Home » Newcomers » Newcomers » Linking data sets when one calls a stored procedure(Trouble using stored procedure result)
Linking data sets when one calls a stored procedure [message #841224] Tue, 10 April 2012 23:29 Go to next message
Paul Missing name is currently offline Paul Missing name
I'm sure that this will be documented somewhere, but I've looked for ages and can't find it. (Yes, I'm very new to Birt. Sorry.)
I have an Oracle function that takes an input parameter. I've created the dataset to execute this function, and I can view the result when I write something like:
select MYSCHEMA.PRODUCTDETAIL(23) from dual
However, I want the function to be called for each product line in the PRODUCT table.
I can see how to merge normal data sets from the documentation. However, I simply cannot see how to call the result of a stored procedure from the dataset that I want to use to display it. I would be very grateful if someone could either write some points on how to do this, or point me to where it is documented? (from what I've read, I will probably need to change the 23 above to a ?, but I'm not sure what next.)
thank you.
Re: Linking data sets when one calls a stored procedure [message #841568 is a reply to message #841224] Wed, 11 April 2012 09:23 Go to previous message
Russell Bateman is currently offline Russell Bateman
On 4/10/2012 9:29 PM, Paul Mising name wrote:
> Hello,
> PRODUCT table.
> thank you.
BIRT questions are handled in the Eclipse BIRT forum.
Previous Topic:python and pyglet on osx lion arch -i386
Next Topic:Eclipse IDE for EGL Web Developers
Current Time: Fri May 24 20:36:36 EDT 2013
Powered by FUDForum. Page generated in 0.06440 seconds
