| OEPE + Debian64 [message #848923] |
Wed, 18 April 2012 14:03  |
ismael Missing name Messages: 6 Registered: August 2011 |
Junior Member |
Hello forum
I'm having problems with the preview tab while working with JSP pages with the latest OEPE package in my Debian/Testing AMD64 box.
When I press the preview button, at first it complained about the MOZILLA_FIVE_HOME variable, so I set it like this:
export MOZILLA_FIVE_HOME='/usr/lib/iceweasel/'
Then it complained about not finding libxpcom.so, so I registered a new LD path:
export LD_LIBRARY_PATH=/usr/lib/xulrunner-10.0/
And now when I try the preview, I get the message: Unhandled event loop exception
With this stack trace:
org.eclipse.swt.SWTError: XPCOM error -1041039104
at org.eclipse.swt.browser.Mozilla.error(Mozilla.java:2502)
at org.eclipse.swt.browser.Mozilla.initFactories(Mozilla.java:1764)
at org.eclipse.swt.browser.Mozilla.create(Mozilla.java:757)
at org.eclipse.swt.browser.Browser.<init>(Browser.java:99)
at org.eclipse.jst.pagedesigner.preview.WindowsIEBrowser.create(WindowsIEBrowser.java:33)
at org.eclipse.jst.pagedesigner.editors.HTMLEditor.getPreviewBrowser(HTMLEditor.java:350)
at org.eclipse.jst.pagedesigner.editors.HTMLEditor.pageChange(HTMLEditor.java:1039)
at org.eclipse.ui.part.MultiPageEditorPart$2.widgetSelected(MultiPageEditorPart.java:290)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1282)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1267)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1061)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:2746)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1433)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:257)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
And session Data
eclipse.buildId=M20120208-0800
java.version=1.6.0_24
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=es_MX
Framework arguments: -vm /home/me/Oracle/Middleware/jdk160_29/bin
Command-line arguments: -os linux -ws gtk -arch x86_64 -vm /home/me/Oracle/Middleware/jdk160_29/bin
Any ideas on how can I get the preview function working?
| Re: OEPE + Debian64 [message #849492 is a reply to message #848923] |
Thu, 19 April 2012 03:36  |
Thomas Schindl Messages: 4462 Registered: July 2009 |
Not JDT but WTP related but more about the XULRunner which IIRC is not
available for 64 - or is this only true for windows?
Please ask at the WTP-Forum the line "WindowsIEBrowser" looks strange
because it holds IE in it.
Tom
Am 18.04.12 20:03, schrieb ismael Mising name:
> Hello forum
> LD path:
> exception
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> And session Data
FUDForum. Page generated in 0.01613 seconds
