Home » Eclipse Projects » Virgo » 3.5.0.M04 Cannot determine the artifact identity of the file
3.5.0.M04 Cannot determine the artifact identity of the file [message #869913] Fri, 04 May 2012 15:05 Go to next message
Rich Mayfield is currently offline Rich Mayfield
Member
I'm trying to deploy a very simple (empty even) plan in the pickup directory however this fails every time with the error "Cannot determine the artifact identity of the file ...".
Any ideas what I'm doing wrong here? This is with the Jetty distribution and other plans appear to be fine.
This is on Mac OS X 10.7.3 with Java 1.6.0_31.
The plan is quite simply:
<plan name="server.plan" version="1.0.0" scoped="false" atomic="true"
xmlns="http: //www.eclipse.org/virgo/schema/plan"
xmlns:xsi="http: //www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="
http: //www.eclipse.org/virgo/schema/plan/eclipse-virgo-plan.xsd">
</plan>
Yields the error:
[2012-05-04 11:55:47.667] fs-watcher <HD0002E> Hot deploy failed for file '.server-1.0.0.plan.swp'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Cannot determine the artifact identity of the file '/Users/me/Desktop/virgo-jetty-server-3.5.0.M04/pickup/.server-1.0.0.plan.swp': uri='file:/Users/me/Desktop/virgo-jetty-server-3.5.0.M04/pickup/.server-1.0.0.plan.swp': uri='file:/Users/me/Desktop/virgo-jetty-server-3.5.0.M04/pickup/.server-1.0.0.plan.swp'
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:167)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:139)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:252)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeployerFileSystemListener.java:163)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeployerFileSystemListener.java:67)
at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:245)
at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:166)
at org.eclipse.virgo.kernel.deployer.hot.WatchTask.run(WatchTask.java:48)
at java.lang.Thread.run(Thread.java:680)
Caused by: org.eclipse.virgo.kernel.deployer.core.DeploymentException: Cannot determine the artifact identity of the file '/Users/me/Desktop/virgo-jetty-server-3.5.0.M04/pickup/.server-1.0.0.plan.swp': uri='file:/Users/me/Desktop/virgo-jetty-server-3.5.0.M04/pickup/.server-1.0.0.plan.swp'
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.determineIdentity(PipelinedApplicationDeployer.java:209)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:159)
... 8 common frames omitted
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.determineIdentity(PipelinedApplicationDeployer.java:348)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.determineIdentity(PipelinedApplicationDeployer.java:207)
... 9 common frames omitted
Re: 3.5.0.M04 Cannot determine the artifact identity of the file [message #871163 is a reply to message #869913] Fri, 11 May 2012 04:25 Go to previous messageGo to next message
Hristo Iliev is currently offline Hristo Iliev
Can you please provide a listing of the pickup folder?
Do you have just the plan there or there are more files? What's the name of the plan file?
Re: 3.5.0.M04 Cannot determine the artifact identity of the file [message #871171 is a reply to message #871163] Fri, 11 May 2012 05:12 Go to previous messageGo to next message
Thorsten Schlathölter is currently offline Thorsten Schlathölter
If you look into the Exception you can see that the Server is complaining about a swap file ".server-1.0.0.plan.swp". If this is still an issue, delete the temporary file and try again.
Thorsten
Re: 3.5.0.M04 Cannot determine the artifact identity of the file [message #871243 is a reply to message #869913] Fri, 11 May 2012 11:28 Go to previous message
Member
Thanks for the replies. I was able to get to the bottom of the problem(s), which I'll summarize.
Note that the ".swp" file was actually created by vi when I edited the plan. In any event, this temporary file and it's name wasn't the problem.
I got this error when:
1) The bundle plan included an artifact with what is apparently an invalid version. For example, "1.0.0.2", which is fine for a Maven artifact versions but not for OSGi artifact versions.
2) The bundle plan was empty - i.e. there were no artifacts whatsoever in the plan. After experiencing "1)" I was just trying to see what it was about my plan, which had 100 artifacts referenced, was incorrect. It baffled me that an empty plan wasn't acceptable.
The error message provided by Virgo, however, is not helpful. In both of the above cases it says that it cannot identify the artifact identity of the plan.
What would be much more useful is if the error cited the artifact within the plan that was causing the problem.
Previous Topic:Problems running Spring DM application in Virgo
Next Topic:[Tooling] Feedback on Default VM settings
Current Time: Sat May 25 18:57:59 EDT 2013
Powered by FUDForum. Page generated in 0.05706 seconds
