Home » Eclipse Projects » Equinox » Plugins IU directly in category.xml
Plugins IU directly in category.xml [message #868734] Wed, 02 May 2012 09:14 Go to next message
Mickael Istria is currently offline Mickael Istria
Hi all,
I want to put directly plugins in my category.xml (I don't want to use
features for those plugins, that I don't own, I just want to mirror
them, they are available in Orbit without feature).
I know p2 can publish directly plugins. I noticed category.xml editor
does not provide entry for Plugins,
So, simple question:
Is there a way (independently of category editor) to add plugins in
category.xml ?
The goal, ultimately, would be to support it also in Tycho.
Thanks in advance.
Mickael
Re: Plugins IU directly in category.xml [message #868756 is a reply to message #868734] Wed, 02 May 2012 09:45 Go to previous messageGo to next message
Gunnar Wagenknecht is currently offline Gunnar Wagenknecht
Am 02.05.2012 15:14, schrieb Mickael Istria:
> category.xml ?
Have you looked at the category.xml we use in Orbit? It's possible to
define categories using queries.
http://dev.eclipse.org/viewcvs/viewvc.cgi/org.eclipse.orbit/org.eclipse.orbit.releng/maps/category.xml?view=markup&revision=1.5&root=Tools_Project
I think it's also possible to list units directly. But I'm not sure
if/where it's documented properly. I discovered the query feature by
looking at the source code.
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
http://wagenknecht.org/
Re: Plugins IU directly in category.xml [message #868768 is a reply to message #868756] Wed, 02 May 2012 10:10 Go to previous messageGo to next message
>> category.xml ?
I did have a look at it. But queries are too complex for my use-case.
Will have a look at source then.
Re: Plugins IU directly in category.xml [message #868787 is a reply to message #868768] Wed, 02 May 2012 10:35 Go to previous messageGo to next message
I found the UI part in org.eclipse.pde.internal.core.idite, but nothing
related to Queries or bundles as IU.
Which class gave you hints for queries?
Re: Plugins IU directly in category.xml [message #868843 is a reply to message #868787] Wed, 02 May 2012 12:09 Go to previous messageGo to next message
Found org.eclipse.equinox.internal.p2.updatesite package.
The <iu id="bundle.name"> element looks promising, but it looks like
CategoryPublisher application only works on existing repository and is
only good at organizing an already existing repo.
What I want is to create a repo and publish some plugins in it, without
making them part of a feature.
But I also found that Tycho seems to use its own implementation, based
on ContextValue "TychoConstants.CTX_PUBLISHED_ROOT_IUS", use by
AssembleRepositoryMojo, to invoke MirrorAppicaiton and
MirrorApplicationServiceImpl....
Both Headless command and Tycho Mojo rely on the CategoryXMLAction and
SiteXMLAction for that. SiteXMLAction seems to perform some cool stuff
for <iu> but I can't get it to work.
Any help on its usage would be very welcome.
Re: Plugins IU directly in category.xml [message #869378 is a reply to message #868843] Thu, 03 May 2012 06:02 Go to previous messageGo to next message
If I understand correctly, <iu> are more aimed to categorize stuff that
is already part of the site. So not good for my use-case.
Then I opened this bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=378338
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: Plugins IU directly in category.xml [message #869420 is a reply to message #868843] Thu, 03 May 2012 07:24 Go to previous messageGo to next message
Hi Mickael,
Am 02.05.2012 18:09, schrieb Mickael Istria:
That's how it works. The p2 category Ant task (and application) takes
any existing p2 repository and adds categories to it (depending on a
given category.xml).
So you don't need categories for this. You can simply mirror or publish
any plug-in to any repository. Features are really just a way to group
bundles. My understanding was that you wanted to have categories as a
way to use "groups" of bundles in a Target Platform (or so).
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
Re: Plugins IU directly in category.xml [message #870771 is a reply to message #869420] Wed, 09 May 2012 11:15 Go to previous messageGo to next message
> bundles.
But there is no way to do it by editing a category.xml file, isn't
there? I'll need to use p2 tasks or scripts (which I tried to avoid as
much as possible in our Tycho-based build process).
Sorry if I was not clear. What I want is to give a category.xml
containing a bundle that is not part of a feature to Tycho and get as
result a repository which contain the IU for this bundle.
Mickael Istria
JBoss, by Red Hat
Re: Plugins IU directly in category.xml [message #870869 is a reply to message #870771] Thu, 10 May 2012 02:10 Go to previous message
Am 09.05.2012 17:15, schrieb Mickael Istria:
I'm not sure category.xml is the right thing for this job. From my
understanding, category.xml is only used to modify repo meta data. None
of the existing scripts/tasks use it for publishing bundles into a repo.
A Google search brought up this for publish bundles in Tycho:
https://docs.sonatype.org/display/TYCHO/Tycho-extras+-+FeaturesAndBundlesPublisher
There is also some discussion here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=347303
Have you tried this?
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
Previous Topic:ServletBridge Enterprise Ready?
Next Topic:Problem when updating bundle programmatically
Current Time: Thu May 23 19:59:24 EDT 2013
Powered by FUDForum. Page generated in 0.02189 seconds
