Home » Eclipse Projects » BIRT » Crosstab style(Manage crosstab boders style)
Crosstab style [message #837300] Thu, 05 April 2012 09:52 Go to next message
Fabien REMY is currently offline Fabien REMY
Hi again,
I try to manage the crosstab borders in order to remove some borders (see screenshot)
I'va already tried to modify styles, modify border of the crosstab itself,...
I just wonder, where is the main configuration to manage border style of the crosstab ?
Thank you.
Re: Crosstab style [message #837446 is a reply to message #837300] Thu, 05 April 2012 13:14 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Check the styles from the outline view and you will see the default
crosstab styles. You can change these in the style editor or through
script. You may be interested in some of the scripting and other info
available on crosstabs, so have a look here:
http://birtworld.blogspot.com/2010/07/birt-and-olap.html
Jason
On 4/5/2012 9:52 AM, Fabien REMY wrote:
> Hi again,
> Thank you.
Jason Weathersby
BIRT Exchange
Re: Crosstab style [message #837986 is a reply to message #837446] Fri, 06 April 2012 07:48 Go to previous message
Thank you for theis link, I will have a look and see if I can find all I need.
I've already tried to modify the crosstab style, but without success.
I tell you more as soon as I study the link.
Thanks a lot
Previous Topic: task.setParameterValue
Next Topic:How to run BIRT reports using Java swing?
Current Time: Thu May 23 21:10:57 EDT 2013
Powered by FUDForum. Page generated in 0.04320 seconds
