Home » Eclipse Projects » Memory Analyzer » can't aquire or open dump with MAT 1.1 on IBM SDK J9(can't aquire or open dump with MAT 1.1 on IBM SDK J9)
can't aquire or open dump with MAT 1.1 on IBM SDK J9 [message #852727] Sun, 22 April 2012 04:48 Go to next message
Harold Ship is currently offline Harold Ship
I'm having problems acquiring or opening dumps with Memory Analyzer version 1.1.1.201108240735, for an Apache Tomcat 6 process running under IBM Java version:
java version "1.6.0"
Java(TM) SE Runtime Environment (build pwi3260sr7-20091217_01(SR7))
IBM J9 VM (build 2.4, JRE 1.6.0 IBM J9 2.4 Windows 7 x86-32 jvmwi3260sr7-20091
4_49398 (JIT enabled, AOT enabled)
J9VM - 20091214_049398
JIT - r9_20091123_13891
GC - 20091111_AA)
JCL - 20091202_01
I have set the JVM option as follows, the Eclipse run configuration:
-Xdump:system+heap+java:events=systhrow+user,filter=java/lang/OutOfMemoryError,request=exclusive+prepwalk+compact
When I try to acquire a heap dump, I get the following error message:
Error opening heap dump 'core.20120422.114612.7556.0001.dmp'. Check the error log for further details.
Not a HPROF heap dump (java.io.IOException)
Please help!
[Updated on: Sun, 22 April 2012 04:48]
Report message to a moderator
Re: can't aquire or open dump with MAT 1.1 on IBM SDK J9 [message #853179 is a reply to message #852727] Sun, 22 April 2012 16:05 Go to previous message
Andrew Johnson is currently offline Andrew Johnson
Member
It sounds like you don't have the IBM DTFJ feature installed.
See http://wiki.eclipse.org/index.php/MemoryAnalyzer#System_Dumps_and_Heap_Dumps_from_IBM_Virtual_Machines and IBM DTFJ feature installation instructions.
Previous Topic:MAT on Linux
Next Topic:Steps to write a plugin of ParseSnapshotApp and deploy to MAT MCP
Current Time: Wed May 22 13:19:37 EDT 2013
Powered by FUDForum. Page generated in 0.06030 seconds
