Home » Eclipse Projects » Orion » Orion as a P2 update site
Orion as a P2 update site [message #854700] Tue, 24 April 2012 03:00 Go to next message
Rafael Chaves is currently offline Rafael Chaves
For people building Maven/Eclipse-based produts using Tycho, it helps if a P2 repository that contains the consumed bundles exists.
Is there a P2 repo that includes Orion bundles?
I found bug 338145 but the URLs there are stale.
Re: Orion as a P2 update site [message #855020 is a reply to message #854700] Tue, 24 April 2012 09:08 Go to previous messageGo to next message
John Arthorne is currently offline John Arthorne
Hey Rafael,
We do produce a p2 repository as part of our build, but since Orion itself doesn't currently include p2 we haven't had a lot of use for it. Integration builds are still posted to this repository:
http://download.eclipse.org/e4/updates/orion/0.3-I-builds
Our builds are currently broken so it is empty, but typically this contains the last 4 integration builds. We have no equivalent repository for releases, but you're welcome to enter a bug for that if you would find it useful. And yes, I should also really remove the "0.3" from that repository URL at some point.
John
Re: Orion as a P2 update site [message #855355 is a reply to message #855020] Tue, 24 April 2012 14:46 Go to previous message
Thanks, John. I opened Bug 377568. I have no interest in the update aspect either, but for dependency resolution at build time only.
Rafael
Previous Topic:Hangul input problem
Next Topic:git tags for milestones
Current Time: Fri May 24 02:24:06 EDT 2013
Powered by FUDForum. Page generated in 0.02240 seconds
