Home » Language IDEs » CDT » Eclipse Indigo problem with debugger(debugger gives error no source found for ntdll.....)
Eclipse Indigo problem with debugger [message #839197] Sun, 08 April 2012 05:01 Go to next message
Waqas Afzal is currently offline Waqas Afzal
I am new to Eclipse. I have started with CDT and using MinGW. The debugger was working fine until I started getting this error after I am halfway through my program. It says that no source found for ntdll....... How can I resolve this? I have been stuck on it for two days. I am using Eclipse Indigo. Thanks
Re: Eclipse Indigo problem with debugger [message #839316 is a reply to message #839197] Sun, 08 April 2012 09:34 Go to previous message
David Wegener is currently offline David Wegener
On 04/08/2012 04:01 AM, Waqas Afzal wrote:
It sounds like you have stepped into a Windows routing. Ntdll is a
Windows system library. I don't think Microsoft distributes source for
the library, so you won't be able to see the source for it.
Previous Topic:Color on disassembly
Next Topic:Cygwin/Path/Symlink fixed = error 1 and no description?
Current Time: Fri May 24 01:35:53 EDT 2013
Powered by FUDForum. Page generated in 0.01895 seconds
