Home » Language IDEs » CDT » Eclipse Juno - CDT build project grayed out
Eclipse Juno - CDT build project grayed out [message #857561] Thu, 26 April 2012 12:58 Go to next message
Nathan Hüsken is currently offline Nathan Hüsken
I just installed the eclipse juno development build.
I know, I should not wonder if it does not work. Still, it works pretty good but for one thing:
When I am in the editor, and want to select Project -> Build Project it is grayed out.
When I select the project in the project editor, it gets enabled but it gets disabled again as soons as I select a file (within the project) in the project edtor.
is there a fix?
Thanks!
Nathan
Re: Eclipse Juno - CDT build project grayed out [message #857569 is a reply to message #857561] Thu, 26 April 2012 13:06 Go to previous messageGo to next message
Yevgeny Shifrin is currently offline Yevgeny Shifrin
I would suggest opening a bug with full problem description, so it could be solved for Juno release.
Yevgeny
Re: Eclipse Juno - CDT build project grayed out [message #858607 is a reply to message #857569] Fri, 27 April 2012 03:59 Go to previous messageGo to next message
Bug reported: Bug 377869 (I can not post links)
Re: Eclipse Juno - CDT build project grayed out [message #858896 is a reply to message #858607] Fri, 27 April 2012 06:57 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=377869
Previous Topic:Problem with GSL in Eclipse
Next Topic:No source available for "_start() at 0x8049b73"
Current Time: Sat May 25 09:23:01 EDT 2013
Powered by FUDForum. Page generated in 0.01583 seconds
