| Customizer window size [message #856026] |
Wed, 25 April 2012 05:50  |
Markus Schütz Messages: 6 Registered: March 2012 |
Junior Member |
My customizer should always pop up with a certain minimum size.
setPreferredSize() and setBounds() both don't work. Is there any other way?
Whenever someome opens the customizer for the first time, they get a relatively small window which confuses people because they do not expect that they have to resize the window to see every option.
| Re: Customizer window size [message #858754 is a reply to message #856216] |
Fri, 27 April 2012 05:27   |
Junior Member |
I took what I found in "org.eclipse.wb.tests.designer.swing.CustomizeTest" and modified it a bit:
pastebin.com/r9HZqCwN
pastebin.com/y4sR4dtm
pastebin.com/141YpwZa
pastebin.com/ng6fYGtv
( sorry for the inconvenient links, the message board gave me an error saying "You cannot use links until you have posted more than 25 messages." )
I've noticed that, when I open MyButtonTestPanel in WindowBuilder for the first time, a blank panel shows up. No Button.
After running MyButtonTestPanel, closing it and refreshing the design view, the button shows up in WindowBuilder. After cleaning the project and refreshing the designer, the panel is blank again.
( edit: But that might be because I've disabled automatic build )
If the designer is opened with rightclick->customize, a small panel shows up. It should be at least big enough to show all labels.
[Updated on: Fri, 27 April 2012 05:33] Report message to a moderator
| Re: Customizer window size [message #861522 is a reply to message #860874] |
Sat, 28 April 2012 12:07   |
Konstantin Scheglov Messages: 547 Registered: July 2009 |
Yes, when you resize or move customizer dialog, it will remember new size and location, and next time will use the same.
I see that initial size is set to 450x300.
I don't remember already why this was done so (may be this was done not by me), because in general org.eclipse.wb.internal.swing.customize.AwtComponentDialog looks as it was supposed to use customizer getPreferredSize(). So,when if I remove this forced size, then I see of dialog is same as required by customizer.
Fixed in trunk.
Konstantin Scheglov,
Google, Inc.
| Re: Customizer window size [message #865253 is a reply to message #861522] |
Mon, 30 April 2012 06:03  |
Junior Member |
Quote:hi, i'm also new to windowbuilder but i believe that if you resize the customizer, it should remember that size even if you close the ide.
Yes, but the issue was that people did not know they have to resize the customizer to see all options.
Quote:Fixed in trunk.
Thanks!
FUDForum. Page generated in 0.02613 seconds
