Home » Eclipse Projects » Rich Client Platform (RCP) » View with ISaveablePart
View with ISaveablePart [message #820852] Wed, 14 March 2012 12:53 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising name
Can i use ISaveablePart with ViewPart? I have tried that but save action does not get enabled... any idea?
if ViewPart can not be used with ISaveablePart then how to add editor to perspective... i donot want editor to be attached with File.
Re: View with ISaveablePart [message #845879 is a reply to message #820852] Sun, 15 April 2012 10:02 Go to previous message
Wim Jongman is currently offline Wim Jongman
Yes that works. Please call
firePropertyChange(PROP_DIRTY);
and reply with "true" in the isdirty method if your view has contents to be
saved. This will enable the save buttons. It works exactly the same as in
editors. They implement isaveablepart as well.
You just open an editor and it gets displayed. To open an editor
programmatically, call openEditor on the page.
to get the page: platformui.getworkbench.getactiveworkbenchwindow....
etcetera
to get the page from a view: getsite.getpage
Wim
> Cheers,
Previous Topic:Updating only visible rows
Next Topic:Default entry point does not exist
Current Time: Mon May 20 12:55:21 EDT 2013
Powered by FUDForum. Page generated in 0.02077 seconds
