| Re: WindowBuilder Issue [message #868563 is a reply to message #867934] |
Wed, 02 May 2012 04:23  |
Eric Clayberg Messages: 737 Registered: July 2009 Location: Boston, MA |
Hans Mueller wrote on Tue, 01 May 2012 11:04it always shows the same shit
Should I translate the above as "Java always shows the same LAF for my app"?
If you have read the doc page I linked to, does that mean that you now know how to set the LAF of your app? What setting(s) are you using?
I would suggest providing a test case and describing what you have done to set the LAF. Specifically, what code are you using to set the LAF?
FUDForum. Page generated in 0.07656 seconds
