Home » Eclipse Projects » Orion » Hangul input problem
Hangul input problem [message #843300] Thu, 12 April 2012 19:53 Go to next message
Cho Hyun Jong is currently offline Cho Hyun Jong
Member
hello.
I've been using OrionHub. OrionHub editor in Eclipse RAP included.
I have a problem.
Hangul(Korea Language) input then stopped frequently.
The editor can not enter Hangul longer. English is the normal input.
A problem is seen as the input Hangul.
Example,
INSERT INTO sampl3e_table (id, name)
VALUES
(49, '22');
View a normal eye, but ( and 4 have between ?(3F).
like this.
This problem occurs frequently.
Let me help you.
Re: Hangul input problem [message #843304 is a reply to message #843300] Thu, 12 April 2012 19:56 Go to previous messageGo to next message
Member
like this.
hangumkj.blogspot.com/2012/04/blog-post.html
my program demo site
ec2-176-32-83-35.ap-northeast-1.compute.amazonaws.com:8080/tadpole/db?startup=tadpole
[Updated on: Thu, 12 April 2012 20:38]
Report message to a moderator
Re: Hangul input problem [message #844093 is a reply to message #843300] Fri, 13 April 2012 13:28 Go to previous messageGo to next message
John Arthorne is currently offline John Arthorne
If you are using RAP then I don't think the Orion editor is being used. There is this bug in RAP requesting use of the Orion editor:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=277346
You must be using RAP's own editor, so I suggest reporting the problem to the RAP team in bugzilla.
John
Re: Hangul input problem [message #844462 is a reply to message #844093] Fri, 13 April 2012 22:30 Go to previous messageGo to next message
Member
i using embedded editor on RAP Browser widget.
like this
http: //deanoneclipse.wordpress.com/2011/05/18/riding-the-editor-life-cycle
thanks John Arthorne
[Updated on: Fri, 13 April 2012 22:31]
Re: Hangul input problem [message #844537 is a reply to message #844462] Sat, 14 April 2012 00:27 Go to previous message
Member
i posted
bugs.eclipse.org/bugs/show_bug.cgi?id=376794
Previous Topic:Key words auto suggestion
Next Topic:Orion as a P2 update site
Current Time: Wed May 22 17:59:14 EDT 2013
Powered by FUDForum. Page generated in 0.01682 seconds
