Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » JVM problem running test with ant script
JVM problem running test with ant script [message #83747] Mon, 18 September 2006 07:15 Go to next message
Dubois Jean-Jacques is currently offline Dubois Jean-Jacques
I've a problem to run test using an Ant script.
I've a default JVM 1.3 installed on my computer (and I can't change it
because it's the default JVM in my office) and some other 1.4 and 1.5 jvms
(not default).
I start Eclipse with the 1.5 JVM specified in my shortcut and the default
JRE associated with my Eclipse runtime is well the 1.5 but when I launch
an Ant script to execute test with TPTP he used the defaut JVM installed
on my computer and that doesn't work because Ant needs a 1.4.1 or higher...
How can I specify an other JVM for Ant inside TPTP?
Re: JVM problem running test with ant script [message #83762 is a reply to message #83747] Mon, 18 September 2006 11:06 Go to previous messageGo to next message
Joe Toomey is currently offline Joe Toomey
Member
Hi Jean-Jacques,
If you're running your ant script from within eclipse, you can change
the JRE by modifying the preferences in Window -> Preferences -> Java ->
Installed JREs. Of course, to run ant tasks that include compile steps,
you'll need to configure using a JDK so you get tools.jar.
If you're running ant from outside eclipse, just set your JAVA_HOME
variable to point to the root of your JDK install directory.
Hope this helps,
--Joe
dubois jean-jacques wrote:
> jvms (not default).
> default JRE associated with my Eclipse runtime is well the 1.5 but when
> I launch an Ant script to execute test with TPTP he used the defaut JVM
> installed on my computer and that doesn't work because Ant needs a 1.4.1
> or higher...
Re: JVM problem running test with ant script [message #83806 is a reply to message #83762] Tue, 19 September 2006 01:55 Go to previous message
Joe,
I've verified the preferences and the referenced JRE is the good one (1.5).
I've tried to set the JAVA_HOME variable but that doesn't work... :s
When I run an Ant script to build a Eclipse plug-in, I don't have this
problem but with TPTP it takes the default JVM.
This problem seems occurs when Ant use a class from the ant-tptp jar but I
don't see why...
Thx for your help :)
Jean-Jacques
Previous Topic:jvmti agent
Next Topic:Editor extensions
Current Time: Sat May 25 04:39:54 EDT 2013
Powered by FUDForum. Page generated in 0.01662 seconds
