Home » Modeling » UML2 » Transform UML2XSD(Transform UML to XSD)
Transform UML2XSD [message #853168] Sun, 22 April 2012 15:52 Go to next message
Arnedo Ramon is currently offline Arnedo Ramon
I need to transform a UML model to a XDS Schema using Eclipse. How I can do it?
I read about two options: Hypermodel and EDNA. What do you recommend?
I need to know the transformations between then (UML-XSD) and I would like to modify them if it's possible.
Thanks for all,
Ramón.
Re: Transform UML2XSD [message #853593 is a reply to message #853168] Mon, 23 April 2012 02:39 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Ramón,<br>
<br>
I imagine such a transformation should be about how instances of the
UML2 model are serialized as XML.  But UML doesn't (directly)
specify how instances are to be serialized as XML/XMI.   One
approach you could use is to transform UML2 to Ecore and then to
generate an XMI or XML schema from that.<br>
<br>
<a target="_out"
href="http://www.theserverside.com/tt/articles/article.tss?l=BindingXMLJava">Binding
XML to Java</a><br>
<a
href="http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchemaToEcoreMapping.pdf">XML
Schema to Ecore Mapping</a><br>
<br>
<br>
On 22/04/2012 9:52 PM, Arnedo Ramon wrote:
<blockquote cite="mid:jn1nie$qv7$1@xxxxxxxxe.org" type="cite">Hi,
<br>
<br>
I can do it? <br>
recommend?
<br>
<br>
<br>
<br>
Thanks for all,
<br>
<br>
Ramón.
<br>
<br>
</blockquote>
</body>
</html>
Re: Transform UML2XSD [message #854075 is a reply to message #853593] Mon, 23 April 2012 12:33 Go to previous messageGo to next message
I'm so sorry, but I didn't explain my idea so well.
I'm going to try again.
I don't want to serialize the UML model as XMI.
My objective is to transform UML model to its XSD Schema (I got it using Enterprise Architect). Besides, if it's possible know the steps and the source code to do it.
I did a Ecore model from a XSD Schema, but I couldn't do the inverse option: a XSD Schema from a Ecore model.
You explain me the option of generate an XMI or XML schema from the Ecore Model. How do you do it? Open the Ecore model with the text Editor?
Thanks for all,
Ramón.
Re: Transform UML2XSD [message #854092 is a reply to message #854075] Mon, 23 April 2012 12:56 Go to previous messageGo to next message
Arnedo,
Comments below.
On 23/04/2012 6:33 PM, Arnedo Ramon wrote:
I assume not, given that UML2 models are already serialized as XMI.
You make it sound like there is some specified mapping, but I don't know
of one.
Open the *.genmodel and use Export Model...
As above. You can play with it to see how it works.
If you only have an Ecore model, you'll have to create Generator Model
for it; there's a wizard to create it.
> Thanks for all,
> Ramón.
Re: Transform UML2XSD [message #869981 is a reply to message #854092] Sat, 05 May 2012 08:39 Go to previous message
Thank you very much.
It was so useful.
Previous Topic:Registering Ecore.profile.uml
Next Topic:Error to get sendEvent or receiveEvent value from UML sequence
Current Time: Sat May 18 06:53:33 EDT 2013
Powered by FUDForum. Page generated in 0.03822 seconds
