Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [TEXO] JPA Foreign Key
[TEXO] JPA Foreign Key [message #869784] Fri, 04 May 2012 05:59 Go to next message
Gary Godfrey is currently offline Gary Godfrey
Member
Using TEXO to generate JPA annotated code.
In the database the foreign key linking Applicant to Application is called 'applicant_id', using default JPA behaviour to name the index.
Is there a way to populate the @JoinColumns annotation when the Java code is generated from the ecore model?
e.g.
public class Application extends JPAIdentifier
	 * <!-- begin-user-doc --> <!-- end-user-doc -->
	 * @generated
	@IndexedEmbedded
	@OneToMany(cascade =
	{ CascadeType.ALL }, targetEntity = Applicant.class)
	@OrderColumn()
	@JoinColumns(
	{ @JoinColumn() })
	private List<Applicant> applicant = new ArrayList<Applicant>();
Gary
Re: [TEXO] JPA Foreign Key [message #869790 is a reply to message #869784] Fri, 04 May 2012 06:05 Go to previous message
Martin Taal is currently offline Martin Taal
Hi Gary,
Using an annotations model you can annotate the model which will be control the code generation:
http://wiki.eclipse.org/Texo/ORM_JPA_Annotations_Details
gr. Martin
On 05/04/2012 11:59 AM, Gary Godfrey wrote:
> Using TEXO to generate JPA annotated code. In the database the foreign key linking Applicant to Application is called
> e.g.
> * * @generated
> @IndexedEmbedded
> @OrderColumn()
> @JoinColumns(
> { @JoinColumn() })
> Gary
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Previous Topic:Invitation for discussion
Next Topic:[EMF Facet] non respect of the API freeze
Current Time: Wed May 22 03:14:44 EDT 2013
Powered by FUDForum. Page generated in 0.02420 seconds
