| DTD not working as it should ? [message #839454] |
Sun, 08 April 2012 14:57  |
morten hundevad Messages: 3 Registered: April 2012 |
Junior Member |
Hi all
I, resently added DTD to out project
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE install SYSTEM "...........jfusion.org/xml/dtd/1.5/plugin-install.dtd">
<install type="jfusion" version="1.5.0">....
Now the file seems to be correct and working ...
I did not see it at first after updating eclipse. it started happen after the first clean of the project I made.
Description Resource Path Location Type
The file cannot be validated as the XML definition "...........jfusion.org/xml/dtd/1.5/plugin-install.dtd" that is specified as describing the syntax of the file cannot be located. jfusion.xml /JFusion/trunk/components/com_jfusionplugins/mybb line 2 XML Problem
Server returned HTTP response code: 403 for URL: ...........jfusion.org/xml/dtd/1.5/plugin-install.dtd jfusion.xml /JFusion/trunk/components/com_jfusionplugins/oscommerce line 2 XML Problem
the thing is if I individual change/save the file then the error go away and it reads the dtd file ..
I notice after updating that:
Window > Preferences -> General > Network Connections > Cache
This option do not exist any more after I update eclipse. this was where I had to go when I was working on the DTD
If seems cache is not working? or what is going on ?
Eclipse SDK
Version: 3.7.2
Build id: M20120208-0800
-Thanks
EDIT: I cant post any links ..... so you have to adjust for the incorrect url's
FUDForum. Page generated in 0.01816 seconds
