Home » Modeling » TMF (Xtext) » ouverture de modele xmi !
ouverture de modele xmi ! [message #869889] Fri, 04 May 2012 12:16 Go to next message
Sassou slima is currently offline Sassou slima
Member
salut ,
j'ai généré un modèle xmi , mais le problème je ne peux pas l'ouvrir .
j'ai vécu le problème suivant :
org.eclipse.xtext.mwe.SlotEntry  - Could not find any exported element of type 'Element' -> Slot 'element' is empty.
l'"element " est le slot de moteur workflow .
S'il vous plait, vous pouvez m'aider . Sad
S'il vous plaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaait moi !!!!!!!
merci d'avance
Cordialement .
Re: ouverture de modele xmi ! [message #869899 is a reply to message #869889] Fri, 04 May 2012 12:56 Go to previous message
Christian Dietrich is currently offline Christian Dietrich
Hi you get this error cause the Model element you try to read is not
"in the index". This is cause it has no name attribute. You can
change this using a custom IQualifiedNameprovider or a
IDefaultResourceDescrptionStrategy. Googling you error message will
give you lots of examples Regards Christian
Previous Topic:error 202 - the decision cannot distinguish between alternative(s)
Next Topic:is xTend to generate no-java code? code to download?
Current Time: Fri May 24 12:11:17 EDT 2013
Powered by FUDForum. Page generated in 0.01637 seconds
