Home » Archived » M2M (model-to-model transformation) » [QVT] not keyword recognized as a keyword
[QVT] not keyword recognized as a keyword [message #839570] Sun, 08 April 2012 19:19 Go to next message
chadi assem is currently offline chadi assem
hello, I face a problem that may already be familiar to some. When I code:
model::keywordlike_name::element
the keywordlike_name is recognized as a Keyword!!! as an exemple, I wrote:
model::references::ReferenceType
references remains RED
is this a qvt incapability of distinction or what!!?
Re: [QVT] not keyword recognized as a keyword [message #839737 is a reply to message #839570] Mon, 09 April 2012 01:43 Go to previous message
This is a problem in almost all languages. Try using 'package' as a
variable name in Java.
AFAIK Java offers no solution other than renaming.
Modeling requires all names to be useable, so there are escaping mechanisms.
In OCL 2.0 and 2.2, and consequently QVT 1.0 and 1.1, a '_' prefix could
be used.
In OCL 2.3 this was deprecated since it was ambiguous for already '_'
prefixed names. The preferred escaping is therefore to use an '_'
prefixed string literal, which also allows spaces, backspaces/new-lines
and any other garbage you might like in a name.
Since Eclipse QVTo reuses Eclipse OCL, the enhancement in OCL is present
in QVT as well so you can do model::_'references'::ReferenceType
Ed Willink
> code:
> references remains RED is this a qvt incapability of distinction or
> what!!?
Previous Topic:Nmodels2Nmodels transformation [qvto]
Next Topic:[ATL] Transformation failure with model references serialized with absolute paths
Current Time: Fri May 24 21:18:40 EDT 2013
Powered by FUDForum. Page generated in 0.01556 seconds
