Home » Modeling » UML2 » Registering Ecore.profile.uml
Registering Ecore.profile.uml [message #868072] Tue, 01 May 2012 12:26 Go to next message
Tex Iano is currently offline Tex Iano
Member
I want to register the Ecore.profile.uml with the nsURI
.eclipse.org/uml2/schemas/Ecore/5 (not allowed to post links)
For UML I did it this way:
EPackage.Registry.INSTANCE.put(UMLPackageImpl.eINSTANCE.getNsURI(), UMLPackageImpl.eINSTANCE);
However, I do not find the class representing the Ecore.profile.uml.
This is what I found out:
EPackage.Registry.INSTANCE.put(UMLResourceImpl.ECORE_PROFILE_NS_URI, ???);
I can find the NS_URI using the UMLResource. But where is the instance that I can link to this URI? Any ideas?
regards,
Tex
Re: Registering Ecore.profile.uml [message #868240 is a reply to message #868072] Tue, 01 May 2012 14:09 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. Damus
Hi, Tex,
Firstly, you don't need to use the UMLPackageImpl and UMLResourceImpl
classes. The UMLPackage interface defines the eNS_URI constant that
you need for registering the package and the UMLResource interface
defines the ECORE_PROFILE_NS_URI constant. You should never need to
use the Impl classes.
The Ecore Profile is not a generated package. Its Ecore definition is
dynamic, defined within the Ecore.profile.uml resource, itself. So,
you'll need to set up the registration to ape what the
org.eclipse.uml2.uml.resources plug-in's plugin.xml does:
<extension
point="org.eclipse.uml2.uml.dynamic_package">
<profile uri="http://www.eclipse.org/uml2/schemas/Ecore/5"
location="pathmap://UML_PROFILES/Ecore.profile.uml#_0"/>
</extension>
HTH,
Christian
On 2012-05-01 16:26:43 +0000, Tex Iano said:
> regards,
> Tex
Re: Registering Ecore.profile.uml [message #868548 is a reply to message #868240] Wed, 02 May 2012 03:47 Go to previous message
Member
Ahh ok, thanks Smile Not its working.
Tex
[Updated on: Wed, 02 May 2012 03:47]
Report message to a moderator
Previous Topic:EMF wizard, UML2 and package name case
Next Topic:Transform UML2XSD
Current Time: Sun May 19 18:32:33 EDT 2013
Powered by FUDForum. Page generated in 0.01587 seconds
