Home » Modeling » QVT-OML » [QVTO] Default initialization of * features
[QVTO] Default initialization of * features [message #870776] Wed, 09 May 2012 11:32 Go to next message
Christopher Gerking is currently offline Christopher Gerking
Member
A target EClass has a *-feature, i.e. cardinality is > 1. After instantiating the EClass within QVTO, the following queries lead to the following results:
(o.ref = null) is false, which implies that the feature has been initialized automatically
(o.ref.oclIsUndefined()) is [], which shows that oclIsUndefined does not return true or false in favor of an empty sequence. I do not assume that this is the intended behaviour?
(o.ref->size()) is 0, which makes sense
On intermediate class objects, the situation is even more weird. After creation of an intermediate class object:
(o.ref = null) is false, same behaviour as for default objects
(o.ref.oclIsUndefined()) is [true], obviously the result is a seqauence containing an instance of OclVoid
(o.ref->size()) is 1, which is normally not expected behaviour and caused serious problems in my case
Why does oclIsUndefined() return a sequence at all and why does the sequence contain an instance of OclVoid in case of an intermediate class?
Re: [QVTO] Default initialization of * features [message #870784 is a reply to message #870776] Wed, 09 May 2012 12:13 Go to previous messageGo to next message
o.ref.oclIsUndefined() is a shortform for
o.ref->collect(oclIsUndefined()) so you get a (empty) collection of the
element returns.
You don't say how you create your intermediate class object so a
response is possible. I suspect you are using the implicit ->
conversion. o.ref->size() = 1 seems very sensible to me.
With QVTo you are using the Ecore binding of Eclipse OCL. This has some
problems in null/invalid/deep collection corner cases, which only
acquired a meaningful specification in OCL 2.3, which postdates QVTo 1.1.
Ed Willink
Re: [QVTO] Default initialization of * features [message #870990 is a reply to message #870784] Thu, 10 May 2012 09:35 Go to previous messageGo to next message
Member
Edward Willink wrote on Wed, 09 May 2012 12:13
element returns.
Okay, this makes sense.
Size 1 is sensible, why? The object o is created via 'object' keyword. Without explicit initialization of the ref feature, the null check returns false. Obviously, the feature has been initialized automatically. For the automatic initialization I would assume an empty collection. Instead, there seems to be an instance of OclVoid inside the collection, which implies the size 1.
The actual problem is that the OclVoid instance remains during execution, i.e. when first adding to that collection, the size is 2 and so on...
Re: [QVTO] Default initialization of * features [message #871357 is a reply to message #870990] Sat, 12 May 2012 06:29 Go to previous messageGo to next message
As I wrote: You don't say how you create your intermediate class object
.... seems very sensible to me.
Without a clear exposition of what you are actually doing, I cannot
explain the subtleties of null content to you.
Ed Willink
>> Hi
>> the element returns.
> and so on...
Re: [QVTO] Default initialization of * features [message #871736 is a reply to message #871357] Mon, 14 May 2012 15:07 Go to previous messageGo to next message
Member
This is the definition of my intermediate class:
intermediate class O {
ref : OrderedSet(O);
And this is how the instance is created. The assertion makes sense to me, but it fails due to an instance of OclVoid within the ref OrderedSet.
var o : O = object O {};
assert fatal (o.ref->size() = 0);
Re: [QVTO] Default initialization of * features [message #873203 is a reply to message #871736] Thu, 17 May 2012 13:12 Go to previous messageGo to next message
I think you are being confused by the lack of unification and
consequent incompatibility between
UML's bounded collections
OCL's nested collections
The QVTo syntax supports UML's bounded collections:
ref : O ordered
Oops: this is not in the QVTo grammar, just the examples and where is
'unique' ?
So when you used
ref : OrderedSet(O)
you were specifying a singleton element of collection type; well worth a
warning message.
Unification of these syntaxes is one of my current OCL activities.
Ed Willink
Re: [QVTO] Default initialization of * features [message #874664 is a reply to message #873203] Mon, 21 May 2012 06:34 Go to previous messageGo to next message
Member
thanks for your response.
So using UML bounded collections is a proper workaround.
However, why is it a problem if I specify a singleton element of collection type?
Am I wrong if I still consider the contained instance of OclVoid as a bug?
Re: [QVTO] Default initialization of * features [message #874673 is a reply to message #874664] Mon, 21 May 2012 06:48 Go to previous messageGo to next message
On 21/05/2012 11:34, Christopher G. wrote:
It's not a workaround. It's just correct.
> collection type?
> bug?
When you use nonsensical statements, you can only complain about missing
error messages.
Ed Willink
Re: [QVTO] Default initialization of * features [message #874729 is a reply to message #874673] Mon, 21 May 2012 08:56 Go to previous messageGo to next message
Member
Ok, I didn't understand it was actually nonsensical, sorry. And I still do not understand the relation to UML, but it's ok.
After changing to UML bounded collections, the += operator does not work anymore.
How can I add to such a collection?
Re: [QVTO] Default initialization of * features [message #874748 is a reply to message #874729] Mon, 21 May 2012 09:30 Go to previous messageGo to next message
I'm not telepathic. It's not sensible to expect me to apply the same
edits as you and then diagnose your problems.
Also "does not work" is notoriously uninformative.
Ed Willink
> work anymore.
Re: [QVTO] Default initialization of * features [message #874819 is a reply to message #874748] Mon, 21 May 2012 11:46 Go to previous messageGo to next message
Member
Sorry, this is how I changed my intermediate class definition:
ref : O ordered;
The += code below produces the compilation error "Property 'ref' must have collection type".
object O {
ref += ...
Re: [QVTO] Default initialization of * features [message #874826 is a reply to message #874819] Mon, 21 May 2012 11:57 Go to previous message
Sorry, but I think it's about time you started doing some work for
yourself; I have my own work to do.
If you look at the QVT specification you will find at least 20 examples
of the solution to your problem and no indication that what you have
done is sensible.
Ed Willink
> ref : O ordered;
> object O {
> ref += ...
Previous Topic:Proper use of libraries
Next Topic:Transformations between enums in QVTo
Current Time: Tue May 21 02:04:17 EDT 2013
Powered by FUDForum. Page generated in 0.01897 seconds
