Home » Modeling » Model-to-Model Transformation » VMException error when try to read part of a UML file(VMException error is being shown when is tried to get some values from a UML sequence file)
VMException error when try to read part of a UML file [message #870360] Mon, 07 May 2012 14:59
Fernanda R.F. is currently offline Fernanda R.F.
Member
I'm getting the follow error when I'm trying to read a UML file into ATL code:
org.eclipse.m2m.atl.engine.emfvm.VMException: The value of type 'class org.eclipse.emf.ecore.impl.DynamicEObjectImpl' must be of type 'class java.lang.String'
I've a UML sequence diagram as Input and it will generate a new UML file, however this error is appearing when I try to get the covered, or sendEvent, or receiveEvent or represents value from UML.
One rule is it:
rule msg {
from
y: UML!Message
to
w: input!mensagem (
name <- y.name,
sender <- y.sendEvent
I can get the name from tag "message" from UML (xmi) file.
Thanks in advance
[Updated on: Mon, 07 May 2012 15:00]
Report message to a moderator
Previous Topic:[QVT tutorial] How can I debug (step into) script ?
Next Topic:Merging multiple Instance Models
Current Time: Tue May 28 20:31:22 EDT 2013
Powered by FUDForum. Page generated in 0.06504 seconds
