Home » Language IDEs » Java Development Tools (JDT) » unable to launch
unable to launch [message #790811] Sat, 04 February 2012 17:16 Go to next message
yasin alm is currently offline yasin alm
hi,
I have a problem that some other users face.
when i try to launch my java class it gives a error message;
"The application cannot be launched and there is no other recent launches."
Also, when i look at the preference-> launching-> default launchers, there is nothing here.
In addition, there no Java Project option under the file->new directory.
What is the problem, can you help?
Re: unable to launch [message #790837 is a reply to message #790811] Sat, 04 February 2012 18:13 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
On 02/04/2012 04:16 PM, yasin alm wrote:
> hi,
It sounds like you don't have the Java development tools installed.
What version/package of Eclipse did you download?
Re: unable to launch [message #791137 is a reply to message #790837] Sun, 05 February 2012 05:36 Go to previous messageGo to next message
eclipse-jdt is installed, too.Version of both eclipse and jdt is 3.7.1
and this is theconfiguration info;
*** Date: 05 Şubat 2012 Pazar 02:13:15 Doğu Avrupa Saati
*** Platform Details:
*** System properties:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20110909-1335
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-showsplash
/opt/eclipse//plugins/org.eclipse.platform_3.7.1.v201109091335/splash.bmp
-launcher
/opt/eclipse/eclipse
-name
Eclipse
--launcher.library
/opt/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.100.v20110505/eclipse_1407.so
-startup
/opt/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.overrideVmargs
-vm
/opt/sun-jdk/jre/bin/../lib/i386/client/libjvm.so
eclipse.home.location=file:/opt/eclipse/
eclipse.launcher=/opt/eclipse/eclipse
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=PlatformProfile
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1328400758673
eclipse.vm=/opt/sun-jdk/jre/bin/../lib/i386/client/libjvm.so
eclipse.vmargs=-Xms40m
-Xmx384m
-Dorg.eclipse.swt.browser.UseWebKitGTK=true
-XX:MaxPermSize=256m
-Djava.class.path=/opt/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
equinox.use.ds=true
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.version=50.0
java.endorsed.dirs=/opt/sun-jdk/jre/lib/endorsed
java.ext.dirs=/opt/sun-jdk/jre/lib/ext:/usr/java/packages/lib/ext
java.home=/opt/sun-jdk/jre
java.io.tmpdir=/tmp
java.library.path=/opt/sun-jdk/jre/lib/i386/client:/opt/sun-jdk/jre/lib/i386::/usr/java/packages/lib/i386:/lib:/usr/lib
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_26-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=//java.sun.com/
java.vendor.url.bug=//java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_26
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=20.1-b02
line.separator=
org.eclipse.equinox.launcher.splash.location=/opt/eclipse//plugins/org.eclipse.platform_3.7.1.v201109091335/splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=tr
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.37.6
org.osgi.framework.processor=x86
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List<Version>="1.0, 1.1, 1.2",osgi.ee; osgi.ee="JavaSE"; version:List<Version>="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6"
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.uuid=208cde1d-8e4f-0011-1d14-f0a318d2a534
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.6.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=i386
os.name=Linux
os.version=2.6.37.6
osgi.arch=x86
osgi.bundles=reference:file:org.eclipse.equinox.simpleconfigurator_1.0.200.v20110502-1955.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=/home/almalioglu/.eclipse/org.eclipse.platform_3.7.0_1473617060/configuration/org.eclipse.osgi/bundles
osgi.configuration.area=file:/home/almalioglu/.eclipse/org.eclipse.platform_3.7.0_1473617060/configuration/
osgi.framework=file:/opt/eclipse/plugins/org.eclipse.osgi_3.7.1.R37x_v20110808-1106.jar
osgi.framework.extensions=
osgi.framework.shape=jar
osgi.framework.version=3.7.1.R37x_v20110808-1106
osgi.install.area=file:/opt/eclipse/
osgi.instance.area=file:/home/almalioglu/EclipseBench/
osgi.instance.area.default=file:/home/almalioglu/workspace/
osgi.logfile=/home/almalioglu/EclipseBench/.metadata/.log
osgi.manifest.cache=/home/almalioglu/.eclipse/org.eclipse.platform_3.7.0_1473617060/configuration/org.eclipse.osgi/manifests
osgi.nl=tr_TR
osgi.os=linux
osgi.sharedConfiguration.area=file:/opt/eclipse/configuration/
osgi.splashLocation=/opt/eclipse//plugins/org.eclipse.platform_3.7.1.v201109091335/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/opt/eclipse/plugins
osgi.tracefile=/home/almalioglu/EclipseBench/.metadata/trace.log
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/opt/sun-jdk/jre/lib/resources.jar:/opt/sun-jdk/jre/lib/rt.jar:/opt/sun-jdk/jre/lib/sunrsasign.jar:/opt/sun-jdk/jre/lib/jsse.jar:/opt/sun-jdk/jre/lib/jce.jar:/opt/sun-jdk/jre/lib/charsets.jar:/opt/sun-jdk/jre/lib/modules/jdk.boot.jar:/opt/sun-jdk/jre/classes
sun.boot.library.path=/opt/sun-jdk/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=unknown
user.country=TR
user.dir=/home/almalioglu/Belgeler
user.home=/home/almalioglu
user.language=tr
user.name=almalioglu
user.timezone=Europe/Istanbul
*** Features:
org.eclipse.help (1.3.0.v20110327-7i7uFFkFFp7gNobOpNgKo0) "Help System Base"
org.eclipse.platform (3.7.1.r37x_v20110729-9gF7UHOxFtniV7mI3T556iZN9AU8bEZ1lHMcVK) "Eclipse Platform"
org.eclipse.rcp (3.7.1.r37x_v20110729-9DB5FmNFnFLSFCtLxnRfMqt15A4A) "Eclipse RCP"
*** Plug-in Registry:
com.ibm.icu (4.4.2.v20110208) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v201101211617) "JSch" [Resolved]
javax.servlet (2.5.0.v201103041518) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v201101211617) "Java Server Pages API Bundle" [Resolved]
org.apache.ant (1.8.2.v20110505-1300) "Apache Ant" [Resolved]
org.apache.commons.codec (1.3.0.v201101211617) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.el (1.0.0.v201101211617) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v201012070820) "Apache Commons Httpclient" [Resolved]
org.apache.commons.logging (1.0.4.v201101211617) "Apache Commons Logging Plug-in" [Resolved]
org.apache.jasper (5.5.17.v201101211617) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.lucene (2.9.1.v201101211721) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (2.9.1.v201101211721) "Apache Lucene Analysis" [Resolved]
org.apache.lucene.core (2.9.1.v201101211721) "Apache Lucene Core" [Resolved]
org.eclipse.ant.core (3.2.300.v20110511) "Ant Build Tool Core" [Starting]
org.eclipse.compare (3.5.201.R37x_v20110817-0800) "Compare Support" [Starting]
org.eclipse.compare.core (3.5.200.I20110208-0800) "Core Compare Support" [Active]
org.eclipse.core.boot (3.1.200.v20100505) "Core Boot" [Starting]
org.eclipse.core.commands (3.6.0.I20110111-0800) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.100.v20110423-0524) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.4.0.I20110111-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.100.I20100824-0800) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.4.0.I20110222-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.4.0.I20110222-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.300.v20110228) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.100.v20110506) "External Tools Headless Support" [Starting]
org.eclipse.core.filebuffers (3.5.200.v20110505-0800) "File Buffers" [Active]
org.eclipse.core.filesystem (1.3.100.v20110423-0524) "Core File Systems" [Active]
org.eclipse.core.filesystem.linux.x86 (1.4.0.v20110423-0524) "Core File System for Linux" [Resolved]
org.eclipse.core.jobs (3.5.100.v20110404) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.100.I20110511-0800) "Internet Connection Management" [Active]
org.eclipse.core.net.linux.x86 (1.1.200.I20110419-0800) "Proxy for Linux" [Resolved]
org.eclipse.core.resources (3.7.100.v20110510-0712) "Core Resource Management" [Active]
org.eclipse.core.runtime (3.7.0.v20110110) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.100.v20100505) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.200.v20110110) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.5.0.v20110505) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.500.v20110511) "Core Variables" [Starting]
org.eclipse.debug.core (3.7.0.v20110518) "Debug Core" [Starting]
org.eclipse.debug.ui (3.7.101.v20110817_r371) "Debug UI" [Starting]
org.eclipse.ecf (3.1.300.v20110531-2218) "ECF Core API" [Active]
org.eclipse.ecf.filetransfer (5.0.0.v20110531-2218) "ECF Filetransfer API" [Active]
org.eclipse.ecf.identity (3.1.100.v20110531-2218) "ECF Core Identity API" [Active]
org.eclipse.ecf.provider.filetransfer (3.2.0.v20110531-2218) "ECF Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient (4.0.0.v20110531-2218) "ECF HttpClient Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient.ssl (1.0.0.v20110531-2218) "ECF HttpClient Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20110531-2218) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.100.v20110531-2218) "ECF Core API" [Resolved]
org.eclipse.equinox.app (1.3.100.v20110321) "Equinox Application Container" [Active]
org.eclipse.equinox.common (3.6.0.v20110523) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.0.200.v20110502) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.ds (1.3.1.R37x_v20110701) "Declarative Services" [Active]
org.eclipse.equinox.event (1.2.100.v20110502) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.0.0.v20110502-1955) "Equinox Framework Admin" [Starting]
org.eclipse.equinox.frameworkadmin.equinox (1.0.300.v20110506) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (2.0.100.v20110502) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.100.v20110502) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.200.v20110502) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.300.v20110502) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.200.v20100503) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.2.0.v20110502) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.gtk.linux.x86 (1.1.100.v20110505) "Equinox Launcher Linux X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.1.101.R37x_v20110714) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.300.v20110502-1955) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.1.0.v20110502-1955) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.1.0.v20110504-1715) "Equinox Provisioning Director" [Starting]
org.eclipse.equinox.p2.director.app (1.0.300.v20110505) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.300.v20110502-1955) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.engine (2.1.0.v20110511) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.2.100.v20110510) "Equinox Provisioning Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.200.v20110510) "Equinox Provisioning Garbage Collector" [Starting]
org.eclipse.equinox.p2.jarprocessor (1.0.200.v20110502-1955) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.1.0.v20110510) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.repository (1.2.0.v20110511-1359) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.1.0.v20110511-1821) "Equinox Provisioning Operations API" [Active]
org.eclipse.equinox.p2.publisher (1.2.0.v20110511) "Equinox Provisioning Publisher Infrastructure" [Starting]
org.eclipse.equinox.p2.publisher.eclipse (1.0.0.v20110511) "Equinox Provisioning Publisher for Eclipse" [Starting]
org.eclipse.equinox.p2.ql (2.0.100.v20110510) "Equinox Provisioning p2 query language" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.1.100.v20110510) "Equinox Provisioning Drop-in" [Active]
org.eclipse.equinox.p2.repository (2.1.0.v20110601) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.0.100.v20110512-1320) "Equinox Provisioning Repository Tools" [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.1.1.R37x_v20110815-0935) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.0.300.v20110502-1955) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.transport.ecf (1.0.0.v20110510) "Equinox Provisioning ECF based Transport" [Active]
org.eclipse.equinox.p2.ui (2.1.0.v20110601) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.importexport (1.0.0.v20110511) "Equinox Provisioning Import and Export" [Starting]
org.eclipse.equinox.p2.ui.sdk (1.0.200.v20110502-1955) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.0.100.v20110502-1955) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.200.v20110502-1955) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.300.v20110510) "Equinox Provisioning Legacy Update Site Support" [Starting]
org.eclipse.equinox.preferences (3.4.1.R37x_v20110725) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.101.R37x_v20110810-1611) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.1.1.R37x_v20110822-1018) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.1.0.v20101004) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.simpleconfigurator (1.0.200.v20110502-1955) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.0.0.v20110502-1955) "Simple Configurator Manipulator" [Starting]
org.eclipse.equinox.util (1.0.300.v20110502) "Equinox Util Bundle" [Active]
org.eclipse.help (3.5.100.v20110426) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.400.v20110425) "Help Application Server" [Starting]
org.eclipse.help.base (3.6.1.v201109091335) "Help System Base" [Starting]
org.eclipse.help.ui (3.5.101.r37_20110819) "Help System UI" [Starting]
org.eclipse.help.webapp (3.6.0.v20110518) "Help System Webapp" [Starting]
org.eclipse.jface (3.7.0.I20110522-1430) "JFace" [Active]
org.eclipse.jface.databinding (1.5.0.I20100907-0800) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.7.1.r371_v20110825-0800) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.1.300.I20110514-0800) "JSch Core" [Starting]
org.eclipse.jsch.ui (1.1.300.I20110511-0800) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.5.201.r371_v20110824-0800) "Refactoring Core" [Starting]
org.eclipse.ltk.ui.refactoring (3.6.0.v20110505-0800) "Refactoring UI" [Starting]
org.eclipse.osgi (3.7.1.R37x_v20110808-1106) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.3.0.v20110513) "OSGi Release 4.2.0 Services" [Resolved]
org.eclipse.osgi.util (3.2.200.v20110110) "OSGi Release 4.2.0 Utility Classes" [Resolved]
org.eclipse.platform (3.7.1.v201109091335) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.user (3.7.0.v20110601-0800) "Eclipse Workbench User Guide" [Resolved]
org.eclipse.rcp (3.7.0.v201109091335) "Eclipse RCP" [Starting]
org.eclipse.search (3.7.0.v20110505-0800) "Search Support" [Starting]
org.eclipse.swt (3.7.1.v3738a) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk.linux.x86 (3.7.1.v3738a) "Standard Widget Toolkit for GTK 2.0" [Resolved]
org.eclipse.team.core (3.6.0.I20110525-0800) "Team Support Core" [Active]
org.eclipse.team.ui (3.6.100.I20110525-0800) "Team Support UI" [Starting]
org.eclipse.text (3.5.101.r371_v20110810-0800) "Text" [Resolved]
org.eclipse.ui (3.7.0.I20110602-0100) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.3.100.v20110426) "Browser Support" [Starting]
org.eclipse.ui.cheatsheets (3.4.100.v20110425) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.5.100.v20110511) "Console" [Active]
org.eclipse.ui.editors (3.7.0.v20110517-0800) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.2.0.v20110506) "External Tools" [Starting]
org.eclipse.ui.forms (3.5.100.v20110425) "Eclipse Forms" [Starting]
org.eclipse.ui.ide (3.7.0.v20110809-1737) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.300.I20110306-2000) "Eclipse IDE UI Application" [Resolved]
org.eclipse.ui.intro (3.4.100.v20110425) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.500.v20110510) "Universal Welcome" [Starting]
org.eclipse.ui.navigator (3.5.100.v20110809-2227) "Common Navigator View" [Starting]
org.eclipse.ui.navigator.resources (3.4.300.I20110421-1800) "Navigator Workbench Components" [Starting]
org.eclipse.ui.net (1.2.100.I20110511-0800) "Internet Connection Management UI" [Active]
org.eclipse.ui.presentations.r21 (3.2.200.I20100517-1500) "R21 Presentation Plug-in" [Starting]
org.eclipse.ui.views (3.6.0.I20110412-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.5.200.I20110201-0800) "Tabbed Properties View" [Starting]
org.eclipse.ui.workbench (3.7.0.I20110519-0100) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.100.I20110413-1600) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.7.0.v20110505-0800) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.3.100.v20100512) "Install/Update Configurator" [Active]
org.eclipse.update.core (3.2.500.v20110330) "Install/Update Core" [Active]
org.eclipse.update.core.linux (3.2.200.v20100512) "Install/Update Core for Linux" [Resolved]
org.eclipse.update.scheduler (3.2.300.v20100512) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.2.300.v20100512) "Install/Update UI" [Starting]
org.mortbay.jetty.server (6.1.23.v201012071420) "Jetty Server" [Resolved]
org.mortbay.jetty.util (6.1.23.v201012071420) "Jetty Utilities" [Resolved]
org.sat4j.core (2.3.0.v20110329) "SAT4J Core" [Resolved]
org.sat4j.pb (2.3.0.v20110329) "SAT4J Pseudo" [Resolved]
*** User Preferences:
#Sun Feb 05 02:13:17 EET 2012
/bundle_defaults/org.eclipse.core.resources/description.buildorder=
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time=false
/bundle_defaults/org.eclipse.ui.editors/othersIndicationInOverviewRuler=false
/instance/org.eclipse.ant.ui/useQuickDiffPrefPage=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_R/uri=http\://download.eclipse.org/technology/epp/packages/indigo/R/
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_categories/uri=http\://download.eclipse.org/eclipse/updates/3.7/categories
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_R/name=Feature
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201109230900/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0" encoding\="UTF-8"?>\n<editors version\="3.1">\n<info extension\="html" name\="*">\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\n</info>\n<info extension\="htm" name\="*">\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\n</info>\n<info extension\="shtml" name\="*">\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\n</info>\n</editors>
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_SR1/isSystem=true
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationInOverviewRuler=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_updates_releases/isSystem=false
/instance/org.eclipse.ui.workbench/<Java>_persp=<?xml version\="1.0" encoding\="UTF-8"?>\n<perspective editorAreaTrimState\="2" editorAreaVisible\="1" fixed\="0" version\="0.016">\n<descriptor descriptor\="org.eclipse.jdt.ui.JavaPerspective" id\="&lt;Java&gt;" label\="&lt;Java&gt;"/>\n<window height\="546" width\="1024" x\="0" y\="0"/>\n<alwaysOnActionSet id\="org.eclipse.ui.cheatsheets.actionSet"/>\n<alwaysOnActionSet id\="org.eclipse.search.searchActionSet"/>\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.annotationNavigation"/>\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo"/>\n<alwaysOnActionSet id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\n<alwaysOnActionSet id\="org.eclipse.ui.actionSet.keyBindings"/>\n<alwaysOnActionSet id\="org.eclipse.ui.actionSet.openFiles"/>\n<alwaysOnActionSet id\="org.eclipse.debug.ui.launchActionSet"/>\n<alwaysOnActionSet id\="org.eclipse.ui.NavigateActionSet"/>\n<alwaysOnActionSet id\="org.eclipse.debug.ui.breakpointActionSet"/>\n<alwaysOnActionSet id\="org.eclipse.debug.ui.debugActionSet"/>\n<show_view_action id\="org.eclipse.jdt.ui.PackageExplorer"/>\n<show_view_action id\="org.eclipse.jdt.ui.TypeHierarchy"/>\n<show_view_action id\="org.eclipse.jdt.ui.SourceView"/>\n<show_view_action id\="org.eclipse.jdt.ui.JavadocView"/>\n<show_view_action id\="org.eclipse.search.ui.views.SearchView"/>\n<show_view_action id\="org.eclipse.ui.console.ConsoleView"/>\n<show_view_action id\="org.eclipse.ui.views.ContentOutline"/>\n<show_view_action id\="org.eclipse.ui.views.ProblemView"/>\n<show_view_action id\="org.eclipse.ui.views.ResourceNavigator"/>\n<show_view_action id\="org.eclipse.ui.views.TaskList"/>\n<show_view_action id\="org.eclipse.ui.views.ProgressView"/>\n<show_view_action id\="org.eclipse.ui.navigator.ProjectExplorer"/>\n<show_view_action id\="org.eclipse.ui.texteditor.TemplatesView"/>\n<show_view_action id\="org.eclipse.pde.runtime.LogView"/>\n<show_view_action id\="org.eclipse.ant.ui.views.AntView"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.JavaProjectWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewPackageCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewClassCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewInterfaceCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewEnumCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewAnnotationCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewSourceFolderCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewSnippetFileCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewJavaWorkingSetWizard"/>\n<new_wizard_action id\="org.eclipse.ui.wizards.new.folder"/>\n<new_wizard_action id\="org.eclipse.ui.wizards.new.file"/>\n<new_wizard_action id\="org.eclipse.ui.editors.wizards.UntitledTextFileWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.junit.wizards.NewTestCaseCreationWizard"/>\n<perspective_action id\="org.eclipse.jdt.ui.JavaBrowsingPerspective"/>\n<perspective_action id\="org.eclipse.debug.ui.DebugPerspective"/>\n<hide_toolbar_item_id id\="org.eclipse.jdt.ui.actions.OpenProjectWizard"/>\n<hide_toolbar_item_id id\="org.eclipse.ui.edit.text.toggleShowSelectedElementOnly"/>\n<view id\="org.eclipse.ui.views.ResourceNavigator"/>\n<view id\="org.eclipse.ui.views.ProblemView"/>\n<view id\="org.eclipse.search.ui.views.SearchView"/>\n<view id\="org.eclipse.debug.ui.DebugView"/>\n<view id\="org.eclipse.ui.console.ConsoleView"/>\n<view id\="org.eclipse.ui.views.ContentOutline"/>\n<fastViewBars/>\n<layout>\n<mainWindow>\n<info folder\="true" part\="left">\n<folder activePageID\="org.eclipse.ui.views.ResourceNavigator" appearance\="2" expanded\="2">\n<page content\="org.eclipse.ui.views.ResourceNavigator" label\="Navigator"/>\n<page content\="org.eclipse.jdt.ui.PackageExplorer" label\="LabelNotFound"/>\n<page content\="org.eclipse.jdt.ui.TypeHierarchy" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.navigator.ProjectExplorer" label\="LabelNotFound"/>\n<page content\="org.eclipse.jdt.junit.ResultView" label\="LabelNotFound"/>\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\n<part id\="0"/>\n</presentation>\n</folder>\n</info>\n<info folder\="true" part\="stickyFolderRight" ratio\="0.7495049" ratioLeft\="757" ratioRight\="253" relationship\="2" relative\="left">\n<folder appearance\="2" expanded\="2">\n<page content\="org.eclipse.help.ui.HelpView" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.internal.introview" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.cheatsheets.views.CheatSheetView" label\="LabelNotFound"/>\n</folder>\n</info>\n<info part\="org.eclipse.ui.editorss" ratio\="0.18272096" ratioLeft\="184" ratioRight\="823" relationship\="2" relative\="left"/>\n<info folder\="true" part\="bottom" ratio\="0.38173303" ratioLeft\="163" ratioRight\="264" relationship\="4" relative\="org.eclipse.ui.editorss">\n<folder activePageID\="org.eclipse.ui.console.ConsoleView" appearance\="2" expanded\="2">\n<page content\="org.eclipse.ui.views.ProblemView" label\="Problems"/>\n<page content\="org.eclipse.search.ui.views.SearchView" label\="Search"/>\n<page content\="org.eclipse.debug.ui.DebugView" label\="Debug"/>\n<page content\="org.eclipse.ui.console.ConsoleView" label\="Console"/>\n<page content\="org.eclipse.jdt.ui.JavadocView" label\="LabelNotFound"/>\n<page content\="org.eclipse.jdt.ui.SourceView" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.views.BookmarkView" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.views.ProgressView" label\="LabelNotFound"/>\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\n<part id\="0"/>\n<part id\="1"/>\n<part id\="2"/>\n<part id\="3"/>\n</presentation>\n</folder>\n</info>\n<info folder\="true" part\="right" ratio\="0.74934036" ratioLeft\="568" ratioRight\="190" relationship\="2" relative\="org.eclipse.ui.editorss">\n<folder activePageID\="org.eclipse.ui.views.ContentOutline" appearance\="2" expanded\="2">\n<page content\="org.eclipse.ui.views.ContentOutline" label\="Outline"/>\n<page content\="org.eclipse.ant.ui.views.AntView" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.texteditor.TemplatesView" label\="LabelNotFound"/>\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\n<part id\="0"/>\n</presentation>\n</folder>\n</info>\n</mainWindow>\n</layout>\n</perspective>
/bundle_defaults/org.eclipse.ui.editors/quickdiff.nowarn.before.switch=
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_gmf_updates_milestones/enabled=false
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/schedule=on-startup
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.dropdown=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_SR1/suffix=content.xml
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_windowbuilder_WB_integration_3.7/enabled=false
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.updateInterval=500
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/bundle_defaults/org.eclipse.ui.editors/quickdiff.quickDiff=true
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.previous=false
/bundle_defaults/org.eclipse.ui.editors/showFilteredSearchResultInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Navigation.SmartHomeEnd=true
/instance/org.eclipse.debug.ui/preferredDetailPanes=DefaultDetailPane\:DefaultDetailPane|org.eclipse.jdt.debug.ui.DETAIL_PANE_LINE_BREAKPOINT\:org.eclipse.jdt.debug.ui.DETAIL_PANE_LINE_BREAKPOINT|
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201109230900/isSystem=false
/bundle_defaults/org.eclipse.ui/LINK_NAVIGATOR_TO_EDITOR=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.text=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_subversive_0.7_update-site/enabled=false
/bundle_defaults/org.eclipse.ui.editors/taskTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.ui/SHIFT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui.editors/hyperlinkKeyModifierMask=262144
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_xpand_updates/isSystem=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.text=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_cdt_releases_indigo/isSystem=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_R-3.7-201106131736/uri=http\://download.eclipse.org/eclipse/updates/3.7/R-3.7-201106131736
/bundle_defaults/org.eclipse.ui.workbench/ENABLED_DECORATORS=
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_R-3.7-201106131736/version=1.0.0
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/printMargin=false
/bundle_defaults/org.eclipse.ui.ide/LIMIT_BOOKMARKS=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_egit_updates/enabled=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.color=50,70,120
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_opt_eclipse_.eclipseextension/isSystem=true
/bundle_defaults/org.eclipse.ui.editors/isAdditionGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndication=true
/instance/org.eclipse.debug.ui/preferredTargets=default\:default|
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_home_almalioglu_.eclipse_org.eclipse.platform_3.7.0_1473617060_configuration_org.eclipse.osgi_bundles_79_data_listener_1925729951/uri=file\:/home/almalioglu/.eclipse/org.eclipse.platform_3.7.0_1473617060/configuration/org.eclipse.osgi/bundles/79/data/listener_1925729951/
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_ptp_updates_indigo/enabled=false
/bundle_defaults/org.eclipse.ui.editors/currentIPOverviewRuler=true
/instance/org.eclipse.jdt.debug.ui/org.eclipse.jdt.debug.ui.javaDebug.alertHCRFailed=false
/bundle_defaults/org.eclipse.ui.editors/isErrorGoToPreviousNavigationTarget=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo/name=EPP Packages Repository
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_opt_eclipse_.eclipseextension/name=/opt/eclipse/.eclipseextension
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_emft_updates/isSystem=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS_BOOLEAN=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_gmf_updates_milestones/uri=http\://download.eclipse.org/modeling/gmf/updates/milestones/
/bundle_defaults/org.eclipse.ui.editors/textDragAndDropEnabled=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_SR1/name=Feature
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_egit_updates/isSystem=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7/nickname=The Eclipse Project Updates
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__eclipse.org_modeling_emft_updates/uri=http\:eclipse.org/modeling/emft/updates/
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/hasAuth=false
/bundle_defaults/org.eclipse.ui.editors/secondaryIPTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionForeground.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/linked.exit.verticalruler=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_mylyn_releases_3.6/isSystem=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_home_almalioglu_.eclipse_org.eclipse.platform_3.7.0_1473617060_configuration_org.eclipse.osgi_bundles_79_data_listener_1925729951/isSystem=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.width=
/instance/org.eclipse.jdt.ui/breadcrumb.org.eclipse.jdt.ui.JavaPerspective=true
/bundle_defaults/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=prompt
/bundle_defaults/org.eclipse.ui.editors/changeIndication=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201106220900/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_categories/enabled=false
/project/lab/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.debug.sourceFile=generate
/instance/org.eclipse.core.resources/version=1
/project/lab/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.enumIdentifier=error
/bundle_defaults/org.eclipse.ui.ide/PROBLEMS_LIMIT=100
/bundle_defaults/org.eclipse.ui.editors/searchResultTextStyle=NONE
/bundle_defaults/org.eclipse.core.net/nonProxiedHosts=localhost|127.0.0.1
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/showInfoInNextPrevDropdownToolbarAction=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocations.migrated=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_updates_udc/uri=http\://download.eclipse.org/technology/epp/updates/udc/
/bundle_defaults/org.eclipse.ui.editors/linked.slave.verticalruler=false
/bundle_defaults/org.eclipse.ui.ide/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui.editors/showTaskInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.showMax=false
/bundle_defaults/org.eclipse.ui.editors/infoIndicationHighlighting=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__dev.eclipse.org_svnroot_dsdp_org.eclipse.tm.tcf_releases_0.4.0/uri=http\://dev.eclipse.org/svnroot/dsdp/org.eclipse.tm.tcf/releases/0.4.0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_emft_mwe_updates/isSystem=false
/bundle_defaults/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_CREATION=prompt
/instance/org.eclipse.jdt.ui/fontPropagated=true
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Background=255,255,255
/bundle_defaults/org.eclipse.ui.editors/isSearchResultGoToNextNavigationTarget=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_emft_updates/enabled=false
/bundle_defaults/org.eclipse.ui.editors/taskIndicationColor=0,128,255
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201109230900/enabled=true
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/errorIndicationColor=255,0,128
/bundle_defaults/org.eclipse.ui/RECENTLY_USED_WORKINGSETS_SIZE=5
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
/bundle_defaults/org.eclipse.ui.ide/TASKS_LIMIT=100
/bundle_defaults/org.eclipse.core.resources/description.applyfilestatepolicy=true
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationColor=34,164,99
/instance/org.eclipse.ui.workbench/RUN_IN_BACKGROUND=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201106220900/enabled=false
/bundle_defaults/org.eclipse.ui.editors/printMarginColor=176,180,185
@org.eclipse.ui=3.7.0.I20110602-0100
/bundle_defaults/org.eclipse.core.resources/description.defaultbuildorder=true
/bundle_defaults/org.eclipse.ui.editors/taskIndication=false
/bundle_defaults/org.eclipse.ui.editors/warningIndication=true
/bundle_defaults/org.eclipse.ui/SHOW_MULTIPLE_EDITOR_TABS=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_jwt_update-site/isSystem=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_orbit_downloads_drops_R20100519200754_repository/uri=http\://download.eclipse.org/tools/orbit/downloads/drops/R20100519200754/repository
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationColor=0,0,0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_mylyn_update_e3.4/uri=http\://download.eclipse.org/tools/mylyn/update/e3.4/
/bundle_defaults/org.eclipse.ui.editors/showTrailingSpaces=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_windowbuilder_WB_integration_3.7/uri=http\://download.eclipse.org/windowbuilder/WB/integration/3.7
/instance/org.eclipse.help.base/always_external_browser=false
/bundle_defaults/org.eclipse.ui.editors/show_range_indicator=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/isBreakpointIndicationGoToPreviousNavigationTarget=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_updates/enabled=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo/description=
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInVerticalRuler=true
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/bundle_defaults/org.eclipse.ui.ide/saveInterval=5
/bundle_defaults/org.eclipse.ui.ide/USE_MARKER_LIMITS=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_R/isSystem=true
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.dropdown=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__eclipse.org_modeling_mdt_?project\=papyrus\#papyrus/isSystem=false
/bundle_defaults/org.eclipse.ui.editors/revisionRulerShowRevision=false
/project/lab/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.compliance=1.6
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_categories/version=1.0.0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__eclipse.org_modeling_updates/uri=http\:eclipse.org/modeling/updates/
/bundle_defaults/org.eclipse.ui/showIntro=true
/instance/org.eclipse.debug.core/org.eclipse.debug.core.PREF_DELETE_CONFIGS_ON_PROJECT_DELETE=false
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/port=-1
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_R-3.7.1-201109091335/suffix=content.xml
/instance/org.eclipse.help.base/help_view_open_mode=in_place
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_mdt_updates/uri=http\://download.eclipse.org/modeling/mdt/updates/
/project/lab/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.debug.localVariable=generate
/bundle_defaults/org.eclipse.ui.editors/showErrorInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.core.resources/description.filestatelongevity=604800000
/bundle_defaults/org.eclipse.ui/CLOSE_EDITORS_ON_EXIT=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_datatools_updates/uri=http\://download.eclipse.org/datatools/updates
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_emft_updates/uri=http\://download.eclipse.org/technology/emft/updates/
/bundle_defaults/org.eclipse.ui.editors/linked.focus.verticalruler=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.overviewruler=false
/bundle_defaults/org.eclipse.ui.editors/spellingEnabled=false
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.DebugVieworg.eclipse.debug.ui.DebugView=<?xml version\="1.0" encoding\="UTF-8"?>\n<DebugViewMemento org.eclipse.debug.ui.BREADCRUMB_DROPDOWN_AUTO_EXPAND\="false"/>
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_updates/isSystem=false
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.FindScope=185,176,180
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201109230900/version=1.0.0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_R-3.7-201106131736/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_mdt_papyrus_updates_milestones_0.8/uri=http\://download.eclipse.org/modeling/mdt/papyrus/updates/milestones/0.8
/bundle_defaults/org.eclipse.ui.editors/linked.target.highlight=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201106220900/version=1.0.0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_xpand_updates/uri=http\://download.eclipse.org/modeling/m2t/xpand/updates/
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_updates_releases/uri=http\://download.eclipse.org/modeling/m2t/updates/releases/
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_mat_1.1_update-site/enabled=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_opt_eclipse_.eclipseextension/description=
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationColor=88,88,22
/bundle_defaults/org.eclipse.ui.editors/isRevisionAnnotationGoToNextNavigationTarget=false
/project/lab/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.targetPlatform=1.6
/bundle_defaults/org.eclipse.ui.editors/secondaryIPHighlight=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_templates_migrated=true
/bundle_defaults/org.eclipse.ui.editors/linked.slave.overviewruler=false
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST_TIME=1000
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/bundle_defaults/org.eclipse.ui.editors/showBookmarkInNextPrevDropdownToolbarAction=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo/type=org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository
/bundle_defaults/org.eclipse.ui.editors/showUnchangedInNextPrevDropdownToolbarAction=false
/configuration/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_mylyn_releases_3.6/uri=http\://download.eclipse.org/mylyn/releases/3.6
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo/suffix=compositeContent.xml
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_sequoyah_updates_2.0/uri=http\://download.eclipse.org/sequoyah/updates/2.0/
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_cdt_releases_indigo/uri=http\://download.eclipse.org/tools/cdt/releases/indigo
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToNextNavigationTarget=false
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/bundle_defaults/org.eclipse.ui.editors/hyperlinksEnabled=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.next=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7/type=org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository
/bundle_defaults/org.eclipse.ui.ide/BOOKMARKS_FILTERS_MIGRATE=false
/instance/org.eclipse.ui.workbench/STICKY_CYCLE=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_gef_updates_releases/uri=http\://download.eclipse.org/tools/gef/updates/releases
/bundle_defaults/org.eclipse.ui.editors/isTaskGoToNextNavigationTarget=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_objectteams_updates_2.0/uri=http\://download.eclipse.org/objectteams/updates/2.0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo/provider=
/bundle_defaults/org.eclipse.ui.editors/searchResultHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationColor=237,237,252
/bundle_defaults/org.eclipse.core.resources/snapshots.operations=100
/bundle_defaults/org.eclipse.ui/USE_WINDOW_WORKING_SET_BY_DEFAULT=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_R-3.7-201106131736/isSystem=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_mdt_papyrus_updates_releases/isSystem=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_objectteams_updates_2.0/enabled=false
/bundle_defaults/org.eclipse.ui.editors/currentLineColor=232,242,254
/bundle_defaults/org.eclipse.ui.editors/deletionIndication=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder.resourceCopyExclusionFilter=
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/infoIndication=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_subversive_0.7_update-site/uri=http\://download.eclipse.org/technology/subversive/0.7/update-site/
/bundle_defaults/org.eclipse.ui/SHOW_FILTERED_TEXTS=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_opt_eclipse_.eclipseextension/suffix=eclipse
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/day=Every day
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_datatools_updates/isSystem=false
/profile/f
[Updated on: Sun, 05 February 2012 05:44]
Report message to a moderator
Re: unable to launch [message #791241 is a reply to message #791137] Sun, 05 February 2012 09:07 Go to previous messageGo to next message
Nick Clevery is currently offline Nick Clevery
Member
Looks like your project is not Java project, it is a general project instead. You can modify the .project file to add Java nature to make the project as Java project.
Re: unable to launch [message #792063 is a reply to message #791137] Mon, 06 February 2012 10:14 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
The platform details indicate a very minimal Eclipse program. The JDT Feature isn't listed in the Features and none of the JDT plugins show up in the Plugin list.
How did you install Eclipse? If you used your Linux distributions package mechanism (apt, yum, etc.) then you need to uninstall if from there, go to eclipse.org and download a zip file for the version/package of Eclipse that you want to use.
Distribution packaged Eclipse versions are very difficult to get working.
Re: unable to launch [message #794494 is a reply to message #792063] Thu, 09 February 2012 06:17 Go to previous messageGo to next message
yasin alm is currently offline yasin alm
David Wegener wrote on Mon, 06 February 2012 10:14
Thanks a lot. This solved my problem. However, it is weird not to work as a distribution package. Anyway now it works well. Wink
Re: unable to launch [message #798335 is a reply to message #794494] Tue, 14 February 2012 09:56 Go to previous messageGo to next message
Bezplatni obiavi
Thanks you man. Just what i needed for.
Cheers!
Re: unable to launch [message #861589 is a reply to message #798335] Sat, 28 April 2012 12:45 Go to previous messageGo to next message
Hans Mueller is currently offline Hans Mueller
very good
Re: unable to launch [message #861590 is a reply to message #861589] Sat, 28 April 2012 12:45 Go to previous messageGo to next message
very good
Re: unable to launch [message #861591 is a reply to message #861590] Sat, 28 April 2012 12:45 Go to previous messageGo to next message
very good
Re: unable to launch [message #861592 is a reply to message #861591] Sat, 28 April 2012 12:45 Go to previous message
very good
Previous Topic:Show Local Date and Time in Eclipse
Next Topic:Error: IWAB0125E Select a node
Current Time: Wed May 22 15:03:47 EDT 2013
Powered by FUDForum. Page generated in 0.01940 seconds
