| serialUID mismatch on remote EJB call [message #842381] |
Thu, 12 April 2012 04:40  |
Ga'bor Pe'ntek Messages: 16 Registered: July 2009 |
Junior Member |
I have been writing some tests for an EJB3 bean when I discovered this problem. The test ought to be simple:
* create an entity manager
* get an object from the database
* call ejb with the object as parameter
* verify the result
however the ejb call resulted in an EOF exception caused by serialVersionUID mismatch of ObjectDefinition.
javax.ejb.EJBException: ; nested exception is:
java.io.EOFException; nested exception is: java.io.EOFException
at weblogic.rjvm.t3.MuxableSocketT3.endOfStream(MuxableSocketT3.java:345)
at weblogic.socket.SocketMuxer.deliverExceptionAndCleanup(SocketMuxer.java:826)
at weblogic.socket.SocketMuxer.deliverEndOfStream(SocketMuxer.java:760)
at weblogic.socket.SocketMuxer.readReadySocketOnce(SocketMuxer.java:941)
at weblogic.socket.SocketMuxer.readReadySocket(SocketMuxer.java:888)
at weblogic.socket.JavaSocketMuxer.processSockets(JavaSocketMuxer.java:339)
at weblogic.socket.SocketReaderRequest.run(SocketReaderRequest.java:29)
at weblogic.work.ExecuteRequestAdapter.execute(ExecuteRequestAdapter.java:21)
at weblogic.kernel.ExecuteThread.execute(ExecuteThread.java:145)
at weblogic.kernel.ExecuteThread.run(ExecuteThread.java:117)
at weblogic.ejb.container.internal.RemoteBusinessIntfProxy.unwrapRemoteException(RemoteBusinessIntfProxy.java:121)
at weblogic.ejb.container.internal.RemoteBusinessIntfProxy.invoke(RemoteBusinessIntfProxy.java:96)
at $Proxy0.getReportToInsure(Unknown Source)
at com.***.report.GetReportTest.testGetReport(GetReportTest.java:88)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at junit.framework.TestCase.runTest(TestCase.java:168)
at junit.framework.TestCase.runBare(TestCase.java:134)
at junit.framework.TestResult$1.protect(TestResult.java:110)
at junit.framework.TestResult.runProtected(TestResult.java:128)
at junit.framework.TestResult.run(TestResult.java:113)
at junit.framework.TestCase.run(TestCase.java:124)
at junit.framework.TestSuite.runTest(TestSuite.java:243)
at junit.framework.TestSuite.run(TestSuite.java:238)
at org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38ClassRunner.java:83)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:49)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Caused by: java.io.EOFException
After creating the parameter object by hand instead of retrieving it from the db, the ran fine. It seems that the persistence metadata is also serialized and sent to the server.
I tried to call entityManager.clear() after loading the parameter but that did not help either.
Gábor
FUDForum. Page generated in 0.04957 seconds
