| Dependent Applications [message #868719] |
Wed, 02 May 2012 08:50  |
Johan Eriksson Messages: 17 Registered: May 2012 |
Junior Member |
I'm just starting to evaluate Virgo and I have read through large parts of the documentation. I do have a question which I haven't been able to find a good answer for. I'm considering moving a large OSGi-based application from "pure" Equinox to Virgo so that I can co-host other applications as well. So far so good - Virgo seems a perfect fit for this. However, my big application has several plugin-constructs - i.e. it can be extended ad-hoc by dropping in bundles which in turn implement and expose a service (there are a couple of different types supported). Now, if I package up my applications using a plan (or a PAR) - how would I deploy my plugins ? I would assume as another application, but how do I declare the dependencies between them ? How do I make sure Virgo starts my "big app" first and then the plugin-apps ? Should note that I am just planning on using the Virgo kernel as this is not a web-application.
Hope someone can help straighten this out for me.
Thanks!
FUDForum. Page generated in 0.01808 seconds
