Home » Eclipse Projects » BIRT » BIRT 3.7.2: Unable to access the data from outer data set using row._outer<column-name>(Unable to access the data from outer data set using row._outer<column-name>)
BIRT 3.7.2: Unable to access the data from outer data set using row._outer<column-name> [message #858786] Fri, 27 April 2012 05:47 Go to next message
Nitesh Gupta is currently offline Nitesh Gupta
We are currently migrating to BIRT 3.7.2 from BIRT 2.3. We are facing one common issue with all report designs. Wherever we have a enclosed grid/table referring to a data set bound to an enclosing list, it gived an error saying:
Invalid bound column name: <column-name>.
In all such places we have referred to outer data set column using "row._outer".
Another important fact is that when we used BIRT 3.7 the reports were migrated easily without making any changes.
Any insights would be of great help here!
[Updated on: Fri, 27 April 2012 05:48]
Report message to a moderator
Re: BIRT 3.7.2: Unable to access the data from outer data set using row._outer&lt;column-name&am [message #859932 is a reply to message #858786] Fri, 27 April 2012 17:47 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Can you post one of the examples?
Jason
> an error saying:
> "row._outer".
Jason Weathersby
BIRT Exchange
Re: BIRT 3.7.2: Unable to access the data from outer data set using row._outer&lt;column-name&am [message #869801 is a reply to message #859932] Fri, 04 May 2012 06:57 Go to previous messageGo to next message
Apologies for late response, as we were facing an out of memory issue with 3.7.2 eclipse while testing it.
I have attached the sample report design.
Re: BIRT 3.7.2: Unable to access the data from outer data set using row._outer&amp;lt;column-nam [message #869879 is a reply to message #869801] Fri, 04 May 2012 11:45 Go to previous messageGo to next message
Nitesh,
Can you open a bugzilla entry with your example report?
Jason
Jason Weathersby
BIRT Exchange
Re: BIRT 3.7.2: Unable to access the data from outer data set using row._outer&amp;lt;column-nam [message #870153 is a reply to message #869879] Mon, 07 May 2012 00:59 Go to previous messageGo to next message
Created a Bugzilla entry Bug 377905. I have also uploaded the sample report design.
Re: BIRT 3.7.2: Unable to access the data from outer data set using row._outer&amp;amp;lt;column [message #870322 is a reply to message #870153] Mon, 07 May 2012 12:05 Go to previous message
Thanks for posting the bug number.
Jason
> report design.
Jason Weathersby
BIRT Exchange
Previous Topic:javascript to iterate through a dataset to find a value?
Next Topic:BIRT and MSSQL: No suitable driver found for jdbc:
Current Time: Sat May 25 12:09:53 EDT 2013
Powered by FUDForum. Page generated in 0.01914 seconds
