| SWTBot with Maven 2.2.1 [message #870516] |
Tue, 08 May 2012 09:56  |
prakash jv Messages: 4 Registered: May 2012 |
Junior Member |
We have been looking for unit test framework for unit testing SWT components in our RCP application developed in eclipse galileo 3.5.
We found SWTBot supports the better UI testing and wanted to additional details reagrding its support for maven 2.2.1.
Does SWTBot work with projects which are mavenized with maven 2.2.1?
Our aim of adding the unit tests for UI components is for better build quality. So we would want these Unit tests to be run everytime we build our assembly. As of now we use Junit4 for running our JUnits and they run with maven outside eclipse.
Does SWTBot support running the UI unit tests outside eclipse using maven?
FUDForum. Page generated in 0.01688 seconds
