| [ATL] Feature ... is not changeable [message #788838] |
Thu, 02 February 2012 04:33  |
st oehm Messages: 79 Registered: October 2009 |
Member |
i'm trying to perform a M2M-transformation from an Java-Model (created with MoDisco) to an UML-Model.
My Problem: If i try to set the owner of a UML::Property i always get the error message "Feature owner is not changeable". I know that in the UML Metamodel owner is declared as not changeable, but despite that is there a way to set the owner during the transformation? Perhaps to force ATL to set this attribute?
I already tried to set the ownedAttribute-Field of an UML::Class to the corresponding attributes of the Java-Modell, but that didn't work either.
So, i hope that there is a possibility to force ATL to set this owner-Field.
Thanks for your answers!
Stoehm
| Re: [ATL] Feature ... is not changeable [message #789126 is a reply to message #789116] |
Thu, 02 February 2012 11:22   |
Ed Willink Messages: 3183 Registered: July 2009 |
Cross-resource containment is a different issue. I think it's normally
disabled because it's expensive but you can enable it when you genmodel.
However the message may indicate something nastier like putting an input
element ion an output resource. I've never been able to understand ATL
so I cannot help you on ATL-specific subtleties.
Ed Willink
On 02/02/2012 16:12, st oehm wrote:
> Edward Willink wrote on Thu, 02 February 2012 04:52
>> Hi
>> The UML meta-model has a variety of subset properties and generally
>> you can only change one of them.
>> I suggest checking that you add to the container from which the
>> subsets are built.
>> Regards
>> Ed Willink
> Hi Ed,
> thanks for your answer. But i think i dont get it.
> Now i've tried it that way:
> rule Class2Class {
> from
> jClassDeclaration : JAVA!ClassDeclaration,
> jClassModifier : JAVA!Modifier (
> jClassDeclaration.modifier = jClassModifier
> to
> umlClass : UML!Class (
> name <- jClassDeclaration.name,
> package <- jClassDeclaration.package,
> visibility <- jClassModifier.getVisibility(),
> isAbstract <- jClassModifier.isAbstract(),
> isLeaf <- jClassModifier.isFinal(),
> -- isActive <-
> -- elementImport <- -- packageImport <-
> -- clientDependency <-
> -- nestedClassifier <- -- ownedOperation <-
> ownedAttribute <-
> jClassDeclaration.bodyDeclarations->select(e |
> e.oclIsKindOf(JAVA!FieldDeclaration))
> -- ownedConnector <- -- ownedPort <-
> -- generalization <-
> -- general <-
> -- interfaceRealization <-
> -- superClass <- jClassDeclaration.superClass.type
> -- _ <- jClassDeclaration.superInterfaces
> But I always get the warning "Cannot set feature ownedAttribute to
> value ... containment references cannot span across models."
> I don't know whats the Problem with that transformation. In an other
> transformation I do it that way: packagedElement <-
> jPackage.ownedElements and that works fine.
| Re: [ATL] Feature ... is not changeable [message #840607 is a reply to message #788838] |
Tue, 10 April 2012 05:42   |
Member |
Hi again,
i solved the Problem two Month ago, and i only want to post the answer for that Problem.
The Key was the FieldDeclaration2Property-Transformation. I matched FieldDeclaration AND Modifier, and so the created Properties didn't go into the ownedAttribute because of the Modifier-Match.
Now my Rule FieldDeclaration2Property works without the Modifier-Match and the Properties are all on the place where they should be
Greetings,
Stoehm
[Updated on: Tue, 10 April 2012 05:42] Report message to a moderator
FUDForum. Page generated in 0.02505 seconds
