| Creating custom configuration from "Default Configuration" not created correctly [message #870183] |
Mon, 07 May 2012 03:59 |
Charu Sharma Messages: 17 Registered: May 2011 Location: Pune |
Junior Member |
After creating project for selected toolchain, when I try to create a custom configuration using "Manage configuration" dialog > select "Default Configuration" option and select available configuration. After creating configuration when I visited .cproject file of my project, I found there neither of options are copied to the custom configuration.
This scenario works fine for MinGW and other toolchains installed, problem occurs with the toolchains I have created using buildDefinitions extension point.
Would like to know what could be missing in my toolchain properties in plugin.xml or anywhere else.
Please guide..
Charu Sharma
FUDForum. Page generated in 0.01403 seconds
