Home » Eclipse Projects » WindowBuilder » WindowBuilder Issue
icon4.gif  WindowBuilder Issue [message #861607] Sat, 28 April 2012 12:48 Go to next message
Hans Mueller is currently offline Hans Mueller
Hey Guys,
i have a little problem with my windowbuilder, im using eclipse 3.7
when im using the design mode windowbuilder shows this preview:
http://desmond.imageshack.us/Himg213/scaled.php?server=213&filename=bsp2om.png&res=landing
but when i run the program it looks like this:
http://desmond.imageshack.us/Himg233/scaled.php?server=233&filename=bsp1.png&res=landing
can anybody help me?
Re: WindowBuilder Issue [message #863412 is a reply to message #861607] Sun, 29 April 2012 08:47 Go to previous messageGo to next message
Eric Clayberg is currently offline Eric Clayberg
In the first picture, it looks like you are using Swing and viewing it with the WIndows look and feel. In the second picture, it looks like you are running it using the default look and feel. This is entirely expected behavior depending on the settings you have in place and the LAF you have set up (or not) for your program.
Re: WindowBuilder Issue [message #865658 is a reply to message #863412] Mon, 30 April 2012 10:05 Go to previous messageGo to next message
and how can i change the LAF ???
Re: WindowBuilder Issue [message #867228 is a reply to message #865658] Tue, 01 May 2012 03:27 Go to previous messageGo to next message
I highly recommend starting with the docs.
Re: WindowBuilder Issue [message #867934 is a reply to message #867228] Tue, 01 May 2012 11:04 Go to previous messageGo to next message
thx, but i already started with the docs.
but no matter which setting i chose it always shows the same shit:
Re: WindowBuilder Issue [message #868563 is a reply to message #867934] Wed, 02 May 2012 04:23 Go to previous message
Hans Mueller wrote on Tue, 01 May 2012 11:04
Should I translate the above as "Java always shows the same LAF for my app"?
If you have read the doc page I linked to, does that mean that you now know how to set the LAF of your app? What setting(s) are you using?
I would suggest providing a test case and describing what you have done to set the LAF. Specifically, what code are you using to set the LAF?
Previous Topic:ExpressionConverter null - assertionException
Next Topic:Need help with an internal error issue
Current Time: Wed May 22 22:18:38 EDT 2013
Powered by FUDForum. Page generated in 0.01985 seconds
