Home » Eclipse Projects » Web Tools Project (WTP) » Deploying a webservice to Tomcat Xampp
Deploying a webservice to Tomcat Xampp [message #855141] Tue, 24 April 2012 11:01 Go to next message
Pat Fleming is currently offline Pat Fleming
I've raised an issue I have with the above on the newcomers forum and have been directed to here. I've tried to post a link to it here but am not allowed yet. It has the same title in that form as I've given it here.
If any of you would care to have a look at it and direct me about what to do next, that would be great.
Pat
Re: Deploying a webservice to Tomcat Xampp [message #855342 is a reply to message #855141] Tue, 24 April 2012 14:31 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
Usually you want to focus on where you're stuck, "I use the link below to create the web service in eclipse
but when it comes to starting Tomcat, eclipse can't start it." Can you give more details?
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Deploying a webservice to Tomcat Xampp [message #857778 is a reply to message #855141] Thu, 26 April 2012 17:24 Go to previous message
Hi Nitin,
Thanks for taking the time to look at this. Sorry, I've been away for a couple of days.
The link I've used is the one that comes up as the top link if you google 'sencide web service'. It's the Sencide blog, entitled "Create Web Service in Java Using Apache Axis2 and Eclipse" and shows how to set up and deploy a very simple Java webservice. It has acreen shots and is really useful for me, up to a point. The blog is faithful in all respects to what I've seen in Eclipse in the way it creates the web service. .
In following what it says, I get to step 3.6 which has a button in Eclipse to start Tomcat on my localhost. I have Tomcat successfully installed and running as part of the Xampp suite. It's not listening on the standard Tomcat port, 8080 but is listening on 8090.
When I've not started Tomcat through Xampp, Eclipse fails to start it when I press this button, and when I have started it, Eclipse says that the Tomcat port is already in use (I believe I have made a change to tell Eclipse that Tomcat is running on 8090).
Where is the Tomcat configuration in Eclipse? Is there a log which indicates what Eclipse is doing when it's attempting to start Tomcat?
Thanks again for looking at this.
Cheers
Pat
Previous Topic:XML Catalog how
Next Topic:no jee perspective in eclipse-jee-indigo-SR2-win32 version
Current Time: Wed May 22 05:15:05 EDT 2013
Powered by FUDForum. Page generated in 0.05875 seconds
