Home » Modeling » B3 » Adding maven central as repository to an aggregation does not complete
Adding maven central as repository to an aggregation does not complete [message #725410] Wed, 14 September 2011 13:39 Go to next message
Lothar Werzinger is currently offline Lothar Werzinger
I am trying to do an aggregation where I want to get a couple bundles from maven central.
Eclipse starts a job called "Loading maven2:http://repo1.maven.org/maven2" That never completes (started it yesterday and still running - I am restarting eclipse now).
If it were not for some warning messages in the error log it would appear that it does not do anything at all.
This is an example of one of the warnings I get:
eclipse.buildId=I20110613-1736
java.version=1.6.0_26
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments:  -os linux -ws gtk -arch x86_64 -data /workspaces/buckminster-research
Warning
Wed Sep 14 10:36:24 PDT 2011
Skipping component activemq/activemq-gbean-management#g1_1-3.2.4: Invalid path, http://repo1.maven.org/maven2/activemq/activemq-gbean-management/g1_1-3.2.4/activemq-gbean-management-g1_1-3.2.4.pom should end with /activemq/activemq-gbean-management-g1_1/3.2.4/activemq-gbean-management-g1_1-3.2.4.pom
Re: Adding maven central as repository to an aggregation does not complete [message #725888 is a reply to message #725410] Fri, 16 September 2011 01:36 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas Hallgren
Hi Lothar,
Can you please enter a bugzilla for this and attach the failing aggregation?
- thomas
On 2011-09-14 19:39, Lothar Werzinger wrote:
> I am trying to do an aggregation where I want to get a couple bundles from http://repo1.maven.org/maven2.
> Warning
Re: Adding maven central as repository to an aggregation does not complete [message #726594 is a reply to message #725888] Sun, 18 September 2011 17:53 Go to previous messageGo to next message
Thomas Hallgren wrote on Thu, 15 September 2011 22:36
Hi Lothar,
- thomas
Created bug 358034
Re: Adding maven central as repository to an aggregation does not complete [message #870356 is a reply to message #726594] Mon, 07 May 2012 14:41 Go to previous message
Ed Gow is currently offline Ed Gow
I'm also unable to get B3 Aggregator to pull in plugins from maven2 repos. Is this user error, or does B3 Aggregator not work?
Previous Topic:Mirror only required dependencies from a Mapped Repository
Next Topic:Compressed build results?
Current Time: Tue Jun 18 02:06:39 EDT 2013
Powered by FUDForum. Page generated in 0.01714 seconds
