Home » Eclipse Projects » P2 » issue to generate some plugins in P2 format with a headless build.
issue to generate some plugins in P2 format with a headless build. [message #846636] Mon, 16 April 2012 08:43
mohamed Missing name is currently offline mohamed Missing name
Hi all,
I'm using a headless build to generate the updates sites. One of our customers had a problem to install some update sites, for this reason i decided to switch to p2 format.
I made some changes in some files like :
- Build.properties :i add some p2 properties
* p2.gathering = true
* p2.compress = true
* properties.1.name=org.eclipse.equinox.p2.type.category
* properties.1.value=true
- allElements.xml : group.group.group
After that i launched a build and it's ok.But the build didn't generate correctly some p2 repository and the folder features is missing under the archive .zip !!!
can someone help me to fix this problem ??
Thanks.
best regards.
Previous Topic:Updates are not installed properly?
Next Topic:p2.mirror and site.xm
Current Time: Tue May 21 11:34:42 EDT 2013
Powered by FUDForum. Page generated in 0.01733 seconds
