| KDM model edit and editor plugins missing [message #832022] |
Thu, 29 March 2012 12:56  |
Benjamin Klatt Messages: 30 Registered: September 2010 |
Member |
I am working on a model that references the kdm model provided and generated by the modisco plugins.
Installing the modisco tools provided the plugin org.eclipse.gmt.modisco.omg.kdm containing the model itself. However, there are not org.eclipse.gmt.modisco.omg.kdm.edit and org.eclipse.gmt.modisco.omg.kdm.editor plugins included. Is there a reason for this or could they be added?
Benjamin
| Re: KDM model edit and editor plugins missing [message #832059 is a reply to message #832022] |
Thu, 29 March 2012 14:06   |
Hugo Bruneliere Messages: 447 Registered: July 2009 |
We currently provide only the metamodel itself (and the corresponding generated code).
We usually don't require the "edit" and "editor" as most of the time using reflexive components for handling KDM models, such as the MoDisco Model Browser.
Anyway, if needed these two projects can be automatically regenerated from the KDM Ecore model.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
| Re: KDM model edit and editor plugins missing [message #847516 is a reply to message #832170] |
Tue, 17 April 2012 07:42   |
Hi Benjamin,
We currently don't plan these two projects to be included into the MoDisco builds, so you should generate them by your own and integrate them in your solution if needed.
Hugo
P.S. Sorry for the delay, I was out of office during the last two weeks.
Nantes - France
| Re: KDM model edit and editor plugins missing [message #948582 is a reply to message #947810] |
Thu, 18 October 2012 02:49   |
Fabien Giquel Messages: 134 Registered: July 2009 |
Hi Rafael,
you may import "org.eclipse.gmt.modisco.omg.kdm" plugin your workspace (File->Import...->Plugins and fragments->...). Then you will find /model/kdm.ecore metamodel definition.
Another way is to checkout plugin code from SVN at "https://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.modisco".
Generating .edit and .editor plugins is done from the kdm.genmodel file editor. You may have a look at some existing online EMF tutorials for details.
Fabien.
Fabien GIQUEL
R&D Engineer
Mia-Software
4, rue du Château de l'Eraudiere
44324 NANTES CEDEX 03
FUDForum. Page generated in 0.09866 seconds
