| Multiple products in one "export" folder [message #848402] |
Wed, 18 April 2012 03:31  |
Cedric Moonen Messages: 214 Registered: August 2009 |
My workspace has currently 3 plugins: a core plug-in, a UI plug-in and an editor plug-in (UI plug-in which allows the user to edit some data files used by the core plugin, editor not meaning an Eclipse editor but a program that allows the user to edit something).
Both the UI plug-in and the editor are RCP products. Now, what I would like to have is that both these products are exported to the same folder: the editor is responsible to edit data files that will be used by the UI plugin, so they are related and belongs to the same "installation".
I would like to have 2 exes and 2 *.ini files. They will both share the same set of plugins.
Is this possible ?
Thank you,
Cédric
FUDForum. Page generated in 0.02873 seconds
