Home » Language IDEs » CDT » [solved] hallo world stopped due to shared library event ubuntu(hallo world stopped due to shared library event ubuntu)
[solved] hallo world stopped due to shared library event ubuntu [message #851994] Sat, 21 April 2012 10:54 Go to next message
Voornaam Achernaam is currently offline Voornaam Achernaam
I tried to debug the hallo world application on ubuntu, but the compiler gave the following error:
.gdbinit: No such file or directory.
Reading symbols from /home/*my name*/Documents/programming/cpp/HalloWereld/Debug/HalloWereld...done.
Stopped due to shared library event
I can run the program in release mode without problem and the terminal-version of gdb also works correctly. If I manually link to the gdbinit file, which is empty, the ".gdbinit: No such file or directory." error disappears, but the "Stopped due to shared library event" error stays. Does anyone know how I can fix this problem?
[Updated on: Mon, 23 April 2012 10:13]
Report message to a moderator
Re: hallo world stopped due to shared library event ubuntu [message #853735 is a reply to message #851994] Mon, 23 April 2012 05:34 Go to previous messageGo to next message
Axel Mueller is currently offline Axel Mueller
Open the Debug Launch Configuration and click the Debugger tab. Then select the tab Shared Libraries. Uncheck "Stop on shared library events".
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: hallo world stopped due to shared library event ubuntu [message #853928 is a reply to message #853735] Mon, 23 April 2012 09:32 Go to previous messageGo to next message
Marc Khouzam is currently offline Marc Khouzam
As a side-note, ".gdbinit: No such file or directory." is not a problem. You can ignore it.
However, I'm surprised you even see this message. Where exactly do you see it?
Marc
Re: hallo world stopped due to shared library event ubuntu [message #853963 is a reply to message #851994] Mon, 23 April 2012 10:13 Go to previous message
Thank you, everything works fine now. The "suspend on shared library event" option was not enabled, instead the "stop on start-up at main" option was enabled. I saw the error in the console tap, while I was not inside the debug view.
[Updated on: Mon, 23 April 2012 10:14]
Previous Topic:Breakpoints unreliable in multithreaded program
Next Topic:Need help getting a fresh Indigo+MinGW install to build and run
Current Time: Fri May 24 15:39:10 EDT 2013
Powered by FUDForum. Page generated in 0.04066 seconds
