Home » Newcomers » Newcomers » Color code new file type
Color code new file type [message #838074] Fri, 06 April 2012 10:29 Go to next message
David Jackson is currently offline David Jackson
How do you add a new file type for example .module to be recognised by Eclipse and use the PHP code color scheme?
Re: Color code new file type [message #840439 is a reply to message #838074] Tue, 10 April 2012 00:54 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
http://wiki.eclipse.org/WTP_FAQ#How_do_I_use_my_own_filename_extensions_in_the_XML_editor.3F_It_only_works_correctly_if_a_file_ends_with_.xml.
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Spell check issue with Eclipse
Next Topic:Dynamic Web Project : Applet not showing in browser
Current Time: Thu May 23 16:30:00 EDT 2013
Powered by FUDForum. Page generated in 0.01529 seconds
