Home » Newcomers » Newcomers » Eclipse with JAR - Classpath on OpenSuse 12.1
Eclipse with JAR - Classpath on OpenSuse 12.1 [message #857785] Thu, 26 April 2012 17:37 Go to next message
martin kaspar is currently offline martin kaspar
Hello dear Eclipse-fans
well i am brandnew to eclipse - i never ever used it so far!
i run a OpenSuse Linux Version 12.1 - and all works fine.
i am currently tryin to install the OSMGenerator - a tool that allows to put OpenStreetMap files
into MySQL-databases therefore i have to setup Eclipse.
Firstly i have to setup Eclipse
The OSMGenerator is set up as an Eclipse project, so i should be able to use it directly from within Eclipse (along with all the build&jar options).
One thing i will need, however, as a dependency on another project of the developer skyebook i have to grab this JAR - and add it to my classpath.
i need these JAR
Well one question - where is my classpath?
look forward to hear from you
greetings
Re: Eclipse with JAR - Classpath on OpenSuse 12.1 [message #865668 is a reply to message #857785] Mon, 30 April 2012 10:03 Go to previous message
Russell Bateman is currently offline Russell Bateman
> classpath.
> i need these JAR
> greetings
Right-click project, choose Build Path -> Configure Build Path -> Libraries.
Previous Topic:Internal web browser disabled using Eclipse/Ubuntu 12.04
Next Topic:uninstall eclipse, how
Current Time: Sat May 25 01:26:04 EDT 2013
Powered by FUDForum. Page generated in 0.01610 seconds
