| get rid of -Djava.endorsed.dirs="/opt/local/share/java/tomcat6/endorsed" [message #834899] |
Mon, 02 April 2012 10:35  |
Joël Krähemann Messages: 3 Registered: April 2012 |
Junior Member |
Hi, I read on stackoverflow.com that -Djava.endorsed.dirs="/opt/local/share/java/tomcat6/endorsed" causes spring loading to fail during tomcat6 startup with wtp plugin. But when I delete it from tomcat6 launch configuration next time I open it again it's still there, so what's happening?
a snippet from web.xml
<listener>
<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
</listener>
which causes:
16:31:49,941 ERROR ContextLoader:313 - Context initialization failed
java.lang.ExceptionInInitializerError
at org.springframework.context.support.AbstractRefreshableApplicationContext.createBeanFactory(AbstractRefreshableApplicationContext.java:195)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:128)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:522)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:436)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:385)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:284)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4205)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4704)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
at org.apache.catalina.core.StandardService.start(StandardService.java:525)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
Caused by: java.lang.NullPointerException
at org.springframework.beans.factory.support.DefaultListableBeanFactory.<clinit>(DefaultListableBeanFactory.java:106)
... 22 more
02.04.2012 16:31:49 org.apache.catalina.core.StandardContext listenerStart
SCHWERWIEGEND: Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
... 22 more
02.04.2012 16:31:49 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error listenerStart
SCHWERWIEGEND: Context [/docadmin] startup failed due to previous errors
02.04.2012 16:31:49 org.apache.catalina.core.ApplicationContext log
INFO: Closing Spring root WebApplicationContext
02.04.2012 16:31:49 org.apache.catalina.core.StandardContext listenerStop
SCHWERWIEGEND: Exception sending context destroyed event to listener instance of class org.springframework.web.context.ContextLoaderListener
java.lang.IllegalStateException: BeanFactory not initialized or already closed - call 'refresh' before accessing beans via the ApplicationContext
at org.springframework.context.support.AbstractRefreshableApplicationContext.getBeanFactory(AbstractRefreshableApplicationContext.java:172)
at org.springframework.context.support.AbstractApplicationContext.destroyBeans(AbstractApplicationContext.java:1066)
at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:1040)
at org.springframework.context.support.AbstractApplicationContext.close(AbstractApplicationContext.java:988)
at org.springframework.web.context.ContextLoader.closeWebApplicationContext(ContextLoader.java:556)
at org.springframework.web.context.ContextLoaderListener.contextDestroyed(ContextLoaderListener.java:142)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4244)
at org.apache.catalina.core.StandardContext.stop(StandardContext.java:4879)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4749)
16:31:49,955 WARN XmlWebApplicationContext:1028 - Exception thrown from ApplicationListener handling ContextClosedEvent
java.lang.IllegalStateException: ApplicationEventMulticaster not initialized - call 'refresh' before multicasting events via the context: Root WebApplicationContext: startup date [Mon Apr 02 16:31:49 CEST 2012]; root of context hierarchy
at org.springframework.context.support.AbstractApplicationContext.getApplicationEventMulticaster(AbstractApplicationContext.java:337)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:324)
at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:1025)
16:31:49,956 WARN XmlWebApplicationContext:1036 - Exception thrown from LifecycleProcessor on context close
java.lang.IllegalStateException: LifecycleProcessor not initialized - call 'refresh' before invoking lifecycle methods via the context: Root WebApplicationContext: startup date [Mon Apr 02 16:31:49 CEST 2012]; root of context hierarchy
at org.springframework.context.support.AbstractApplicationContext.getLifecycleProcessor(AbstractApplicationContext.java:350)
at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:1033)
You can download project from sourceforge.net it's name is docadmin
| Re: get rid of -Djava.endorsed.dirs="/opt/local/share/java/tomcat6/endorsed" [message #846686 is a reply to message #846564] |
Mon, 16 April 2012 13:32  |
Tim Kryselmire Messages: 2 Registered: April 2012 |
Junior Member |
Sorry for the delay in posts. My wife had a baby so I was out last week.
I made an interesting discovery regarding this error: It seems to be more related to the Tomcat instance than anything else.
I got annoyed at it and just deployed to production (not the best practice, I know) but it ran on production! Now the question is, what is different.
So far I've verified that:
1. the same JRE and JDK are installed on production and my test environment (1.6.31 in this case).
2. Same Tomcat configurations (in my case I just copied the tomcat directory from production)
3. All Endorsed jars are same version (again, copied)
I don't know if it will help you, but this has certainly boiled down the list of possibilities for me.
FUDForum. Page generated in 0.03785 seconds
