Home » Eclipse Projects » Rich Client Platform (RCP) » Views and Editors in same folder?
Views and Editors in same folder? [message #852122] Sat, 21 April 2012 13:58 Go to next message
Crypt Demon is currently offline Crypt Demon
Member
Is it possible to put views and editors into the same folder layout?
My application has Views and editors that need to go into the same area. Sometimes they can view graphs, but then I want tabs where they can also edit the data from those graphs. It wouldn't make sense to the user to put the graphs in one pane and then the editor in another.
Re: Views and Editors in same folder? [message #853201 is a reply to message #852122] Sun, 22 April 2012 16:40 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Not in 3.x but in 4.x. Not sure the compat layer allows this through API
but at runtime it works without problems.
Tom
Am 21.04.12 19:58, schrieb Crypt Demon:
Re: Views and Editors in same folder? [message #855035 is a reply to message #853201] Tue, 24 April 2012 09:21 Go to previous messageGo to next message
Member
Hmm. Guess I'll just have to do a workaround and make any editors I want from views. I was wanting to use the forms api too. Don't think it's possible to use that inside a view since it's extended from EditorPart.
Re: Views and Editors in same folder? [message #855069 is a reply to message #855035] Tue, 24 April 2012 09:50 Go to previous message
Simon SSC is currently offline Simon SSC
Member
the Forms API itself can be accessed by the org.eclipse.ui.forms.widgets.FormToolkit.
For further information see this article: www.eclipse.org/articles/Article-Forms/article.html
Simon
Re: Views and Editors in same folder? [message #855072 is a reply to message #855035] Tue, 24 April 2012 09:50 Go to previous message
The low-level forms API can be used anywhere and is not bound to Editors
or Views.
I'd suggest to go with views and ISaveablePart2 interface in there.
Editors can't be bound to a perspective and are visible in any you have
that shows and editor-area.
Tom
Am 24.04.12 15:21, schrieb Crypt Demon:
> EditorPart.
Previous Topic:Importing WTP xml editor functionality in to an RCP
Next Topic:Multiple products in one "export" folder
Current Time: Tue May 21 11:34:43 EDT 2013
Powered by FUDForum. Page generated in 0.02143 seconds
