Home » Eclipse Projects » GEF » To delete an object in gef using the delete key(I have an graphical editor with MultiPageEditpart. How can i delete the an graphical object in the GEF using the delete key?)
To delete an object in gef using the delete key [message #827019] Thu, 22 March 2012 15:50 Go to next message
archana G is currently offline archana G
Any help will be needfull..
Thanks In Advance
Archanag
Re: To delete an object in gef using the delete key [message #832516 is a reply to message #827019] Fri, 30 March 2012 04:32 Go to previous messageGo to next message
Marcel Boerner is currently offline Marcel Boerner
The easiest way is to use org.eclipse.ui.bindings extension point. Just add it to the manifest.xml of your editor plugin. There you can add a key which is the shortcut and a command which should be used when this shortcut is pressed. Your command then needs to delete your modelartefact.
Re: To delete an object in gef using the delete key [message #847618 is a reply to message #827019] Tue, 17 April 2012 09:39 Go to previous message
pawcik Missing name is currently offline pawcik Missing name
For standard GEF Editor the easiest way is to use a GEF ActionBarContributor. But for MultiPageEditor it is not able to provide support for tracking changes. You have tu support this somehow.
In my case I propagate selection in GEF editor like this:
getSite().setSelectionProvider(this.getGraphicalViewer());
and MultiPageEditor has to provide a org.eclipse.ui.part.MultiPageEditorActionBarContributor
check also this www.eclipsezone.com/eclipse/forums/t46499.html.
good luck
Previous Topic:GridLayout and Panel with strange behaviour
Next Topic:[ZEST] Custom Node with large data sets
Current Time: Fri May 24 16:12:27 EDT 2013
Powered by FUDForum. Page generated in 0.01523 seconds
