Home » Language IDEs » CDT » eclipse qt integration
eclipse qt integration [message #851086] Fri, 20 April 2012 12:28
roby kiss is currently offline roby kiss
I use c++ (with MinGW) in eclipse, it works fine.
I installed Qt SDK with default settings and Qt Eclipse Integration for C++ in c:\eclipse\plugins
when I make a file->new->Qt Gui Project .. i receive in console this error
C:\QtSDK\Symbian\SDKs\Symbian3Qt474\bin\qmake -recursive fgdsgdsgf.pro
Warning: failed to resolve epocroot.
Either
1. Set EPOCROOT environment variable to a valid value.
or 2. Ensure that the HKEY_LOCAL_MACHINE\Software\Symbian\EPOC SDKs\CommonPath registry key is set, and then
a. Set EPOCDEVICE environment variable to a valid device
or b. Specify a default device in the devices.xml file.
Either
and when i build the project i receive
/bin/sh:c:QtSDKSymbianSDKsSymbianQt474binqmake:command not found
and
make:****[d:\eclipse] Error 127
I run eclipse x32 on windows 7 x64.
i have no experience in qt so hope someone can help me
i have to alter the path?
[Updated on: Fri, 20 April 2012 12:32]
Report message to a moderator
Previous Topic:Make eclipse warn when editing Read-only files
Next Topic:How to set realtime priority?
Current Time: Mon May 20 16:28:05 EDT 2013
Powered by FUDForum. Page generated in 0.03327 seconds
