Home » Eclipse Projects » Remote Application Platform (RAP) » GraphicalEditorWithFlyoutPalette & mouse wheel scrolling
GraphicalEditorWithFlyoutPalette & mouse wheel scrolling [message #837945] Fri, 06 April 2012 06:29 Go to next message
Andrea Poli is currently offline Andrea Poli
I'm writing a RAP application which is a port of a PDE plugin. The aim of this application is to draw an automaton starting from its XML description.
The automaton is contained inside a GraphicalEditorWithFlyoutPalette.
The problem is that I'm able to scroll the automaton only by moving the mouse on the scroll bar and clicking on it (so the scroll bar has the focus).
I've tried different approaces:
1. to add a MouseWheelHandler to the GraphicalViewer using setProperty method
1a. setting CTRL as key
1b. setting SWT.None as key
2. to use addListener method setting SWT.MouseWheel (this constant is not defined for
RAP so I tried to use the raw value, 37)
3. to filter mouse wheel event using addFilter method of Display class
None of them works.
I will appreciate any suggestion.
Thanks a lot.
[Updated on: Fri, 06 April 2012 06:37]
Report message to a moderator
Re: GraphicalEditorWithFlyoutPalette & mouse wheel scrolling [message #841881 is a reply to message #837945] Wed, 11 April 2012 16:31 Go to previous messageGo to next message
Austin Riddle is currently offline Austin Riddle
Hi Andrea,
Would you please open a bug on this issue. I will have a look at it.
Thanks.
Re: GraphicalEditorWithFlyoutPalette & mouse wheel scrolling [message #842655 is a reply to message #841881] Thu, 12 April 2012 09:54 Go to previous message
This is the bug id: 376573.
Thanks.
[Updated on: Thu, 12 April 2012 16:24]
Previous Topic:Who can provide demos of RAP upload and download
Next Topic:Nebula formattedtext
Current Time: Thu May 23 16:50:25 EDT 2013
Powered by FUDForum. Page generated in 0.01834 seconds
