Home » Eclipse Projects » Web Tools Project (WTP) » Combobox is closed soon in the Property view in WPE(in eclipse3.6, )
Combobox is closed soon in the Property view in WPE [message #836322] Wed, 04 April 2012 06:54
satoshi kobayashi is currently offline satoshi kobayashi
When I choose a control and change its property in the property view,
some of the combobox will be closeed as soon as I open it.
I would appreciate it very much if somebody tell me how to fix it.
The problem will be shown in the following case:
Precondition:
1. Create a new Dynamic Web project.
2. Create a JSP file and open it with WPE.
3. Place a button control from palette to the graphical editor.
Steps to reproduce:
1. Select the control's attribute in property view to activate the cell editor(I chose lang attribute)
2. Then, quickly open the combo box. (within approximately 1 sec, in my environment)
Results:
The combo box loses its focus quickly before allowing the user to set a selection.
If I wait a little bit for the cell editor to finish its activation, then the
drop down menu stays as expected when I click on the drop down button.
The cause of this problem I guess is somewhat related to the forcefocus method
that is called in the last part of activate of the cell editor, which is:
org.eclipse.jst.pagedesigner.properties.celleditors.LabeledStyleComboCellEditor
Thanks in advance.
Previous Topic:I want to customize the pageDesignEditor !
Next Topic:Trouble importing war file into Enterprise App project
Current Time: Fri May 24 16:52:55 EDT 2013
Powered by FUDForum. Page generated in 0.01473 seconds
