| Hudson and modules activated via parameterized profile [message #844191] |
Fri, 13 April 2012 15:51  |
Jay Blanton Messages: 2 Registered: April 2012 |
Junior Member |
There is a bug reported for Jenkins that has information related specifically to the type of issue we are having with Hudson 2.2.0 (with both maven 2.2.0 and maven 3.0.4).
issues.jenkins-ci.org/browse/JENKINS-2295
We utilize build parameters so we can customize our maven command, for example (providing a drop-down with all our different envs so that a build person can select the environment they want and this gets substituted into the build section of the mvn package).
The problem is we want to be able to parameterize profiles that contain modules. So there isn't a problem using parameters that resolve profiles if those profiles just hold properties...for instance:
<profile>
<id>sample</id>
<properties>
<target.names>${sample.name}</target.names>
<deploy.port>${sample.port}</deploy.port>
<deploy.hostname>${sample.hostname}</deploy.hostname>
<deploy.user>${sample.userId}</deploy.user>
<deploy.password>${sample.password}</deploy.password>
</properties>
</profile>
We can have a String Param = CONTAINER that takes an env property and have a command that does something like:
mvn package -P$CONTAINER -fae
And this works fine because the profile contains only properties.
The problem occurs when one of our profiles contains modules. Even if I go in and comment out all plugins/dependencies/functionality in the modules plugins - we receive the NullPointerException...so for instance:
<profile>
<id>projects-to-build</id>
<modules>
<module>sample-proj-1</module>
<module>sample-proj-2</module>
</modules>
</profile>
If we have a String param = PROFILE and it is set to projects-to-build, then Hudson will correctly output (in the console) the correct mvn command:
mvn package -P$PROFILE -fae
Becomes the following in the console
mvn package -Pprojects-to-build -fae
But after the reactor is built and the module poms are going to be processed, we receive:
mavenExecutionResult exceptions not empty
message : Internal error: java.lang.NullPointerException
cause : null
Stack trace :
org.apache.maven.InternalErrorException: Internal error: java.lang.NullPointerException
at org.apache.maven.lifecycle.internal.BuilderCommon.handleBuildError(BuilderCommon.java:128)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:95)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
at org.jvnet.hudson.maven3.launcher.Maven3Launcher.main(Maven3Launcher.java:79)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:329)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:239)
at org.jvnet.hudson.maven3.agent.Maven3Main.launch(Maven3Main.java:158)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:104)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:70)
at hudson.remoting.UserRequest.perform(UserRequest.java:118)
at hudson.remoting.UserRequest.perform(UserRequest.java:48)
at hudson.remoting.Request$2.run(Request.java:287)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.NullPointerException
at hudson.maven.Maven3Builder$MavenExecutionListener.recordProjectStarted(Maven3Builder.java:286)
at hudson.maven.Maven3Builder$MavenExecutionListener.projectStarted(Maven3Builder.java:276)
at org.jfrog.build.extractor.maven.BuildInfoRecorder.projectStarted(BuildInfoRecorder.java:149)
at org.apache.maven.lifecycle.internal.DefaultExecutionEventCatapult.fire(DefaultExecutionEventCatapult.java:71)
at org.apache.maven.lifecycle.internal.DefaultExecutionEventCatapult.fire(DefaultExecutionEventCatapult.java:42)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:78)
... 24 more
Is anyone else seeing this problem? This is holding us back from utilizing smarter jobs so that we can create one job regardless of what we are building and using the parameters so that we can dynamic set the profile during build time. But without this working, someone has to manually reconfigure the job everytime they want to change the profile or create duplicate jobs for different profiles.
Thanks..
FUDForum. Page generated in 0.01624 seconds
