Home » Eclipse Projects » Virgo » Loading a vanilla war file fails until WABheaders=defaulted is set
Loading a vanilla war file fails until WABheaders=defaulted is set [message #855798] Wed, 25 April 2012 01:30 Go to next message
Mark Elliot is currently offline Mark Elliot
Referring to www.eclipse.org/virgo/documentation/virgo-documentation-3.0.0.x/docs/virgo-programmer-guide/html/ch04s06.html
I expect that the bundle classpath of a WAR File where the MANIFEST.MF file consists of:
Manifest-Version: 1.0
will include WEB-INF/classes and WEB-INF/lib/*.jar (where *.jar is expanded).
Ultimately, the solution to my cryptic ClassNotFound error for DispatcherServlet was to set repository/ext/org.virgo.web.properties WABHeaders=defaulted; but this isn't a WAB file!
Why do I need to set this relaxation in order to get vanilla war files to run? (is this expected?)
Re: Loading a vanilla war file fails until WABheaders=defaulted is set [message #855996 is a reply to message #855798] Wed, 25 April 2012 05:21 Go to previous messageGo to next message
Frieder Heugel is currently offline Frieder Heugel
Member
http://eclipse.org/virgo/documentation/virgo-documentation-3.5.0.M03/docs/virgo-programmer-guide/htmlsingle/virgo-programmer-guide.html#developing-applications-automatic-imports-web
http://eclipse.org/virgo/documentation/virgo-documentation-3.5.0.M03/docs/virgo-user-guide/html/ch13s08.html
Re: Loading a vanilla war file fails until WABheaders=defaulted is set [message #856136 is a reply to message #855996] Wed, 25 April 2012 07:55 Go to previous messageGo to next message
The first link is the same section I link to; the second doesn't say anything about how WAR files are treated.
My question stands: why do I need to change the way Virgo treats WAB files in order to get my vanilla WAR file to load without error?
Re: Loading a vanilla war file fails until WABheaders=defaulted is set [message #856156 is a reply to message #856136] Wed, 25 April 2012 08:21 Go to previous messageGo to next message
Member
Can you provide an example war file to reproduce this problem? In the past I had problems which dependencies in lib/ that were bundles at the same time but I never investigated this any further. Besides that I never experienced any problems with vanilla war files and VTS.
Frieder
Re: Loading a vanilla war file fails until WABheaders=defaulted is set [message #856414 is a reply to message #856156] Wed, 25 April 2012 12:30 Go to previous messageGo to next message
Violeta Georgieva is currently offline Violeta Georgieva
The problem is already reported - https://bugs.eclipse.org/bugs/show_bug.cgi?id=354730
I'm going to resolve it these days.
Violeta
Re: Loading a vanilla war file fails until WABheaders=defaulted is set [message #856576 is a reply to message #856414] Wed, 25 April 2012 16:02 Go to previous messageGo to next message
Thanks. I wanted to (a) validate that this was unexpected behavior; and (b) file a bug if one did not already exist.
I see that you're working on a patch, any progress?
Re: Loading a vanilla war file fails until WABheaders=defaulted is set [message #857358 is a reply to message #856576] Thu, 26 April 2012 09:28 Go to previous message
Wink
Previous Topic:Maven repository for Virgo 3.0.0 artifacts
Next Topic:virgo ide installation failed
Current Time: Fri May 24 11:36:11 EDT 2013
Powered by FUDForum. Page generated in 0.02570 seconds
