJ4ARdkSRd 0mWVkxVFyl8c
h6UCQddDIYE89Ad8H7uXEi+9syRNFFTtFFXo4gjypI+zgRD8ErkwNScpINXw SdSGkA3aH1/K
H1QLJ6mtbD1f81yVpz6NHUwo+lxFI8GzOJghwP1RfjdOQKVnQH8ZMnGHo8pC r1mSOK5i1vSG
rlunUVZOxYL+AFJ9q1bh2wmgtARCGUHdDYokCwI37nBO75WUmndVMqvSY5iw Dw9O0/JTePtd
ZRa9VZ9PQKVneIAOcOQftMkYOnAWFEaeeU8m/zun8lKDIjc8aFProVwfPkR1 POJq0LJOQKVm
7K3+BcOqPxfwr2dOg4Tr6uIxBg1pyPs4QBRHbDNblGIekcmlsssVJXGxJ+zs D7ImG0nQLwRG
38GGM+CHHiTfZfuG/x3sMMID5LHphBHrMDYJpvAiLwo7W7SoisV06HhmWvMj GOKI8o8oou+2
7wYpkeU71Dgcx0mNss7qdcOwjJrRPRefmaHxxvUcv9V22k6/AGTQPAm5LXog AN4rQYRn7SWM
4ATBKf8EJiCtzUcHiHdFtIqqaqmWZmimVks4EgyGKIDZe7DifqPhWVscb6rc tQ2ja3TNmnlv
js8jL/vWL6v2NhAl3ShWE9IPF+40cV413XExVgVWqM6HxVE4rvQsPLqhG4Z1 /1dwJvXL0MqO
oWmO5hRve7Zx5jr/Mqq64d7emqgysLs2MvF55G/ZDPfo2ZM9ml2RY6zsywLb Th/hGNHsW5n9
IbIKxAaYfeU5rW/Rz1/IR7oWfbWoEzQA2xEy7FnimNln3hp+IMYJiuUKGE9K F1uyLj5ZxZXE
lpvkXeA7mAKKCEUu8PgXlL7vPgCOJ6ZLBxoBN7t2aknLLL4UEpr5Y+QWmmnV XVIzrAWfednG
dG9hJU3UXdqh7EwazSwiSDH2UtePd1KmsxAPU0b1cnlUHtkt27Wnp8GWSzjL 5PsMzM7vj9Um
cdqty0wG1XB64L3nvdIuStLrk9Mh1q161LsZ6Sc9e1ioJn/lz7QPq11dLA6K llcfj5PMGYUR
e5BsRPiJ/WH7i6nuoDcQ9XfPj5YnTKvba0myEm2AIeRbbadp9oxm6cZ+MHst 884stc1yfmPl
AHgEfjD/FFzJaXR7jaZTZbCeHUu7ulg7E+NYaYQxgYvTMhKyHCkj4OFhC1KK giHZc61sG3eO
1evY5fbNdiRF1vetXkvemLZ1096KSopyULTi1Nu9ulEzt9LivA1G2AdzfS7M O3a97HRac3HO
iSL7vfgqgrC+2twR1ioHR/ndc5q2ZdffTSrKB4W7e8KCdjykTbjKzjqYoCGg ONoL40biAcEp
a99XE9lymu1eu9vY8X/fsI3mYsLYDLGJqiCPbhkdp3lr1y2WW+8xN4bDCDI7 YI51HLkpCvp4
mhPFgiwUVFWRVU0/7tLuAmL92uK9FVk+3njQz39W3r3+C1BLAwQKAAAAAAB4 T281AAAAAAAA
AAAAAAAANgAAAEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVj bGlwc2UudWku
d29ya2JlbmNoL1BLAwQUAAAACABLUG81TCCDOwABAACfAQAASQAAAEVUU1Bs dWdpbi8ubWV0
YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UudWkud29ya2JlbmNoL2RpYWxv Z19zZXR0aW5n
cy54bWx9kE1Lw0AQhs8V/A9h70705iGxhGYrgWpCEql4CWs6rkv3I2y2tfXX u0kqfoBehhne
l5ln3mh+UDLYo+2F0TG5gksSoG7NRmgek4d6eXFN5jfnZ1GPrfOWQDOFMVkb u332vlfitdkv
MVOdsY4ehpqMwuiaRcKhCrZ4/GkpGEeo6rykTUVXdFHTtMnuirysm3X2lJR+ SkmwZ3LndxvL
AVspuh7Bda4DZbRwxnpckIbvBAjt0Gom4U28M7vpYbq1MnwpJJJwQpGid/+i 0MciuU+/UBZJ
TW/zMqPV9Mzpm7+wOsnci7EKWuaQG3sEZ1mLIMZrnxThgDEmGJ4iHKL+1n8A UEsDBBQAAAAI
AEpQbzVzjlWX1QwAAPhOAABDAAAARVRTUGx1Z2luLy5tZXRhZGF0YS8ucGx1 Z2lucy9vcmcu
ZWNsaXBzZS51aS53b3JrYmVuY2gvd29ya2JlbmNoLnhtbO0ca2/bOPL7Afcf BN/hPiyw8iPx
I7jN7qWxs5tekga1u71vAW3RNhtJFEgqjvvrd0jqbVmmZKe3CxQFGpHiPDgz nBkOKf/0y6vn
Wi+YcUL9y1bX7rQs7C+oQ/zVZevT7ObHUeuXn//+t582lD3P4c3aChhdMcz5 NQ19ASAXrRS+
B/C50VfOC+GUtVUn8R26sdaYrNYAODwbtawNccQakHR65y3r9bIF5Lfyfzl+ ibj4neDNGAlk
xY07ukBC8yphFOIAyAd4IcgLfoeY7CECe1PyFUuU3UFHD2vvjltQ6s4Ru0Nb GgrLpYtn7MTk
5btbwGMR6FoxGgb2kri4ZUnks22AL1sC/v9VvrlH7BkzTSYHR9nKxguXBBzb IbETuZSimgEk
MHZNfcHIPJTTVEK5GCmp9HolBJDjEDmQN+fLwfNwJblzUShVtpD4pliYstet 4i9LaL1FDua2
YGiBbfyKFwqH1GptmmfDBiTBcqXYGxEc9RsQZHiJGai7GUnTOX5xhNTee/SC Ji72sC+uGVaL
pDZJU01+4cLecHsBdhd6gQY3nNSFGQWOEYNlov/Unsega0ZFBCKwAxeJJWWe 7dKV/QKa4jbx
BWY+cmXXm+oO9PYZfAJ4W0Bem0q/Y0ZlA+rimIGblgSTyW3wfM7oBt7YqPYE K/SonaWPXk7k
KwETWSFh7C+7VYtVM4fBa1JWjz8NucZucKJ5laHaN6cftUXDHx3LcpFLBUG0 whZaQWiWokqN
6hY4uIq7LbBzK4rD3e7grDPo98/P+kNY9ku6CDnwwEKQs4vm2L1sSSw8AE9m /WhJ96LiohYd
Tx+vwNtYSIVVCTCn9PmyNcZLFLpiokbE3Qqe+EtqBYiJqkFL6jqYWSgIwAEg 8KCgVchMXgPk
OzJE99SoAPIQcHfK15WJOvueq4WmBP+Y6b4BxinbRlLVZNWjZFM9pJPMNNX0 la+IH8roS/9I
XWxf67/Sk7TU1B+QBzOKulsxiimwhDUjslmFWbupR0bn4PGLeKNunkdsLagb ev5nmXF1QIL9
QSvb1YUY18319EDmhUFn4FrzPecqZ1tTRr6CySL3kXKi87OOygsFWeQ79fKQ 8B+YVHHm+RZ0
q3LA9uFBXZNBPZNBZyaDokyznUjzsJZymUDic0F3j2NQ0BfIQyevgUsZ+Iy8 7iBHgaVr3VNf
+ai61hHRlcEs6+wjJ0qZfUdXD3EjSxr6rfRFjqxsTP73ePUwfprOrmaT2sLI 5CgOXRQNNurW
Mq6Cl37yN4KZTAq2WQxpZ97m18TBS4JdB1zbErkcfJvsgkwfudLd5rt96gfh 3CWLXC+XniLt
IvyzcqCpi429pvfyFFv8E18w6rpqFZTMA3zqM/hr0BLxnyUf65h/QbWDiSBJ 7KeknVpMPsKT
jPt8TcGRrzGD+OEkzMFeS8y3cs4+8CZUWIlelbEmBSWXibVJJqPl2TIwtIPJ k27e6RQK79ia
soK61h0JcEpDtthxqGMYhZSQ/ApbStynDLIg3w+hADXgLKK4q7Fn/oi54rB0 oe1ZZNbd7cN/
nx6ufr/99Wr24ePT7MPTZHwLT0pVUrOYSccngcBHQIv//K9/vHau/h01LazT /8vWDzYIgss9
IZ/4CIJBYiHtFDodbr+fzCYeERJlDkbZdSnICvuGI+0f9rHRjmcBz3Foj2cU gYPUZH2gPZlN
Y3+oQAuvwZyuwOK2XzGLfGtEIUELDQ5AKs09SKMdJSZR8ynwyWDTueg8wT9w 6Ivg1SMRgRRp
M4/4qD1BaSjQr6zkXd5a9vshVyWFal0f9D1Zd8MohSk7Otfa8QiSOqSIgno3 Wm1WCDuHsXQ1
2HlE0nj8opolzKvnRoNuUnUv1sR1LK3/WyPJ2FPlhrlGss+kGuCVXgBJ9u7I HHzw9jgCuUBf
oDSBrfL21vfBSPWbElLpOmoyFZdy0IVeAaeX1EkEVIL3gfqPKuyeHPONCv0n R3vrBeCNM9Hm
xIp8CvRyuolgnn74Z5lHNyMROCouvSM+6C6yDY24e0KRTLe+WGNYoPfYm8Mi P7VpR+1Tyfzg
Mt2/Qo+S045mC9HxKBnBOpquEXtDD3AdXvnOtTREQH1y4diyuO/KHP/0nINs 5C7jzSQT4Y8K
sNXo26UhsZ0LrhXphHpQAzIHGjyqwDyqwopJohGNT1Hs3bFlxrQKZK20OvI7 4QSmqpKHJXnV
Bynp0VDH7nQHChx2VAtGAgCzlE+rXp0FBuJ6TdUOM8tvXMpS5SslfeRu0JZ/ SIvjpZWbNUaC
rzEWPFMbNYTfU7s2py6Fagv8KlLaNg2wP3nVcpGL70h0yPep3llGu5Fkz9QY pX8qRAvqy83q
HSyQMXYJbExAoTNaB2skKEGpy+1YbLK2yutpImXqGW8hhMpzUV4Dvqy4bwod OLDyJRJOl2ID
fv2T6jEmv/dczxA+s6KOgd17JmUuxchEcW3YRATR0V9zBHNg/zmg4JkaySLB 8348G8vnRli+
hLAftd9/gv+bzwTJjTInvIBB1pOeZGR50jZvumGtBZyv39UCzVR8asFlS45m gJH7DuNazlS1
ayAIyyv/xsCl1ama0NmjgZqgu7WrmghmiD/fEW5qWFme1c2SGkwjX6TwV76o ASr3RSz0BfFw
XKPUkD7AbMhXxJwDpqUHcfsBb6JVETu5z+pNc3QqxT4VsluZTS3R4mTcTfzQ OxWuqyQPORVG
7Shu1EneyXD6JAiwTOsbCjGDDgbb+pyxKXCS/RmBRgeWCYpPYPICtiQzSJLk hOrLRoehjHhm
mItrxEtlk9ks7MO596RM9WSzeVOMezYDpuBJrFSh+kgG3skrFpAD7qCRzqlW lK0CKImspcP3
B4gq7DtBtGpwMVJX81EW5tzkVoOHiK/L3LKlrg7otRPXuvVFAhcvRe7ewELv hVf4dmwk39xN
g17JTQNZiF9oVs0QRvvOnSJ+2whd4aAzQlZQ8H4sFbE8xnUn/zxQcUND3zHh Sq96QBi6OsxW
YTrdxQzNGNMJbSdmNGrHt2Gy+FRHyUWOvcZT4C1xQHKSUwH6+0/37GLZmc+T A9iOPTy/6Hd6
F4Oo6w7s77I17J9H7Y/6imuvD6bEsKvnuSaBsi3dIestO2bb1AjlTSLJ+2/w 96BuqqwmmTw8
MPpyDKpsCSVa6rJnKnu+of20K+2h1AKiiMkz+u6Ohudnw8Eop+/uaJTX96jb P6zvdqUxzqkQ
1MtaWj9Hs9/t5Gl2h50izfMszX1zM/KWpdGiuZmWo4s9ZXxrycxD5q6SZIp8 yT2Sgxiydwgi
BDsXCPYjqdglNl4xZdfFGuLSTL2j9NlD7PkEqHKbsz+P60/avW8TCoa9xTBx +1EkGAxGF/lF
OhgUFqkasN8xnGaRFu+zHL9OixgjteeStf1oSjfn/z/TMTKNdj7jbKepaPbz EYW++hSkc9Qp
SNXlwezpRvOtVMbtLvWFQzAO646uVvCsBfb9pGT6/aTEFFHK1PeTkkZ1+aZH FCZfVTVBtefj
pSaoSj+8MkRU/xMdhfhg+bfG9WwzhHsSOGNgPa2ji+/APEQmsVX7rAbANU8N 6t02b6AazRhy
UACoUwJRXUVdCuSCqH2Asapq31xWaI+q8v4lipZc2F96GNvve5OJWbmy7ioq RXLI+Kso1zG8
fcT3LttSgGbGU7ukKWhwZ1zVrPnNR/M6U41vWnbyy9wF7qNqlwW9HuTXVC7x 1iT3IYwm8Vfe
1Ur/+LzVJ2JqQ3ryQmaZsX6vZUa6O7b2OLi46PfOOmc5FZ2fF+uAuyWG8zIV tQ95naKF9EbD
7tmony999oqlz+GB0mctd1b/y6JjSh1VZbeoz9DP8Dgb0U5xxVCwbm53JmnQ NYX9X0ke9GYE
J/EGo0Cx93Yk77EHfvObzTD6lOWtyUwhJLr4GxG7x2JNnTEWiLj8rYl9jDeO M3n1+QTUQs/t
cSdD1J7Jx+m4eXio72EyuYEia+gRHIl8IRGpazg68/6zFdGPSy/0kVUxbOTj xZlKIDLxQsWP
ymilEZ4io0gyyuRi2tFHITunV8cF/or4wUPPQ2yrw0iaE+RPBXuj4oFD/9xM vtXpgFatCtwZ
2nnSg0Ku2B0OjBKRk2o2X/U4xtkUdCCHMuryQ2H8uLOEbFt92ZF+fckV+rRi /BswB+ta9erE
PvlCJHsicXuvbl3TTBbcrNxggKnm/a12gW3iB6GwltpflRxuJRg96mA32RYm X4JEn++2LP25
+yj2aaDpWJTKO2pNZH+RTHvjd4hlOwUjXvqzKrKlfuCkXAzd3qgVD1M/+HJY WtkZfc7zZsPa
AG6iCcSkTdiQv4VWg48CGzfRj6sltGtM54u8WRpV/9U3uiGXxxH3yAf510eX ZSv+pbnk7Pkj
XpH4zCQnnnZeae1Nsug8FkqPr0ESU/j5D1BLAwQUAAAACAD2eWk1EzuUPacA AADsAAAARQAA
AEVUU1BsdWdpbi8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UudWku d29ya2JlbmNo
L3dvcmtpbmdzZXRzLnhtbGWOTQvCMBBE74L/Ydm7saVWPRiLIIIHTyqeY7uG YLqRNVr991b8
APE6vJl5k+JWe7iSnF1gjalKEIjLUDm2GrebRW+MxbTbmTRBjm22prgybCzJ bwjGWiFrImmM
ciGEgyljkPtyrjGIVVR6dzqTujjlOJKw8Wr3rS9eMII3e/Iad46r0MAbgJZA YFO347PPDxyC
QPPi0nSYJcM8H2T5aIz9p1r/X/gBUEsDBAoAAAAAABlQbzUCMEcUGgAAABoA AAAfAAAARVRT
UGx1Z2luLy5tZXRhZGF0YS92ZXJzaW9uLmluaW9yZy5lY2xpcHNlLmNvcmUu cnVudGltZT0x
UEsDBBQAAAAIAEZyaTVNNMBi5wAAAJ4CAAASAAAARVRTUGx1Z2luLy5wcm9q ZWN0vZLPagMh
EMbPLfQdwt6j6a0Hs4Hmzy2lsMkDWJ1sDeso6oY+ftS4KctS6KH0Nt838/kT R7b60t3sAs4r
g8vqmSyqGaAwUmG7rI6H3fylWtVPj8w6cwYRNuCFUzbE6eg+MOQa6u2hee/6 ViGjWaeGMFoD
hprRoUpuOcVnQUfqo1edbCyIpIpcxyhHmZ3CMq4lIDplPZCzDEQYFwt+4TkA 7vsKMcFd2ye2
L5qODUYnlF9xrQSy56hO4MPr/2Ib8Qma/wm0OMOTR17oHZTpm5jgb2t+y81E z0M/BUbrwUlm
qBPx/hfG/+sKUEsDBAoAAAAAAM9gbzUAAAAAAAAAAAAAAAAOAAAARVRTUGx1 Z2luL2Jpbi9Q
SwMECgAAAAAAz2BvNQAAAAAAAAAAAAAAABgAAABFVFNQbHVnaW4vYmluL2V0 c3BsdWdpbi9Q
SwMEFAAAAAgAz2BvNWIJf5kuAgAANwQAACcAAABFVFNQbHVnaW4vYmluL2V0 c3BsdWdpbi9B
Y3RpdmF0b3IuY2xhc3OlkttuEzEQhn+nabZZlhbSE0059UiSSqwqcRdUAT1I lSKESOm9s3W3
Lpvdlddb+lgcLoq44AF4KMTY2aalBHHBjT0z/ufzeMY/fn77DmATGw5KDNNC Z2mUhzL2XwZa
nnGdKAdlhvVEhb4IIplmws+lfynqZVrxQL/bf2MDDJW0MGY7I1htEjyXsdRb DGON5iFDeTs5
Ei7GcMuDg4kqGG57GEeFYaojY/E67/eEOuC9SDDUOknAo0OupPGLYFmfyIxh PNNcaYa1RsfU
mmSh9I8V74sPiXrvv8rjo0hsJ7EW57ptLnZ3zwORapnEmYNZevopP+N+xOPQ H56YuuY93EWN
wQkGyQzL/76Aqsp0kpr8+x7qJt8Nhd4RxzyPCDHfaP6lPTWS7fd5KHZEFiiZ UpThRaNzVV1X
KxmH7Wbn+khOj3kgfCWyJFdk3CC0J7DMUN096A7GZOpa9bCGdYYF+bt2TyX9 y2G+HXHvf1ZC
nUm5PjGz/ANETerarD1pBjs57MtTI8US/Y0x+qwkMx+ErHGy6dPQWiWvTTuj vdq6gNv6Au8T
OSVM0jppE2soY5rkM5gizxuIcceimJkyqafJLpM3Y5FbFCnRXmltXGDuiufa aJ0KWLSsuYGq
YBnrHhZsOfUR1L2C6hrqIhtR6RKRl0m7co3uDuluQa/iAR4Wj1+1r6FbPsP7 OKRVbLRpKSX7
2kd4XGRsUsScOrWl1les3Ex6dq1JDp6gAdOkplW1fgFQSwMEFAAAAAgAz2Bv NQVWjUnhCwAA
5BcAACoAAABFVFNQbHVnaW4vYmluL2V0c3BsdWdpbi9FVFNMb2dQYXJzZXIu Y2xhc3OlWAt8
U+UV/580bdL0UtqUV7HFgoBtShsKKFKgUkqQQlqwLcXKlKbJbRtMcuO9SaFu zs35mM+54TZh
U3HToe6FDlIjPticb6d7uOE2p+7hnO7hnHMvN90596ZtLFWL0l/7fff7zjnf efy/853DY2/d
fR+AOjrVARthmpow4pFkXzjm9XW0+7W+TQHdUHUH7IQqTe/zqsFIOG6o3v7B QEg1vBGtj2n7
vHGTzPBa5ITCuK6FksFEJy+GtRjB7d8eGAh4IwEmbk/ozLN8lKpNjagBQyU4 DS2pB9XmNYQp
cV0dCGtJo0lXAwmW0RGOMkVhVDWMQJ/apCVjCTmJmgklm9o2rtnc1LGt09fW 3ryxddsGXxdh
UpMWMxKBWKIzEEmqTkwmTB5DmMXa5vP7Gtt9wuqEO4s0s0HIWxGOhRMNhJzK qk6CvUkLqS7k
YLqCEkzJB6FUQS7yZHacAgfynCgnKB2bOjb5dgai8YhqyN7xCpyyN5sA+T5B 4cHkmqfAhQI+
2x+Oqa3JaI+qdwR6Iqq4TwsGIp0BPSzfmUV7oj9sEGb4xw8aO7jIUBPshd5w X1I3ncjUlVYk
kolwxLsuYPQnRNhyscjl2xlU40JmOFBLOGkCAR85bYRXXLJQgQfVLizCEgcW s5fHOVLBSTiZ
ndmnJgjzK7PwsbFnuxpMLK86esmBU9iosUhyoJ4wfezq6mQ4ElJ1F5ZihYKV 4MA5BgQJG3vf
/7wMRF1YhlUS3kbC1Mqj96s6nWgi2Co6hdKnYC1OY6AE4nE1FiLUjMdy1FJG 0eVOMJSpTSRt
UOBHC9+HhGbR8H2oHEc/Qm7CwsLUcaNKyDcD1aruZCfXV1Zt9b9HTNUBNZYw vMEe1dukRaNa
bDVfSp8ssuPbCad8UG7B9mYFnYJtV0DXA4PNsZC6U5bPUNCFPA5NMKkL6iVc WxV8RKy3s5FR
WThbwTZ0s2Mjaqwv0W/ewGbZ6FEQBDs6L9gf0BvZRHtlc1WTi+X2KujDFL5K uiq3NhyIhM9T
m1b7hCusYDvO4TPDooXAQdhMgVHZ4luSW9mcWYkrOBecZ/KNZI+RicU02T06 Gk6wBgXNsV5N
jwasq7AUAwp2YCerqJ6bDESMMTgaht6Z4ovzFHxU/OzM5DijAOfjAgc+/t5X 8d0dr+AT+CSr
xFmgnan0cGJQbG0X2H6KjfTpuqY7cTG7YktAj7Ewcd2lCj4tFhf1sn+ys6+o c7mCK+Q2TJbM
MmbvKgVX4zOEYvO8c5NqLJjJYnLq+qpO8cdnxZ+fEzeM50IRc62Cz8sReSym xegTz3xRwXUC
nqIWyzONgqF2jqhs7lHwJdks0NWgpofMl0HsuF7BDQKjfFYz1CjgcmIvp1LT 6gq5F3xiBXux
1oUarHLiqxzZVq3CEmNU7FB1taKXpYVmO3DLcBIzte3o17Udw0lYjcb5seHk bnT0B2ImslnT
PnEO5+/RJacxEgMl+I5HjcKsZWJU5lT/OEeZvvm2gv0Ca7uAWoy/U8F3cIAl mihYGwgmNJ0P
WDLBm+rL4uIDUrjLgSHComPnVpDG3YRy0zJ+nqNxLca7zSH+E+4NBzPPTyOn sQljeTwRfMvu
YfvXs4MKcB8OO3A/YeWHEqngu4K36Yw33041mJQ1X2wgrGuxKNPJMQ8o+L7Q KOaDmpHixEMc
1ZZB6wEUskcUPDp8O9qTPVmUjzM+G+PxSOZIIf6BgieF2J0tsznUMRhnoP6Q M/460xC/ZUe7
VUAI448V/EQYi7IZhU0A8VMFP5OEWhCRimGdZrBIYXpGwc+FSZKBFBOihdD/ UsGzQl+cRb/W
TGDC9ZyC54cNGuaSkwSLv1bwG/yW9RRjzbotywrC6soPGeiqTgHkiwp+j5dY AwtY7eFEMgOl
xROG0giTCfGXFbyCP/ItsyS2qXFNT2TJXTZhuWNYGZp/ZkA0t3b42lob/QV4 Fa858NcJZ+8x
4hT8TVwv2bSNy2NN8nN7UBN0/J2fQP/G0+SEfyj45yiZCGhio/r4Rjrxb3bb GKEFeBP/c+C/
BO8x+k7BWyOJP3NCa0AS/5t8LYjIZgFyhF5gwjXDRFHwDj4z9ueTXaFcyrNu XVaAlhyzTLO8
LTbGgJS7jFM/JEYllfdkg7LumFXjBMALR6Fw6QfEoIMKCbODWtQb7uHfYNKb 4OKPz5P0sYYD
Z11uJxXJc9pSG6odHKw955zaaLTWMFw0CascVDJcTpusZnrbpBlhs6QhN03l ipimWVVTJ7PQ
DIVKaSYXFGaxyel4nLrX/y4Chwtis3IV/ZY7qYwf20H+V9PSUhMKVaxbVx+N 1huGg2bxC310
+dzby2U+q1Gh0Gyaw4WDVYAR5laOlT1ejU/l/PjTPH6GO3hOJypUSVVcEulq PBIIsjm1XO5N
rJAXTVj/auauXWj+E4k13BcQ91MLJtgOmFJErQ1cLnMHqycyFUS+kdDimbkr NBJLbiH97xtw
xpldWDjqY50iLeS7aMGGcH8m99xJy7jKsaRWDLf5Lt7MtPhOWsEndNbVLuRl 6zlYG5Zipji7
J62VczCb350cgFtkmzTMPLNJu2yOzsyYnxm5IeZxJhT+ZgXMtUL+Lsr6LmZu kiac/07llR5e
4+YaFZ4hTPPQQcyQPzM97rKDmOVxVxzEHE/OQcy9w+Sez39nsQT5a2fd8jGX T6hkaQv4HC+O
5/UTeVexZPJOFY8kHS5zL+C5nb9qzJOf4rmNxws81UPweqrdhSnUHcZSUaHa XTz8MdNzADMe
wlYeZj6ExZ5DWNbF81l3YfkQTnWvTmGNUPDgXmfNZ/KQwnrWfx/mvge9RTNq 2Bx2KFDPbl4J
NxrYmEZeb2J11+AsnIaPY71p3DRL7YxxMmvFRjaLsAmnjzXT9rIVNnqQDqPN L77s2EfdHtZh
SwpnHsQWa3bWDbRBZjkpBIpO2EsN8mHPfNRxcFRZKFqRQv9Kc9ZQlkLEpCqz d5enoLG0enup
3W2kkNzNsTyAQf7tWFTkSuNjNuxDPW9eOHZzUWaznDcvMjdLRjdnmZvWwXxE 5B0nl5UP4ZL6
3BHq0tw0LjOp55TmmpJmj+x5ug5g7pn2bgbSrovTuDKHTyw0ceUpzRWIjRDy AeX27hSuYXPS
2MXymLVDODuEgH+/sBfTTTfKzm7Z2S3s+7M+PSl8WVz78Ft7hGkPtzzi/H1Y KJ8r92GScJRR
+0U2KhORN739mqwwRWHLIdR0uW8cwk3389LuPZhkLnxFFqr3yy2jbbQPN1M3 3SxjBjy3M8bB
bXsuzuB7eDbftgBmIIQV3FuvQpihsx2bEYUKjX/iuJBbuyuh40YYuA0J7ggG uGzewbfiPBzh
3vYlhtvruICKcSFN4w60DJfSUlxGjbiC/LiKTsfVtBXXUDd20XacTQO4js7H broY19NVuIGu
5fFG7uFE01u5JbsTt1Eat9MD+KYJ4jYBOz2YAXEu++draGfQrqcKjk0BW7WZ puJWnuVApVzW
MY9BfQS72NI8pr+cwf11oWPpLnyDpdr4p284r1Adf9lZ8i0joU3jW9yD4Y40 D
Re: Remote Import of log file [message #87566 is a reply to message #87449] Thu, 16 November 2006 00:13 Go to previous message
Eclipse User
Originally posted by: cvkmurthy.hotmail.com
Hi Cindy,
Thanks a lot for taking time to look at my problem. Now I am able to
do local and remote log import. I appreciate your help.
Krishna
Cindy Jin wrote:
> Hi Krishna:
> the AC.adapter.
> it should be
> in the log view.
> Cindy
>> Regards,
>> Krishna
>> Krishna wrote:
>>> Hi Cindy,
>>> Please find the plugin project attached.
>>> Regards,
>>> Krishna
>>> Krishna wrote:
>>>> Hi Cindy,
>>>> Even the local import is not working for me. I get a popup which
>>>> says "An internal error occurred during "Importing log file..." and
>>>> java.lang.NullPointerException
>>>> at
>>>> org.eclipse.tptp.monitoring.logui.internal.wizards.ImportLog Wizard$LocalLogImportJob.parseStatusString(ImportLogWizard.j ava:1240)
>>>> at
>>>> org.eclipse.tptp.monitoring.logui.internal.wizards.ImportLog Wizard$LocalLogImportJob.getProgressStatus(ImportLogWizard.j ava:1218)
>>>> at
>>>> org.eclipse.tptp.monitoring.logui.internal.wizards.ImportLog Wizard$StatusListener.run(ImportLogWizard.java:2073)
>>>> Exception in thread "Thread-1" java.lang.NullPointerException
>>>> at
>>>> org.eclipse.tptp.monitoring.logui.internal.wizards.ImportLog Wizard$StatusListener.run(ImportLogWizard.java:2078)
>>>> Regarding remote import my adapter file is in
>>>> <RAServer HOME>/plugins/<Your plugin>/ETSParser/AC.adapter
>>>> I copied ETSParser/AC.adapter to <RAServer HOME>/plugins/<Your
>>>> plugin>/config to see if it works. But I get the same error.
>>>> Attached is my pluginconfig.xml file.
>>>> Regards,
>>>> Krishna
>>>> Cindy Jin wrote:
>>>>> It seems the your adapter file is not found. Where is your adapter
>>>>> file located? It should be at <RAServer HOME>/plugins/<Your
>>>>> plugin>/config/ETSParser/AC.adapter.
>>>>> If your AC.adapter is at the correct location, could you please
>>>>> Thanks
>>>>> Cindy
>>>>> Krishna wrote:
>>>>>> Hi,
>>>>>> Regards,
>>>>>> Krishna
>>>> <PluginConfiguration requires="org.eclipse.hyades.logging.parsers">
>>>> <Application configuration="default"
>>>> value="%RASERVER_HOME%\plugins\ETSPlugin_1.0.0\ETSLogParser.jar "/>
>>>> <Variable name="GLA_CONFIG_PATH" position="prepend"
>>>> value="%RASERVER_HOME%\plugins\ETSPlugin_1.0.0"/>
>>>> <Parameter position="append"
>>>> value="&quot;config_path=%GLA_CONFIG_PATH%&quot;"/ >
>>>> </Application>
>>>> <Option name="ETSPlugin" type="version" value="1.0.0"/>
>>>> </PluginConfiguration>
Previous Topic:[AGR] Invoking context-menu items inside an editor pane
Next Topic:Trouble Installing TPTP
Current Time: Tue May 21 08:41:03 EDT 2013
Powered by FUDForum. Page generated in 0.02029 seconds
